#182136 - 30/09/2003 14:41 So what's up with this boot log?
Flawed
Here's the boot log that I get on an empeg that I bought for $200. Rob has said that one of the chips needed to be replaced but I'd like to verify that and I know he's having some problems now so I'll ask you guys to take a look at it. Sometimes it boots up fine... Solder joints look fine as does the ide cable...
Tx!
ÿIf there is anyone present who wants to upgrade the flash, let them speak now,ite: device select failed
Page cache hash table entrie
i2c: Failed to receive
or forever hold their peace...it seems not. Let fly the Penguins of Linux! failedFIX
empeg display initial
I2C write failed (927, 0)inux
Star
e000 v1.04v 1
Copying kernel...mpeg dsp audio in
Calling linux kernel...rsion 4.27 wDentry hash
Buffer cache has
IP Protocols: ICM
i2c_write: device select failedxf8010000 (ir
l. 1
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315 Failed to receive ACK for data!cols for Linux-2.2 (Dag Brattli)stin
ttyS01 at
(release)) #17 Wed Jul 24 18:23:20 BST 2002 select failedol ( revision:Tue May 18 03:1
Processor: Intel StrongARM-1100 revision 11= 16) is a SA1100 UART
ircomm_tty
NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel ce select f
Uncompressing L
Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 )e, booting the kernereceive ACK for data!emote control/panel butt
ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 ) Faile
i2c_write: device select failedk5-np17-empeg51 (mac@aphex) (gci2c_write:
Starting kswapd v 1.58c1 (save to d0004c80
SA1100 serial driver version 4.27 with no serial options enabledmpeg RDS driver i
i2c_write: device select failed(release)) #17
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UARTata!
I2C write failed (
ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UARTto receive ACK for data!(927, 0)
Probing primary inte
Calibrati
i2c: Failed to receive ACK for data!Failed to receive ACK for data! 64k)
i2c_write: device select failedreceive A
i2c: Failed to receive ACK for data!(ordice select failed... done, booti
i2c_write: device select failedmpeg dsp mixer initialised
i2c: Failed to receive ACK for data!ialisede testing by UNIFIX17-empeg51
i2c_write: device select failedould not find CS4231A (vers
I2C write failed (fff, d223)4: Line: device
empeg state
i2c: Failed to receive ACK for data!o d0004f80).rotocol90d)
i2c: Failed to receive ACK for data!inux-2.2 (Dag Brattli)
i2c_write: device select failedplayer (hardware revision 9, se
i2c: Failed to receive ACK for data!ed: 16 RAM disks of 4096K sizeOMM p
i2c_write: device select failed:11:39 1999 )
Calibrati
I2C write failed (927, 0)K for data!
empeg single channel IDE, 20k reser
i2c_write: device select failedterface...l tty driver for IrCO
I2C write failed (8f9, 90d)rite: device select failede
i2c: Failed to receive ACK for data!driveailed (8ef, 800)
i2c_write: device select failedriveACK for data! 64k)
i2c: Failed to receive ACK for data!ice select f
hda: IBM-DJSA-220, ATA
i2c_write: device select failedwith no ser
i2c: Failed to receive ACK for data!y UNIFIX
hda: IBM-DJSA-220, ATA DIS
smc chip id/r
i2c: Failed to receive ACK for data!roto
empeg dsp, UDP, TC
smc9194.c:v0
i2c_write: device select failedrik@vt.edu)initialised384 bhash
i2c: Failed to receive ACK for data!river initialised (f
empeg audio-in
i2c_write: device select failedMC9194: SMC91C94(r:9) at 0x4008
I2C write failed (8f9, 90d)MAC 00:02:d7:22:06:3ote con
i2c: Failed to receive ACK for data!empeg single channel IDE
i2c_write: device select failederface...l tty driver for IrCOM
i2c: Failed to receive ACK for data! PDIUSBD12
i2c_write: device select failedhda2 hda3 hda4Starting kswapd v
i2c: Failed to receive ACK for data!pport initialisen 4.27 with no ser
h
i2c_write: device select failedtem found at block 0
i2c: Failed to receive ACK for data!K: Loading 320 blocks [1
empeg
empeg dsp mixer initialisedvt.edu)init
hda: IBM-DJSA-2
empeg dsp initialisedio-in initial
SM
i2c
Could not find CS4231A (version=80)INTF:TP MEM:6144b MAC 00:02:d7:22
i
empeg usb initialised, PDIUSBD12 id 1012: IBM-DJSA-220, 19077MB w
empeg
empeg state support initialised 0089/88c1 (save to d0005100).ck 0
i2c_write: device select faileder in
empeg RDS driver initialisedm disk... done.
emp
i2
empeg power-pic driver initialised (first boot)FS: Mounted root (ext2 filesys
smc9
i
e000 v1.04o receive
C
aI
Partition check:fff, d223)
hda: hda1 < hda5 hda6 > hda2 hda3 hda4nel...
i2c: Fail
RAMDISK: ext2 filesystem found at block 0.....................
i2c_write: dev
RAMDISK: Loading 320 blocks [1 disk] into ram disk... done.te: device select failed!
i2c
i2c
l.a
empeg-pump v0.03 (19980601)!
i2c_write: dev
Press Ctrl-A to enter pump...hange_root: old root has d_count=1
I2C write failed (8ef, 800)
Trying to unmount old root ... okaya!
Freeing player.cpp : 385:empeg-car 2.00-beta13 2002/07/24. Failed to receive ACK for data!y loop... 207.67 BogoMIPS
i2c: Failed to receive ACK for data!d/07/24.
Page cache hash table entriekernel.
i2c_write: device select failed device select failed..........
i2c: Failed to receive ACK for data!receive ACK for data!y UNIFIX
i2c_write: device select failedr dat
NET4: Li
l.
i2c: Fai
i2c: Failed to receive ACK for data! failed(gcc version 2.95.3
IP Proto
i2c_write: device select failedvice select failed
i2c: Failed to receive ACK for data!onailed:23:20 BST
i2c_write: device select faileddriver failable (96
i2c: Failed
i2c: Failed to receive ACK for data!iled00:49:11 1999 )
i2c_write:
i2c_write: device select failedmpeg-car bootstrap v1.02 200011
i2c_writ
St
i2c_write: device select faileder 4, 64
i2c: Failed to receive ACK for data!let them speak now,ntrie
i2c_write:
i2c: Fail
I2C write failed (8e1, 347)
Vcb: 0x4086d000
#182137 - 30/09/2003 15:08 Re: So what's up with this boot log? [Re: Flawed]
Oh, that looks so unhealthy!!!
#182138 - 30/09/2003 15:37 Re: So what's up with this boot log? [Re: Flawed]
Consider it verified, since these are not supposed to be in the output:
#182139 - 30/09/2003 15:43 Re: So what's up with this boot log? [Re: Flawed]
Dead 74LVX04 probably
#182140 - 30/09/2003 15:43 Re: So what's up with this boot log? [Re: tfabris]
maczrool
Loc: Louisiana, USA
Like I said, in case you missed it on my other post. I will replace that chip for you. Since Empeg support is down for a while, it's your only option right now.
Stu
#182141 - 30/09/2003 19:07 Re: So what's up with this boot log? [Re: maczrool]
Flawed
I sent you a PM.
Thanks!
