#178840 - 11/09/2003 10:22 Tuner, sony stalk remote issue
cookie_77
Hi.
I have a Pcats tuner and sony RMX4S remote.
The remote does work ok, but the empeg does not react to the button presses in a sutible time period , some times taking 20secs to do a command.
Any way to speed this up?
C.
#178841 - 15/09/2003 07:29 Re: Tuner, sony stalk remote issue [Re: cookie_77]
cookie_77
Anyone at least confirm how yours works.
C.
#178842 - 15/09/2003 08:40 Re: Tuner, sony stalk remote issue [Re: cookie_77]
Works instantaneously, or near enough.
MOST of the time, that is.
There have been reports in the past of the buttons and the stalk suffering longish delays within the first minute after powerup/resume in some situations. Dunno what the resolution was.
#178843 - 16/09/2003 06:05 Re: Tuner, sony stalk remote issue [Re: mlord]
cookie_77
Thanks.
Works fine most of the time on the tuner , but on the player is normaly slow , some times it will work o and then if i skip say 10 songs it starts to slow down.
I am thinking i might just sell the tuner as the stalk control was the reason i got , if i had know it was as flakey as it is i would not have got it.
C.
#178844 - 16/09/2003 10:19 Re: Tuner, sony stalk remote issue [Re: cookie_77]
siberia37
Loc: Tacoma,WA
Do you have any heavy userland apps running in the background (e.g. GPSApp or Roadmapgpsapp)? These probably take up buffer space so after skipping 10 songs the empeg won't respond to commands until it refills it's buffers.
#178845 - 16/09/2003 10:52 Re: Tuner, sony stalk remote issue [Re: siberia37]
cookie_77
Only have empacman running as a init script.
I do have an additional buffer section in my ini file.
C.
#178846 - 16/09/2003 10:57 Re: Tuner, sony stalk remote issue [Re: cookie_77]
Try removing those temporarily and see if it solves your tuner stalk delay problem.
#178847 - 16/09/2003 15:30 Re: Tuner, sony stalk remote issue [Re: tfabris]
cookie_77
Will Do.
C.
#178848 - 08/10/2003 09:19 Re: Tuner, sony stalk remote issue [Re: cookie_77]
cookie_77
Back on this again.
Tried both my players with just V2 on them and both have slow down periods when responding to button presses.
C.
#178849 - 08/10/2003 10:10 Re: Tuner, sony stalk remote issue [Re: cookie_77]
Have a look at this thread...
#178850 - 08/10/2003 10:36 Re: Tuner, sony stalk remote issue [Re: tfabris]
cookie_77
Not sure that that realy helps me much as mine is empeg tuner remote.
I do have 2 stereo's but have only had the battery warning once.
C.
#178851 - 08/10/2003 10:38 Re: Tuner, sony stalk remote issue [Re: cookie_77]
So is Tod's. Read carefully, we're reporting the exact same problem.
#178852 - 08/10/2003 10:55 Re: Tuner, sony stalk remote issue [Re: tfabris]
cookie_77
What is a soundgate then?
Also found this thread
http://empeg.comms.net/php/showflat.php?Cat=&Board=empeg_general&Number=158392&page=&view=&sb=&o=&vc=1
Other things...
I also get the same style of slow response from the http interface on just the player so the whole stalk thing might be a bit of a fish.
I also get the same thing from your face program.
Sort of not related but do you have a port of your face progam for pocket PC ?
C.
#178853 - 08/10/2003 11:54 Re: Tuner, sony stalk remote issue [Re: cookie_77]
Ah, that's very telling. It means something fishy is going on with your player. You're right, it's got nothing to do with the stalk.
Please post your config.ini and a boot log.
No, I don't have a pocketPC version. Do pocketPCs have ethernet?
#178854 - 08/10/2003 12:16 Re: Tuner, sony stalk remote issue [Re: tfabris]
cookie_77
Will do.
Pocket Pc will take ethernet and 802.11* wireless cards.
If it was possible that would make the "Empeg hidden under seat" issue not a problem.
Will post the configs later.
C.
#178855 - 09/10/2003 15:15 Re: Tuner, sony stalk remote issue [Re: cookie_77]
cookie_77
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v340 (root@ibbm) (gcc version 2.95.3 20010315 (release)) #2 Wed Jun 18 18:40:14 EDT 2003
empeg-car player (hardware revision 9, serial number 30102889)
Command line: mem=16m
Memory: 15016k/16M available (976k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005c80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:49
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init
empeg-preinit starting...
empeg-preinit complete
empeg init 0.8
Mounting proc
No secondary hard disk
Starting player
hijack: removed menu entry: "Tuner RDS Control"
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
empacman running as pid 15
Mounting /programs0... mount: can't find /programs0
in /etc/fstab or /etc/mtab
Vcb: 0x4086d000
Edited by cookie_ARM (09/10/2003 15:21)
#178856 - 09/10/2003 15:18 Re: Tuner, sony stalk remote issue [Re: cookie_77]
cookie_77
[Options]
Name=Robs RioCar
[User Info]
Email=******************
Phone=****************
Name=******************
[Network]
Gateway=0.0.0.0
Netmask=255.0.0.0
IPAddress=10.0.0.79
DHCP=1
[power]
off_timeout=20000
[display]
play_count=1
visual_names=0
caching=0
[synchronise]
seq_num=119
[sense]
muteaction=0
mute=-1
[hush]
hushpercent=20
[volumecap]
enabled=0
[kenwood]
disabled=0
[ramp]
disabled=1
[menu]
quit=0
sort_playlist=1
[controls]
stalk_side=left
[output]
notify=1
[serial]
car_rate=115200
[tuner]
region=europe
[aux]
source=
title=
artist=Playing CD's
[wendy]
flag_amount=0
[custom]
wendy=
[searches]
amount=0
[VisualFavourites_AM]
count=0
[VisualFavourites_AUX]
count=0
[VisualFavourites_DSP]
count=0
[VisualFavourites_FM]
count=0
[hijack]
dc_servers=1
[shuffle]
deduplicate=1
#178857 - 13/10/2003 14:34 Re: Tuner, sony stalk remote issue [Re: cookie_77]
cookie_77
Anyone?
C.
