#181160 - 25/09/2003 18:14 mlord's upgrader, ported to cygwin
Loc: Los Angeles, CA
download the attached file. the dll is way too big, so you need to extract cygwin1.dll from here. its in /usr/bin. for some reason, cygwin wont recognize the current directory as part of the $path, so you're gonna have to do the following at the command prompt before it works:
set path=%path%;.
ported this really quick to mess with v3alpha3. still had to use the old emplode to recreate my database.
179767-upgrader-win32.zip (56 downloads)
#181161 - 25/09/2003 19:43 Re: mlord's upgrader, ported to cygwin [Re: image]
For those who are wonderin', this is an ethernet UPGRADER for applying .upgrade files to an empeg very quickly and without wiiping out Hijack in the process.. no serial cables required to switch between v2-final and v3-alpha (and back again..).
#181162 - 25/09/2003 19:58 Re: mlord's upgrader, ported to cygwin [Re: mlord]
old thread here, though it seems to be including a number of tangents.
This version is pretty simple to use, but not 100% complete.
--> requires Hijack v328 or newer.
--> you should manually "pause" your player first, or put it in stand-by mode.
--> after "upgrader" completes, you must manually reboot your player.
--> after the reboot, you should run emptool or emplode to rebuild the database
mark, can't you just modify the program to send a SITE command to the ftp daemon to make sure the player is off before uploading the upgrade? i.e.:
make_ftp_cmd(cmd, ftp_user, ftp_passwd, "-Y \"site button top.L"", empeg_host, "/dev/null");
though i'm not sure what the effects would be if the player was off already
#181163 - 25/09/2003 20:41 Re: mlord's upgrader, ported to cygwin [Re: image]
Daria
I have a port to MacOS; I should also post it.
#181164 - 25/09/2003 20:52 mlord's upgrader, ported to MacOS [Re: image]
Daria
Diff in a moment, I need to fetch pristine source to diff against.
179798-upgrader (286 downloads)
#181165 - 25/09/2003 20:55 Re: mlord's upgrader, ported to MacOS [Re: Daria]
Daria
Simple diff.
--- upgrader/upgrader.c Sat Apr 5 09:56:20 2003
+++ upgrader.c Fri Sep 19 15:10:39 2003
@@ -12,7 +12,12 @@
#include <unistd.h>
#include <errno.h>
#include <sys/mman.h>
+#ifdef linux
#include <linux/types.h>
+#else
+typedef unsigned int __u32;
+typedef unsigned char __u8;
+#endif
// Chunk ID definitions from "defines.h", part of a GPL'd UpgradeSplitter package by sven@incase.de
#181166 - 26/09/2003 07:40 Re: mlord's upgrader, ported to cygwin [Re: image]
Hey image, send me any diffs you needed to get upgrader.c to build for cygwin, and I'll incorporate them into the next release.
#181167 - 26/09/2003 10:29 Re: mlord's upgrader, ported to cygwin [Re: image]
Yup. Except the command is "site button=top.L".
Version 0.3 attached -- I used this to apply the v3alpha3 .upgrade without any problems. It also does the auto reboot at the end.
179919-upgrader.tar.gz (60 downloads)
#181168 - 26/09/2003 16:51 Re: mlord's upgrader, ported to cygwin [Re: mlord]
Mataglap
This compiles with no changes under a fresh cygwin install (needed an excuse to get it on the new harddrive anyway), there is a cast warning on line 399, though.
And of course the strip command doesn't work 'cause there's a ".exe" added, but that's not a problem.
Experimentation later.
--Nathan
#181169 - 26/09/2003 17:00 Re: mlord's upgrader, ported to cygwin [Re: Mataglap]
Okay thanks.
I'll turn on -Wall in the next version and fix all of the trivial warnings and stuff.
#181170 - 26/09/2003 17:08 Re: mlord's upgrader, ported to cygwin [Re: mlord]
Mataglap
Oh, well since you're interested:
$ gcc -O -Wall upgrader.c -o upgraderWall
upgrader.c: In function `process_chunk':
upgrader.c:139: warning: implicit declaration of function `strcmp'
upgrader.c:220: warning: unused variable `count'
upgrader.c: In function `main':
upgrader.c:363: warning: implicit declaration of function `exit'
upgrader.c:399: warning: comparison of distinct pointer types lacks a cast
upgrader.c:407: warning: unsigned int format, different type arg (arg 4)
upgrader.c:432: warning: implicit declaration of function `strcat'
upgrader.c:434: warning: implicit declaration of function `system'
upgrader.c:446: warning: unsigned int format, different type arg (arg 4)
upgrader.c:458: warning: unsigned int format, different type arg (arg 4)
upgrader.c:351: warning: unused variable `crc'
upgrader.c:355: warning: unused variable `p'
--Nathan
#181171 - 26/09/2003 17:11 Re: mlord's upgrader, ported to cygwin [Re: Mataglap]
Yeah, I already captured all of those.
Newest version attached.
180085-upgrader.tgz (55 downloads)
#181172 - 26/09/2003 17:25 Re: mlord's upgrader, ported to cygwin [Re: mlord]
Mataglap
$ make
gcc -Wall -O upgrader.c -o upgrader && strip upgrader
upgrader.c:445: warning: long unsigned int format, different type arg (arg 4)
upgrader.c:457: warning: long unsigned int format, different type arg (arg 4)
--Nathan
#181173 - 26/09/2003 17:30 Re: mlord's upgrader, ported to cygwin [Re: Mataglap]
Mataglap
I'll post a cygwin compile of v0.4 or newer either later tonight or tomorrow for everyone who doesn't want to bother with installing cygwin itself.
(Thanks Mark!)
--Nathan
#181174 - 26/09/2003 17:40 Re: mlord's upgrader, ported to cygwin [Re: Mataglap]
Mmm.. odd, no such warning with Linux. No big deal, I'll just add some casting to the next version to eliminate it.
#181175 - 26/09/2003 17:46 Re: mlord's upgrader, ported to cygwin [Re: mlord]
Different GCC version probably. I tried to compile this with MinGW so you don't need to have the huge Cygwin library but can't because of mmap. Could add code to use the native Win32 equivalent but don't have time at the moment but if anybody else wants to I'll tell them how to do it.
#181176 - 26/09/2003 17:52 Re: mlord's upgrader, ported to cygwin [Re: tman]
Well, I suppose the simple mmap() could be replaced with an fstat() malloc() read() sequence instead..
#181177 - 26/09/2003 18:10 Re: mlord's upgrader, ported to cygwin [Re: tman]
Mataglap
The current gcc for cygwin is: gcc version 3.3.1 (cygming special)
--Nathan
#181178 - 27/09/2003 10:51 v.04 (Re: mlord's upgrader, ported to cygwin) [Re: Mataglap]
Mataglap
Here's updater v0.4, compiled for cygwin. I used it about a dozen times to flip back and forth between 2.00final and 3.00alpha3, with no problems.
--Nathan
180185-upgraderV0_4.zip (42 downloads)
#181179 - 01/10/2003 22:43 v.04 (Re: mlord's upgrader, ported to cygwin) [Re: Mataglap]
siberia37
Loc: Tacoma,WA
Try as I might this doesn't work for me. The upgrader flips the player into standy and then skips by everything else really fast. I even tried downloading cygwin in it's entirety and still no luck. It's probably some weird path problem but I have no idea what it could be. What exactly is the upgrader doing when it's doing the pumping partitions? The script does make the zImage file BTW but doesn't get past that.
#181180 - 02/10/2003 00:01 v.04 (Re: mlord's upgrader, ported to cygwin) [Re: siberia37]
try this. its everything u need, even findempeg. just use the up.bat script. there are quirks tho. since you're not in a cygwin bash shell, /dev/null isn't avaliable, so you wont auto-standby nor reboot. i probably can change it to ^Z but i'm lazy. also, findempeg has trouble when you have two empegs. modify the up.bat to accept a serial# if thats the case. put latest cygwin1.dll in the unzipped folder.
#181181 - 02/10/2003 00:02 v.04 (Re: mlord's upgrader, ported to cygwin) [Re: image]
didn't seem to upload the attachment. here it is again
181060-upgrader-v04.exe (100 downloads)
#181182 - 02/10/2003 07:10 v.04 (Re: mlord's upgrader, ported to cygwin) [Re: image]
siberia37
Loc: Tacoma,WA
Thanks I'll try it again.. I was running from the cygwin bash shell when trying it last time btw, but it could be it wasn't working right. I'll let you how it works out know thanks!
#181183 - 02/10/2003 08:57 v.04 (Re: mlord's upgrader, ported to cygwin) [Re: siberia37]
thinking about it, you most likely didnt have the ncftput (sp?) package downloaded.
#181184 - 02/10/2003 12:09 v.04 (Re: mlord's upgrader, ported to cygwin) [Re: image]
siberia37
Loc: Tacoma,WA
I had ncftpput, downloaded about three different version of it.. at least one of which was compiled with cygwin, same thing with gunzip. Very weird.
#181185 - 24/12/2003 13:07 mlord's upgrader, ported to MacOS, works now [Re: Daria]
Daria
Here's the revised diff
193869-diff (252 downloads)
#181186 - 24/12/2003 13:09 Re: mlord's upgrader, ported to MacOS, works now [Re: Daria]
Daria
And the revised binary
193870-upgrader (292 downloads)
#181187 - 24/12/2003 14:07 Re: mlord's upgrader, ported to MacOS, works now [Re: Daria]
Hi
Your diffs don't apply cleanly to my current souce -- could you post the entire upgrader.c file that you have now, please.
#181188 - 24/12/2003 14:26 Re: mlord's upgrader, ported to MacOS, works now [Re: mlord]
Daria
Absolutely
193888-upgrader.c (175 downloads)
#181189 - 24/12/2003 15:49 Re: mlord's upgrader, ported to MacOS, works now [Re: Daria]
Okay, here is upgrader.c version 0.6 -- my latest with your latest sync'd in.
193910-upgrader.c (215 downloads)
