Page 2 of 2 < 1 2
#175116 - 12/08/2003 19:06 Re: Other embargo lifted!!! [Re: image]
mschrag
Loc: Richmond, VA
I nominate that as the worst idea ever posted.
#175117 - 12/08/2003 19:08 Re: Other embargo lifted!!! [Re: tfabris]
Loc: Los Angeles, CA
will RMM be compatible with the empegs? is dupe checking via the 64k chunks implemented there as well?
are nested playlists in the works for the karma?
how about an autosync to hard drive feature?
EDIT: in my experience, i didnt like the way that the current RMM for my s10 didnt allow for drag-and-drop support. is this implemented in 2.0?
Edited by image (12/08/2003 19:21)
#175118 - 12/08/2003 19:15 Re: Other embargo lifted!!! [Re: mschrag]
hahah. well, how else are lazy ppl who can't cut and paste going to spread the word and kill off misinformation? =)
#175119 - 12/08/2003 19:21 Re: Other embargo lifted!!! [Re: image]
"will RMM be compatible with the empegs?"
From what I understand, the eventual goal is that Empeg will run off of the same protocol as the Karma ("protocol2"), which will be nice
#175120 - 12/08/2003 19:24 Re: Other embargo lifted!!! [Re: image]
It's a very bad idea for more than one reason. The main one would be that since this BBS is hosted for free, the actual owners of the server wouldn't take too well to it being tested against the slashdot effect. Another is that you'll end up with a huge number trolls on here.
#175121 - 12/08/2003 19:45 Re: Other embargo lifted!!! [Re: tman]
goooberhead
Loc: Your mom's bed
K4rM4 $Ux.
It dO35N't 5UPPOR+ OptimFROG
#175122 - 12/08/2003 19:58 Re: Other embargo lifted!!! [Re: tman]
mschrag
Loc: Richmond, VA
My impression is that this is not a terribly high priority (for obvious reasons), but since no other Rio products have a GUI like Emplode, most likely the only future for continued Empeg support is to transition us over to a common platform (i.e. RMM).
#175123 - 12/08/2003 20:29 Re: Other embargo lifted!!! [Re: mschrag]
cushman
Loc: Erie, CO
Mike, this is great news. I'm happy to see that Jemplode development will continue! I'm looking forward to your next release.
Mark Cushman
#175124 - 12/08/2003 21:09 Re: Other embargo lifted!!! [Re: cushman]
PeterDLai
Loc: San Diego, CA, USA
Want.. more.. pictures..
#175125 - 12/08/2003 21:09 Re: Other embargo lifted!!! [Re: PeterDLai]
PeterDLai
Of the box too..
#175126 - 12/08/2003 22:57 Re: Other embargo lifted!!! [Re: image]
Currently it is not. Maybe someday.
Currently not. Maybe someday.
Not sure exactly what you mean, but I think that's supposed to be implemented already.
There are some things you can drag and drop and others you can't. Not sure which specific thing you want to drag and drop?
#175127 - 12/08/2003 23:55 Re: Other embargo lifted!!! [Re: tfabris]
I really hope someday soon, as, well, this is still the feature that is most useful to me on a device that may hold my entire music collection. Other then that, very cool from what I have seen so far. Now to decide when I need one for music while riding the motorcycle.
#175128 - 13/08/2003 02:27 Re: Other embargo lifted!!! [Re: tman]
Yeah. What he said.
#175129 - 13/08/2003 02:29 Re: Other embargo lifted!!! [Re: msaeger]
How does Rio Music Manager compare to emplode. Does it work as good for changing track info.
The tagging UI is the same as in emplode -- I lifted the code directly. Moreover, it allows you to use the same UI for editing the tags on files on your PC (in your Media Library).
Does the karma have it's own database like the empeg or does it just use the tags.
It has its own database. It's not the same as the empeg's database. It supports UTF8 and is better optimised for memory usage.
#175130 - 13/08/2003 02:43 Re: Other embargo lifted!!! [Re: image]
You can drag files from the Media Library window to the portable device window. You can drag files from Windows Explorer to the portable device window. You can drop files on the portable icon on the sidebar. See the screenshot.
You can also use drag and drop for playlist creation.
#175131 - 13/08/2003 02:44 Re: Other embargo lifted!!! [Re: Roger]
Attach smaller picture.
#175132 - 13/08/2003 03:49 Re: Other embargo lifted!!! [Re: Roger]
Damn. I fall asleep for the evening, and look what happens! Thread explosion!
#175133 - 13/08/2003 05:56 Re: Other embargo lifted!!! [Re: mschrag]
Jerz
Loc: Jesusland
I may be able to have jEmplode control both Empeg and Pearl together (perhaps sync between them also)
Now that would be cool...
Glad to see you're onboard with the empeg team with this
#175134 - 13/08/2003 08:36 Re: Other embargo lifted!!! [Re: tfabris]
i was thinking about being able to specify a root directory in RMM, and whenever you add/delete files/folders to the root, at sync up the changes will be reflected with the karma. also, if you make changes to the tags on the files, then will RMM pick those changes up and transmit them to the karma?
#175135 - 13/08/2003 08:43 Re: Other embargo lifted!!! [Re: Roger]
cool. that was what i was looking for. i found it easier to use windows search rather than navigate using the My Computer tab in RMMv1.6.
#175136 - 13/08/2003 09:30 Re: Other embargo lifted!!! [Re: image]
Yes.
No.
#175137 - 13/08/2003 09:31 Re: Other embargo lifted!!! [Re: image]
That's because you're not supposed to use the My Computer tab (now a separate window). You're supposed to use the database. It has searching now, too.
#175138 - 13/08/2003 11:45 Re: Other embargo lifted!!! [Re: Roger]
DLF
Loc: Colorado, N.A.
That interface looks very good, Roger. And do I see that RMM 2.0 also works with the S players? Those folks will be chomping at the bit for a 2.0 download, won't they?
-- DLF
#175139 - 13/08/2003 14:43 Re: Other embargo lifted!!! [Re: Roger]
crutkas
That is a 30 gig ipod.
The slate is a 1.5 gig unit.
Also in RMM2.0, you can drag files over, but not folders or m3u files.
clint rutkas
www.pronerd.com
#175140 - 13/08/2003 15:26 Re: Other embargo lifted!!! [Re: PeterDLai]
elperepat
Loc: Qc, Canada
Here are a few high-res shots of the new rio players:
http://gear.ign.com/articles/433/433165p1.html
Just click on small images to get the large ones!
Display looks nice and crisp on karma!! What is its resolution? bitdepth?
Patrick
#175141 - 13/08/2003 16:04 Re: Other embargo lifted!!! [Re: elperepat]
Rio basically kept the firmware, tweaked it, and put it into a new shell.
From what I remember the Riot was nothing to do with the empeg team. And wasn't the Riot interface quite different?
#175142 - 13/08/2003 16:31 Re: Other embargo lifted!!! [Re: tman]
robricc
From what I've seen of the Karma, the interface of the Karma and Riot are kinda similar.... not that that's a bad thing.
Karma has nothing to do with the Riot though and empeg did not work on the Riot.
#175143 - 14/08/2003 06:39 Re: Other embargo lifted!!! [Re: robricc]
The Karma and Riot UI's are superficially similar but there's no common code at all. IGN got the wrong end of the stick.
#175144 - 17/08/2003 19:11 Re: Other embargo lifted!!! [Re: tfabris]
Jerz
Loc: Jesusland
Ethernet is 100 megabit, of course. I don't know how well it's speed-optimized against USB 2.0 since I don't have a USB 2.0-capable machine to test with. I know that ethernet is faster than USB 1.0, I just don't know how much.
So is there a noticeable difference in speed when using the usb2.0 vs 100mb ethernet?
#175145 - 18/08/2003 02:45 Re: Other embargo lifted!!! [Re: Jerz]
Yes, large. Ethernet has to deal with running a TCP stack (& so on). It will improve over time, but even 100Mbit ethernet is nowhere near the speed of USB2.0, which is direct to disk with no CPU involvement at all.
We're taking maybe 6x speed increase with USB2.0.
Page 2 of 2 < 1 2
