I have searched through the FAQ and posts here but haven't found a specific answer to this question. I have been having off and on problems with my hard drive not reading properly ever since I owned the Empeg but it hasn't been a major deal until now. Usually it was a bad cable or drive and I would send it back to the UK to be massaged and it would come back working fine. NOw that I can't do that, I am running into the following issue and short of replacing the hard drive (which I don't want to do) I can't see an easy way to fix it. Thus I turn to you.
Basically, when I went to sync music today, the process failed and my second drive (hdb) dropped from the Empeg's site. When I boot up now, this is what I get through the seriel connection:
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux..................................... done,
booting the kernel.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v330 (root@ibbm) (gcc version 2.95.3 20010315 (release)) #2 Tue Apr 8 19:02:00 EDT 2003
empeg-car player (hardware revision 7, serial number 90000784)
Command line: mem=12m
Memory: 10940k/12M available (996k code, 20k reserved, 328k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
IrCOMM protocol (Dag Brattli)
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=1, ID=0
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004900).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
hdb: FUJITSU MHR2020AT, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
hdb: FUJITSU MHR2020AT, 19077MB w/2048kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:03:10
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 4k init empeg init 0.8
Mounting proc
Starting player
khttpd: listening on port 80
kftpd: listening on port 21
! tags.cpp : 61:Failed to open tags (0xc0041002).
EXT2-fs warning (device ide0(3,68)): ext2_free_blocks: bit already cleared for block 18671
EXT2-fs warning (device ide0(3,68)): ext2_free_blocks: bit already cleared for block 19696
After a few of those I get
EXT2-fs error (device ide0(3,68)): trunc_indirect: Read failure, inode=139, block=-1342103153
Remounting filesystem read-only
EXT2-fs error (device ide0(3,68)): trunc_indirect: Read failure, inode=139, block=-1793708560
attempt to access beyond end of device
03:44: rw=0, want=1949980067, limit=19451880
dev 03:44 blksize=1024 blocknr=-197503582 sector=-395007164 size=1024 count=1
EXT2-fs error (device ide0(3,68)): trunc_indirect: Read failure, inode=139, block=-197503582
03:44: rw=0, want=701845941, limit=19451880
dev 03:44 blksize=1024 blocknr=701845940 sector=1403691880 size=1024 count=1
EXT2-fs error (device ide0(3,68)): trunc_indirect: Read failure, inode=139, block=701845940
03:44: rw=0, want=1909346640, limit=19451880
dev 03:44 blksize=1024 blocknr=1909346639 sector=-476274018 size=1024 count=1
Then it goes back to
EXT2-fs warning (device ide0(3,68)): ext2_free_blocks: bit already cleared for block 73203
Untill eventually it just stops and hangs.
I have not tried this in the car which sometimes corrects this problem but every connection attemp through AC power seems to be resulting in this. I also opened her up to make sure all mount points and connections are solid which they are. Am I through or is there hope?
Greg
172458-empeglog.TXT (211 downloads)
