#175495 - 17/08/2003 03:15 Trouble with hard disc -> Any Help?
fossi
Loc: Germany
I have some trouble with my hard disc. After a "Contact support" problem I installed the disc builder image, run it, reinstalled the empeg 2.00b13 sw with hijack 3.40, preinit, mkprgpt and so on. But the hard disc does not work correct. See the follwing boot sequence:
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v340 (root@ibbm) (gcc version 2.95.3 20010315 (release)) #2 Wed Jun 18 18:40:14 EDT 2003
empeg-car player (hardware revision 9, serial number 40104354)
Command line: mem=16m
Memory: 15016k/16M available (976k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004a80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHN2200AT, ATA DISK drive
hda: FUJITSU MHN2200AT, 19077MB w/2048kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:11:02
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... okay
Freeing unused kernel memory: 4k init
empeg-preinit starting...
Using /programs0/preinit.d as startup script directory
empeg-preinit complete
empeg init 0.8
Mounting proc
No secondary hard disk
Starting player
hijack: removed menu entry: "Tuner RDS Control"
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
M10empacman is not marked as executable. Not executing.
M20emptris is not marked as executable. Not executing.
M40empan is not marked as executable. Not executing.
M60viewer is not marked as executable. Not executing.
M70empwake is not marked as executable. Not executing.
Vcb: 0x4086d000
Some files are not accessable (error: read-only) although I have set rw. Scripts are not executed, ...
When forcing a check media with jemplode I get the following:
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
VM: do_try_to_free_pages failed for kswapd...
VM: do_try_to_free_pages failed for fsck.ext2...
VM: killing process fsck.ext2
buffermem : 331776
page_cache_size : 307
nr_free_pages : 32
num_physpages : 4096
When pressing CTRL+T during boot I get all O.K. with the hardware.
When trying to follow the hand work file check (as mentioned in the FAQ) I get errors with /dev/hdc4.
When setting the drive to rw I get an read-only error while accessing for instance config.ini, when setting the drive to rwm it works.
Does anybody have an idea with that problem?
Fossi
#175496 - 17/08/2003 03:40 Re: Trouble with hard disc -> Any Help? [Re: fossi]
mtempsch
Vcb: 0x4086d000
Are they executeable? ls -l should show ..rwx... in the permissions if they're rEADABLE, wRITEABLE and ExECUTABLE. Try 'chmod 777 [filename'] to set them read/write/execute-able...
IIRC this is normal - it looks for the /etc/mtab file for which filesystems that are mounted, but the empeg doesn't have/use that file.
buffermem : 331776
nr_free_pages : 32
This might be an issue with swap space - not sure... Search the FAQ for 'swap'
Do you have two drives? According to the boot log only one drive /dev/hda is found. You can't fsck a drive you don't have or the system for some reason doesn't see.
I believe the config file lives on the music partition, which is mounted red/write by the rwm command, the rw command only mounts the system partition as read/write.
#175497 - 17/08/2003 04:58 Re: Trouble with hard disc -> Any Help? [Re: mtempsch]
fossi
Loc: Germany
Thanks for the response.
The scripts M10, M20, ... are not marked as executable and should not. But the scripts M30, M50 and N10 are marked as executable (chmod 755) but are not executed.
My configuration is a single hard disc.
With the swap file I have no idea, found nothing useful in the FAQ.
When trying to access files in the programs0 folder whether rwm nor rw helps. The error message is alsways read-only.
Anything else I could try?
#175498 - 17/08/2003 06:06 Re: Trouble with hard disc -> Any Help? [Re: fossi]
Where is your programs0 folder?
#175499 - 17/08/2003 06:11 Re: Trouble with hard disc -> Any Help? [Re: pgrzelak]
fossi
Loc: Germany
I have used mkprgpt to create programs0, so it is at /dev/hda2:
mount -n -r -t ext2 /dev/hda2 /programs0
Fossi
#175500 - 17/08/2003 06:16 Re: Trouble with hard disc -> Any Help? [Re: fossi]
Hmmm... Why does that mount -r bother me... I do not have a man page handy - is that a read only flag?
#175501 - 17/08/2003 06:24 Re: Trouble with hard disc -> Any Help? [Re: pgrzelak]
Yes.
#175502 - 17/08/2003 06:27 Re: Trouble with hard disc -> Any Help? [Re: fossi]
I don't see any messages indicating hard disk problems in that log.
But it does look like "low memory" issues or something. Some app you have installed is taking too much memory away from the player. There's a config.ini parameter for "reserved cache" or some such thing, described in the FAQ, which will likely help here.
#175503 - 17/08/2003 07:06 Re: Trouble with hard disc -> Any Help? [Re: mlord]
fossi
Loc: Germany
Now I set ReserveCache=30 and tried again.
The bootlog:
e000 v1.04
Copying kernel...
empeg state support initialised 0089/88c1 (save to d0005980).
Partition check:
Press Ctrl-A to enter pump... hange_root: old root has d_count=1
empeg init 0.8
Mounting proc
Starting player
Using non-standard cache size 104 (adjustment 30)
Vcb: 0x4068d000
The log while trying to force check media:
Vital Signs says:
Cac: 1223,Buf:81,Fre:102
The problem remains. Scripts don't start, while trying to remove a file in programs0 directly after rw and rwm I get the error:
empeg:/programs0# rm gpsapp
rm: remove write-protected file `gpsapp'? y
rm: cannot unlink `gpsapp': Read-only file system
Fossi
#175504 - 17/08/2003 07:08 Re: Trouble with hard disc -> Any Help? [Re: fossi]
Okay.
/programs0 is a filesystem that you created. If you look carefully at rw and rwm, they only cover the root and music partitions (unless you modified them). That is your likely problem for the read only aspect of things.
#175505 - 17/08/2003 08:44 Re: Trouble with hard disc -> Any Help? [Re: pgrzelak]
fossi
Loc: Germany
O.K., that worked (with rwp) - but I don't understand why it worked before with rw ...
But what does not work is still the executing of preinit scripts although they are located right and marked executable.
Any idea?
Fossi
#175506 - 17/08/2003 10:14 Re: Trouble with hard disc -> Any Help? [Re: fossi]
Do me a favor. Go to /programs0, and do an "ls -al" and paste the results. Also, paste one of the scripts (if they are ascii). Thanks.
#175507 - 17/08/2003 11:17 Re: Trouble with hard disc -> Any Help? [Re: pgrzelak]
fossi
Loc: Germany
Here we go:
Programs0:
empeg:/programs0# ls -al
total 344
drwxr-xr-x 7 0 0 1024 Aug 17 16:42 .
drwxr-xr-x 17 502 220 1024 Aug 17 15:17 ..
drwxr-xr-x 2 0 0 1024 Jan 19 2003 CVS
-rw-r--r-- 1 0 0 61925 Jan 19 2003 empacman
-rwxr-xr-x 1 0 0 25468 Jan 19 2003 empsoko
-rwxr-xr-x 1 0 0 10336 Jan 19 2003 emptris
drwxr-xr-x 2 0 0 1024 Jan 19 2003 emptriv
-rwxr-xr-x 1 0 0 130574 Jan 19 2003 empwake
-rwxr-xr-x 1 0 0 51768 Aug 17 16:42 gpsapp
-rwxr-xr-x 1 0 0 26192 Mar 2 17:01 gpsd
-rwxr-xr-x 1 0 0 89 Mar 2 22:07 gpsdd
-rwxr-xr-x 1 0 0 3164 Feb 8 2003 incar
drwxr-xr-x 2 0 0 12288 Jan 19 2003 lost+found
-rwxr-xr-x 1 0 0 3204 Mar 26 18:26 mini_ifconfig
drwxr-xr-x 2 0 0 1024 Mar 2 16:10 preinit.d
drwxr-xr-x 3 0 0 2048 Jul 27 09:10 routes
-rwxr-xr-x 1 0 0 9048 Jan 19 2003 viewer
subdirectory preinit.d:
empeg:/programs0/preinit.d# ls -al
total 10
drwxr-xr-x 2 0 0 1024 Mar 2 16:10 .
drwxr-xr-x 7 0 0 1024 Aug 17 16:42 ..
---------- 1 0 0 62 Jan 19 2003 M10empacman
---------- 1 0 0 60 Jan 19 2003 M20emptris
-rw------- 1 0 0 136 Jan 19 2003 M30emptriv
---------- 1 0 0 56 Jan 19 2003 M40empan
-rwxr-xr-x 1 0 0 189 Jan 19 2003 M50gpsapp
---------- 1 0 0 58 Jan 19 2003 M60viewer
---------- 1 0 0 60 Jan 19 2003 M70empwake
-rwxr-xr-x 1 0 0 48 Jan 19 2003 N10telnetd
and the script M50gpsapp:
#!/bin/bash
#Could also be Garmin, TSIP, TAIP
#Most GPS's understand NMEA.
PROTOCOL=NMEA
[ -x /programs0/incar ] && /programs0/incar || exit
[ -x /programs0/gpsapp ] && /programs0/gpsapp
Fossi
#175508 - 17/08/2003 11:44 Re: Trouble with hard disc -> Any Help? [Re: fossi]
Give this a shot:
(make your programs0 read/write)
cd /programs0/preinit.d
chmod 777 M*
#175509 - 17/08/2003 18:46 Re: Trouble with hard disc -> Any Help? [Re: pgrzelak]
genixia
No, don't do that - it'll increase your boot time somewhat as all the preinit scripts load, check whether their application exists and then bail.
preinit is clever enough to ignore unexecutable scripts, as shown by your log. At one point it wasn't - I assume that your running a recent version. I don't think that it has changed in ages though. so you probably are. We use permissions to decide what is going to run - this made it possible for mkprgpt to provide a bunch of scripts for various applications that could then be tweaked fairly easily, without anyone having to vi them from scratch. I would suggest that the M30emptriv permissions are wrong (based upon a previous post listing which scripts should execute) and need to chmod'd;
chmod 755 /programs0/preinit.d/M30emptriv
Aside from that, nothing in the log suggests that N10telnetd or M50gpsapp aren't executing. The log lists those scripts that didn't execute, and those weren't in that list.
Now, if you're testing in AC mode then gpsapp won't start. the 'incar' application is used to ensure that gpsapp only starts in DC mode. So you'll need to force DC power to see GPSapp on your hijack menu.
I suspect that telnetd is running. Why do you think it isn't?
#175510 - 17/08/2003 21:17 Re: Trouble with hard disc -> Any Help? [Re: genixia]
fossi
Loc: Germany
Yep!
That was it. GPSapp does in fact only run when DC mode is forced (Didn't found it documented).
Telnet now also starts. After rebuilding my hard disc I didn't run "devs" which prevents telnetd from starting - this was documented, so my fault.
So both apps run again, many thanks for all your help.
The low memory issue was a very interesting one. Before rebuilding my player I had some mysterious effects which are reported sometimes here, like hang-ups of gpsapp in the long-run. Probably these effects are somehow linked ... we will see.
Fossi
