#183703 - 08/10/2003 16:49 playing music in emplode
thrasher
can you play music while in emplode off of the empeg.
040103958 60g
#183704 - 08/10/2003 16:51 Re: playing music in emplode [Re: thrasher]
Yes.
#183705 - 08/10/2003 16:57 Re: playing music in emplode [Re: tfabris]
thrasher
can you explain how or point me in the right direction.I can not get it to play.Thanks
040103958 60g
#183706 - 08/10/2003 16:59 Re: playing music in emplode [Re: tfabris]
Heh, I suppose you'd like a more detailed answer.
If you plug the audio outputs of the empeg into the Line Input on your sound card (using the correct cable of course), then you can use the buttons on the Emplode tool bar to play songs.
You can also stream songs over ethernet this way.
#183707 - 08/10/2003 17:01 Re: playing music in emplode [Re: tfabris]
thrasher
Thanks I guess im on my way to stapels.Thanks for the fast reply,your the best
040103958 60g
#183708 - 08/10/2003 17:05 Re: playing music in emplode [Re: thrasher]
If you have ethernet, you can even remotely control the player with my EmpegFace utility.
#183709 - 08/10/2003 17:16 Re: playing music in emplode [Re: thrasher]
Anonymous
Unregistered
There's no need to thank or compliment the robot.
#183710 - 08/10/2003 17:36 Re: playing music in emplode [Re: ]
Anonymous
Unregistered
I'm joking of course. tfabris is the heart of this bbs.
#183711 - 08/10/2003 17:37 Re: playing music in emplode [Re: ]
Thank you very much, both of you. It's good to be appreciated.
#183712 - 08/10/2003 18:35 Re: playing music in emplode [Re: tfabris]
SE_Sport_Driver
Tony, all this time I used CharcholGrey99's XML thingy, I didn't realize that you made that! Cool!
#183713 - 09/10/2003 14:04 Re: playing music in emplode [Re: SE_Sport_Driver]
lopan
Loc: Manassas VA
I recently discovered empeg face as well.... you da man master kahn...
Brett 60Gb MK2a with Led's
#183714 - 09/10/2003 14:05 Re: playing music in emplode [Re: lopan]
lopan
Loc: Manassas VA
AND I AM NOW AN OLD HAND!!!! Sweet!
#183715 - 09/10/2003 14:26 Re: playing music in emplode [Re: SE_Sport_Driver]
Thanks! I wrote it because I liked CharcoalGray's XML thingy (and still do, and still use it for other stuff), but wanted it to float without an IE border around it. Really, that's all it was meant to be. It kind of expanded though.
#183716 - 09/10/2003 14:31 Re: playing music in emplode [Re: lopan]
Thank you! And that's Master Kan by the way.
#183717 - 09/10/2003 15:24 Re: playing music in emplode [Re: tfabris]
SE_Sport_Driver
Tony, I noticed that you have support for skins on this thing... how about some 303 facias! Or for fun, a Mk1 skin and "no facia installed" skin?
#183718 - 09/10/2003 15:26 Re: playing music in emplode [Re: SE_Sport_Driver]
Go for it. Instructions on creating skins is in the zip file. There is already a 303 skin I think. Check the programming forum, a few cools skins have already been posted.
#183719 - 09/10/2003 15:27 Re: playing music in emplode [Re: tfabris]
SE_Sport_Driver
D-oh! I must have been away that month! Thanks!~
#183720 - 09/10/2003 19:36 Re: playing music in emplode [Re: tfabris]
SE_Sport_Driver
I am SO loving this little program! I've got the 303 skin and transparency set to match my Trillian!
#183721 - 09/10/2003 21:38 Re: playing music in emplode [Re: SE_Sport_Driver]
Hey, cool, thanks! Glad you like it!
