#178618 - 10/09/2003 04:19
Suggestion for FAQ
Loc: Amersfoort, The Netherlands
I have a suggestion for the networking and home connections FAQ. Where it talks about connecting the empeg to your PC with a crossover Ethernet cable, I would recommend buying a normal cable plus a crossover adapter. That way, you can reuse the cable if you later decide to buy a hub.
#178619 - 10/09/2003 09:58
Re: Suggestion for FAQ
[Re: Captain_Chaos]
Interesting suggestion, but...
a) Don't want to muddy the waters,
b) I clearly state that crossover connection is not recommended in the first place, and
c) Crossover adapters are even more rare (hard to find) than crossover cables.
#178620 - 10/09/2003 10:14
I didn't even know they existed. =]
#178621 - 10/09/2003 10:27
[Re: loren]
They are easy to make if you have a crimper and a punchdown tool. Just get a RJ45 jack and a RJ45 plug and about 2 inches of wire and wire up each side correctly.
#178622 - 10/09/2003 10:44
[Re: JBjorgen]
They are easy to make if you have a crimper and a punchdown tool. Just get a RJ45 jack and a RJ45 plug and about 2 inches of wire and wire up each side correctly. Surely anyone who knows how to do that will get as far as "crossover cable required" and work the rest out for themselves? If they were even reading a FAQ on networking in the first place?
#178623 - 10/09/2003 13:28
Oh well, just a random thought I had while browsing the FAQ...
#178624 - 10/09/2003 14:03
[Re: peter]
uh...right.
/me slinks back into his cave.
#178625 - 10/09/2003 14:20
[Re: loren]
I didn't even know they existed. =] My favorite "network thing I didn't know existed until recently" was the two-way splitters. Something we'd been wiring here by hand for a long time and is available as a simple plug-in dealie.
A cat-5 cable has eight wires. Only four of those wires are used for ordinary LAN communication.
So if you want, you can put one of these "splitters" on one end of a cable run (say, the single port at a guy's desk) and put another splitter at the other end of the cable run (say, just before the hub) and you get two network plugs for the price of one.
You still need two ports on the hub, what you're saving is a second cable-run.
Dunno how well it works for 100 megabit, but we've been using it successfully for 10 megabit for years now.
#178626 - 10/09/2003 14:28
[Re: JBjorgen]
Loc: Atlanta, GA
my biggest problem with crossover cables is that I have a bunch that look exactly like regular cables. So whenever I'm re-connecting out of my stock I can't alwasy be sure I've got the right kind of cable. But then that's my own fault for being disorganized.
#178627 - 10/09/2003 14:33
[Re: JeffS]
Just compare the color of the wires on the first pin on each side. Assuming that the cable works at all, same means straight, different means crossover.
#178628 - 10/09/2003 14:45
Loc: Atlanta, GA
Just compare the color of the wires on the first pin on each side. Oh right . . . Hadn't thought of that. And I've even built one before.
#178629 - 10/09/2003 17:22
This should work for 100 as well. Gigabit is where it needs all 8 wires, and all my drops in the house are ready for gigabit, minus one. I found a bad run of cable, and ended up using it anyhow since the repair people left it in the wall. It had 2 pairs not functioning, so I used the other two, and did use it at 100 for a time. It is now marked for my empeg at my desk though, so it is only running at 10.
#178630 - 10/09/2003 17:27
[Re: drakino]
My only concern is crosstalk if you've got two runs of 100 sending saturated data at the same time across the same wire set.
#178631 - 10/09/2003 20:24
Loc: Australia
I've been running a 100 and a 10 over 30 metres of cable without any problems.
#178632 - 10/09/2003 20:38
Loc: New Orleans, LA
No issues here. I do it all the time. We also have a few that split it to Cat5 and 2 pots lines. Again, with no issues.
#178633 - 10/09/2003 20:53
[Re: drakino]
Loc: NH USA
This and this came in to the office today. Moving from 100bT unmanaged hubs (3 of them). The Dell was only $800 for 12 ports worth of 1000bT ($400 rebate). Woot!
-Zeke
WWFSMD?
#178634 - 10/09/2003 21:19
Not quite. Just before I left for the NY/NJ empeg meet this spring I tossed what I thought was a crossover cable into my bag, and grabbed my laptop, just in case someone had a use for it.
Sure enough, someone wanted to upgrade to 2.0final and HJ. Can't remember who it was, but anyway. I discovered that my bag contained the straight cable that it always did, and this strange bastard cable - neither of which would work (obviously).
I've since discovered that Cisco management/console cables are sometimes implemented using a 9 pin D to RJ45 adapter and regular cat 5 cable... the cat 5 is wired so that one end is the mirror image of the other, and is known (to Cisco anyway) as a Rollover cable. And that is what I had in my bag.
#178635 - 10/09/2003 21:56
[Re: genixia]
doesnt work for me either. im color blind. takes me an hour to make a crossover cable with that stupid translucent insulation on some of the cables out there
#178636 - 10/09/2003 23:28
[Re: peter]
Hmm... I got to the part about "crossover cable" and said "Hmm... whatever." My hub auto-detects crossover cables, and Does The Right Thing. Half the cables I have are crossover cables scammed from my previous place of employ. (I had them with their permission, but never gave them back when they layed me off.)
#178637 - 10/09/2003 23:36
[Re: Captain_Chaos]
I wish there was a cross over version of these
#178638 - 11/09/2003 04:19
And if you have an old house, where squeezing in extra runs is hard or impossible, you definitely appreciate the saving.
I want as far as actually wiring up the terminations in the wiring cabinet as 2 x 4 wire connectors for each run.
#178639 - 11/09/2003 08:17
[Re: genixia]
Not quite. Well, I meant a cable that works for ethernet, but I do suppose that assumes something not easily checked.
BTW, rollover cables are fairly common. You'll find them connected to every telephone. At least each one with a cable.
Also BTW, have you noticed that electronics retailers have decided to divide phones into three categories: corded, cordless, and wireless? WTF is the difference between cordless and wireless (in reality)? Arbitrary distinctions like that are almost less than useless.
#178640 - 11/09/2003 09:46
Loc: NH USA
Bitt, I'd say the distinction is how far you can move before your signal cuts out. If it's cordless, 50 feet. If it's wireless, at least 300 feet.
-Zeke
WWFSMD?
#178641 - 11/09/2003 09:49
[Re: Ezekiel]
Loc: Atlanta, GA
I think the point he's trying to make, is that given the words "cordless" and "wireless" there's not obvious distinction. "Cordless" means "the phone has no cord" and "wireless" means "the phone has no wire". The problem is that both statements are true in both cases.
#178642 - 11/09/2003 09:49
[Re: Ezekiel]
So one's analogue tech and the other is digital?
#178643 - 11/09/2003 09:53
[Re: tman]
Cordless means you must wear denim. Wireless means if you twiddle the knobs you get the Home Service. Simple, really.
#178644 - 11/09/2003 10:58
[Re: JeffS]
Loc: NH USA
Ferretboy- I got the point. Did you get that my cell service sucks?
-Zeke
ps: Tman - the distinction is that wireless means cellular and cordless means your typical analog, 900 Mhz, 1.2Ghz or 5 Ghz residential cordless phone with one base station. It is rather a Stephen Wright -esque distinction.
Edited by Ezekiel (11/09/2003 11:02)
WWFSMD?
#178645 - 11/09/2003 11:27
[Re: Ezekiel]
Loc: Atlanta, GA
Um no. I was too busy being an anal know-it-all.
I get it know though
#178646 - 11/09/2003 11:29
[Re: Ezekiel]
Ahh okay. Cordless == Wireless over here from what I can tell. They're all residential cordless phones.
Cellular would be a mobile here
