#181096 - 25/02/2004 15:52
Re: V3 alpha bugs
[Re: russmeister]
Loc: Lochcarron and Edinburgh
When you are deleting playlists, there's a checkbox to delete the song as well, right?
That's not how it works in JEmplode, IIRC. There's a checkbox for "Remove completely" which kills all references to the playlist or tune, but I believe that the children will be orphaned when you remove their last containing playlist.
You can do a search on refs=0 to find your orphans.
#181097 - 25/02/2004 15:59
Re: V3 alpha bugs
[Re: tms13]
No, remove completely is supposed to remove the tune itself, just like Emplode.
#181098 - 25/02/2004 21:39
Re: V3 alpha bugs
[Re: Daria]
Loc: Los Angeles, CA
couple of bugs:
first, before i've complained about OGG files making the load up to the 7s, making it practically impossible to do anything after (slow menus, song load, etc). I finally isolated it to VISUALS. i turned the selected visual to OFF, and its at around 1.0 - 1.5 load at -q7. now, here's the kicker. INFO mode didn't have to be showing visuals for it to be eating up cpu time. I could have it at the Track Info screen, and it would be at such a high load, until i change it to off. this by design? I mean, does the player have to be processing the visual even if nothing is showing? can't you autoswitch it to OFF if its a non-visual INFO screen? how come i never noticed this until i played with OGGs?
secondly, i have some audio books that i compressed on -q0 mono, which turned out to be 19kbps. these OGG files do not seek whatsoever in v3a7. not sure if they did in any other alpha.
#181099 - 26/02/2004 05:46
Re: V3 alpha7 bugs
[Re: genixia]
Loc: Hamburg, Germany
I'm just noticing the same effect: alpha7 is 'too gapless', a very short part of music is missing between tracks.
Which of course is still much better than a gap...
Also, as somebody mentioned before, special characters like in Bj  rk are not handled correctly in emplode (which is pretty bad as I have those all over the place..lots of german stuff..).
When adding new tracks everything seems to be right, but after emplode (2.00 and 2.10) downloads the database from the empeg those characters go nuts somehow.
I noticed this behaviour in v3alpha3 already.
#181100 - 26/02/2004 08:26
Re: V3 alpha bugs
I thought we were talking about removing playlists here, not tunes?
#181101 - 26/02/2004 08:33
Re: V3 alpha bugs
[Re: image]
Have you tried the latest Hijack with this? Any better?
#181102 - 26/02/2004 16:04
Re: V3 alpha7 bugs
[Re: pupvogel]
Or in the BBS apparantly
#181103 - 26/02/2004 18:50
Re: V3 alpha7 bugs
[Re: genixia]
I thought it was a particularly apt transliteration.
#181105 - 27/02/2004 01:29
Re: V3 alpha bugs
Have you tried the latest Hijack with this? Any better? nope, the one i have on my empeg is 374. been pretty hectic, and haven't been able to just recompile a new ext3 kernel in the last week. will try tommorow.
#181106 - 27/02/2004 16:03
Re: V3 alpha7 bugs
LOL. Although true, I think that it's due to some strange codebase effect. No matter how I tried, I couldn't get the BBS to convert : o to  without spacing between the "j" and ":", whereas the original post has no spacing.
#181107 - 28/02/2004 12:50
Re: V3 alpha7 bugs
[Re: genixia]
#181108 - 28/02/2004 16:02
Re: V3 alpha7 bugs
[Re: drakino]
Hmm. Maybe not then. So how did he do it??
Bj:ork
#181109 - 28/02/2004 16:09
Re: V3 alpha7 bugs
[Re: genixia]
Bj  rk? If you intentionally put in the image tag then you can do it without the space.
#181110 - 28/02/2004 16:14
Re: V3 alpha7 bugs
[Re: genixia]
I typed this out:
Shift-B
j
Option-U
o
r
k
Looks like my browser is in ISO-Latin-1 encoding mode. This being on OS X. I'm not sure what the ALT-code equivalent is on the PC.
#181111 - 28/02/2004 16:59
Re: V3 alpha7 bugs
[Re: tman]
Doh! Overlooking the bloody obvious again.
#181112 - 02/03/2004 01:37
Re: V3 alpha bugs
Have you tried the latest Hijack with this? Any better? nope, just tried 379 and its the same behavior. on the same ogg file, it rockets to 7 if i'm showing the SpectroLog 128 visual, 4 if its on the visual but track mode, and 1.5 when track + visual off.
#181113 - 14/07/2004 21:27
Re: V3 alpha bugs
[Re: boxer]
Loc: Oxford, UK
4. I've given up trying to figure out whether the RDS issues are the Empeg, or the transmitted signal - it was never a great piece of technology! Since installing 3.00 I haven't had a single traffic announcement, but I seldom got them on 2.00.
Boxer: I remember the meticulous investigations you made previously on this subject.. Can you, or perhaps anyone else with v3alpha8, comment upon whether this (TA) and the AF and the right/left-buttom freq searching problems have been resolved in the new release(s)?
I understand that the freq searching was an acknowleged bug but the AF and TA problems, and more importantly to me the AF, were considered by the Cambridge team to be working properly in previous releases?
Edited by Rue (14/07/2004 21:31)
