#182136 - 30/09/2003 14:41 So what's up with this boot log?
Flawed
Here's the boot log that I get on an empeg that I bought for $200. Rob has said that one of the chips needed to be replaced but I'd like to verify that and I know he's having some problems now so I'll ask you guys to take a look at it. Sometimes it boots up fine... Solder joints look fine as does the ide cable...
Tx!
˙If there is anyone present who wants to upgrade the flash, let them speak now,ite: device select failed
Page cache hash table entrie
i2c: Failed to receive
or forever hold their peace...it seems not. Let fly the Penguins of Linux! failedFIX
empeg display initial
I2C write failed (927, 0)inux
Star
e000 v1.04v 1
Copying kernel...mpeg dsp audio in
Calling linux kernel...rsion 4.27 wDentry hash
Buffer cache has
IP Protocols: ICM
i2c_write: device select failedxf8010000 (ir
l. 1
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315 Failed to receive ACK for data!cols for Linux-2.2 (Dag Brattli)stin
ttyS01 at
(release)) #17 Wed Jul 24 18:23:20 BST 2002 select failedol ( revision:Tue May 18 03:1
Processor: Intel StrongARM-1100 revision 11= 16) is a SA1100 UART
ircomm_tty
NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel ce select f
Uncompressing L
Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 )e, booting the kernereceive ACK for data!emote control/panel butt
ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 ) Faile
i2c_write: device select failedk5-np17-empeg51 (mac@aphex) (gci2c_write:
Starting kswapd v 1.58c1 (save to d0004c80
SA1100 serial driver version 4.27 with no serial options enabledmpeg RDS driver i
i2c_write: device select failed(release)) #17
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UARTata!
I2C write failed (
ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UARTto receive ACK for data!(927, 0)
Probing primary inte
Calibrati
i2c: Failed to receive ACK for data!Failed to receive ACK for data! 64k)
i2c_write: device select failedreceive A
i2c: Failed to receive ACK for data!(ordice select failed... done, booti
i2c_write: device select failedmpeg dsp mixer initialised
i2c: Failed to receive ACK for data!ialisede testing by UNIFIX17-empeg51
i2c_write: device select failedould not find CS4231A (vers
I2C write failed (fff, d223)4: Line: device
empeg state
i2c: Failed to receive ACK for data!o d0004f80).rotocol90d)
i2c: Failed to receive ACK for data!inux-2.2 (Dag Brattli)
i2c_write: device select failedplayer (hardware revision 9, se
i2c: Failed to receive ACK for data!ed: 16 RAM disks of 4096K sizeOMM p
i2c_write: device select failed:11:39 1999 )
Calibrati
I2C write failed (927, 0)K for data!
empeg single channel IDE, 20k reser
i2c_write: device select failedterface...l tty driver for IrCO
I2C write failed (8f9, 90d)rite: device select failede
i2c: Failed to receive ACK for data!driveailed (8ef, 800)
i2c_write: device select failedriveACK for data! 64k)
i2c: Failed to receive ACK for data!ice select f
hda: IBM-DJSA-220, ATA
i2c_write: device select failedwith no ser
i2c: Failed to receive ACK for data!y UNIFIX
hda: IBM-DJSA-220, ATA DIS
smc chip id/r
i2c: Failed to receive ACK for data!roto
empeg dsp, UDP, TC
smc9194.c:v0
i2c_write: device select failedrik@vt.edu)initialised384 bhash
i2c: Failed to receive ACK for data!river initialised (f
empeg audio-in
i2c_write: device select failedMC9194: SMC91C94(r:9) at 0x4008
I2C write failed (8f9, 90d)MAC 00:02:d7:22:06:3ote con
i2c: Failed to receive ACK for data!empeg single channel IDE
i2c_write: device select failederface...l tty driver for IrCOM
i2c: Failed to receive ACK for data! PDIUSBD12
i2c_write: device select failedhda2 hda3 hda4Starting kswapd v
i2c: Failed to receive ACK for data!pport initialisen 4.27 with no ser
h
i2c_write: device select failedtem found at block 0
i2c: Failed to receive ACK for data!K: Loading 320 blocks [1
empeg
empeg dsp mixer initialisedvt.edu)init
hda: IBM-DJSA-2
empeg dsp initialisedio-in initial
SM
i2c
Could not find CS4231A (version=80)INTF:TP MEM:6144b MAC 00:02:d7:22
i
empeg usb initialised, PDIUSBD12 id 1012: IBM-DJSA-220, 19077MB w
empeg
empeg state support initialised 0089/88c1 (save to d0005100).ck 0
i2c_write: device select faileder in
empeg RDS driver initialisedm disk... done.
emp
i2
empeg power-pic driver initialised (first boot)FS: Mounted root (ext2 filesys
smc9
i
e000 v1.04o receive
C
aI
Partition check:fff, d223)
hda: hda1 < hda5 hda6 > hda2 hda3 hda4nel...
i2c: Fail
RAMDISK: ext2 filesystem found at block 0.....................
i2c_write: dev
RAMDISK: Loading 320 blocks [1 disk] into ram disk... done.te: device select failed!
i2c
i2c
l.a
empeg-pump v0.03 (19980601)!
i2c_write: dev
Press Ctrl-A to enter pump...hange_root: old root has d_count=1
I2C write failed (8ef, 800)
Trying to unmount old root ... okaya!
Freeing player.cpp : 385:empeg-car 2.00-beta13 2002/07/24. Failed to receive ACK for data!y loop... 207.67 BogoMIPS
i2c: Failed to receive ACK for data!d/07/24.
Page cache hash table entriekernel.
i2c_write: device select failed device select failed..........
i2c: Failed to receive ACK for data!receive ACK for data!y UNIFIX
i2c_write: device select failedr dat
NET4: Li
l.
i2c: Fai
i2c: Failed to receive ACK for data! failed(gcc version 2.95.3
IP Proto
i2c_write: device select failedvice select failed
i2c: Failed to receive ACK for data!onailed:23:20 BST
i2c_write: device select faileddriver failable (96
i2c: Failed
i2c: Failed to receive ACK for data!iled00:49:11 1999 )
i2c_write:
i2c_write: device select failedmpeg-car bootstrap v1.02 200011
i2c_writ
St
i2c_write: device select faileder 4, 64
i2c: Failed to receive ACK for data!let them speak now,ntrie
i2c_write:
i2c: Fail
I2C write failed (8e1, 347)
Vcb: 0x4086d000
#182137 - 30/09/2003 15:08 Re: So what's up with this boot log? [Re: Flawed]
Oh, that looks so unhealthy!!!
#182138 - 30/09/2003 15:37 Re: So what's up with this boot log? [Re: Flawed]
Consider it verified, since these are not supposed to be in the output:
#182139 - 30/09/2003 15:43 Re: So what's up with this boot log? [Re: Flawed]
Dead 74LVX04 probably
#182140 - 30/09/2003 15:43 Re: So what's up with this boot log? [Re: tfabris]
maczrool
Loc: Louisiana, USA
Like I said, in case you missed it on my other post. I will replace that chip for you. Since Empeg support is down for a while, it's your only option right now.
Stu
#182141 - 30/09/2003 19:07 Re: So what's up with this boot log? [Re: maczrool]
Flawed
I sent you a PM.
Thanks!
