#173809 - 05/08/2003 09:28 Hard Drive Issues
kazama
Loc: Boston, MA
I have searched through the FAQ and posts here but haven't found a specific answer to this question. I have been having off and on problems with my hard drive not reading properly ever since I owned the Empeg but it hasn't been a major deal until now. Usually it was a bad cable or drive and I would send it back to the UK to be massaged and it would come back working fine. NOw that I can't do that, I am running into the following issue and short of replacing the hard drive (which I don't want to do) I can't see an easy way to fix it. Thus I turn to you.
Basically, when I went to sync music today, the process failed and my second drive (hdb) dropped from the Empeg's site. When I boot up now, this is what I get through the seriel connection:
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux..................................... done,
booting the kernel.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v330 (root@ibbm) (gcc version 2.95.3 20010315 (release)) #2 Tue Apr 8 19:02:00 EDT 2003
empeg-car player (hardware revision 7, serial number 90000784)
Command line: mem=12m
Memory: 10940k/12M available (996k code, 20k reserved, 328k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
IrCOMM protocol (Dag Brattli)
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=1, ID=0
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004900).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
hdb: FUJITSU MHR2020AT, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
hdb: FUJITSU MHR2020AT, 19077MB w/2048kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:03:10
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 4k init empeg init 0.8
Mounting proc
Starting player
khttpd: listening on port 80
kftpd: listening on port 21
! tags.cpp : 61:Failed to open tags (0xc0041002).
EXT2-fs warning (device ide0(3,68)): ext2_free_blocks: bit already cleared for block 18671
EXT2-fs warning (device ide0(3,68)): ext2_free_blocks: bit already cleared for block 19696
After a few of those I get
EXT2-fs error (device ide0(3,68)): trunc_indirect: Read failure, inode=139, block=-1342103153
Remounting filesystem read-only
EXT2-fs error (device ide0(3,68)): trunc_indirect: Read failure, inode=139, block=-1793708560
attempt to access beyond end of device
03:44: rw=0, want=1949980067, limit=19451880
dev 03:44 blksize=1024 blocknr=-197503582 sector=-395007164 size=1024 count=1
EXT2-fs error (device ide0(3,68)): trunc_indirect: Read failure, inode=139, block=-197503582
03:44: rw=0, want=701845941, limit=19451880
dev 03:44 blksize=1024 blocknr=701845940 sector=1403691880 size=1024 count=1
EXT2-fs error (device ide0(3,68)): trunc_indirect: Read failure, inode=139, block=701845940
03:44: rw=0, want=1909346640, limit=19451880
dev 03:44 blksize=1024 blocknr=1909346639 sector=-476274018 size=1024 count=1
Then it goes back to
EXT2-fs warning (device ide0(3,68)): ext2_free_blocks: bit already cleared for block 73203
Untill eventually it just stops and hangs.
I have not tried this in the car which sometimes corrects this problem but every connection attemp through AC power seems to be resulting in this. I also opened her up to make sure all mount points and connections are solid which they are. Am I through or is there hope?
Greg
172458-empeglog.TXT (211 downloads)
#173810 - 05/08/2003 10:11 Re: Hard Drive Issues [Re: kazama]
The hard drive seems to be behaving, but the filesystem data structures are corrupted. If you try another SYNC from Emplode, then it may do a proper filesystem check and fix the problem. Be prepared to wait an hour or more for it to do it's thing, though
The FAQ undoubtedly has more info, but try the simple SYNC again first.
#173811 - 05/08/2003 11:42 Re: Hard Drive Issues [Re: mlord]
kazama
Loc: Boston, MA
Just to clarify, when the system it hangs on "Building music database" (in the display) and on the last "EXT2-fs warning . . . " (In Terminal) it never gets to a point where Emplode will recognize it for a SYNC. I only let it hang for a couple of minutes so it may be doing something but I don't hear any drives spin or see any action in the terminal screen. I will run it now for an hour+ on the hang but my feeling is that it is frozen trying to do something. I can reach the pump from boot but I don't think that will do anything.
Addemndum - I am flashing the kernel and putting in the developers image again whihc is getting me around this problem. Thank you for you help!!!!
Addemndum - After I replaced the kernel with 2.0 developers, I am still running into the same problem. Delving into the FAQ again for some more help.
Edited by kazama (05/08/2003 12:21)
#173812 - 05/08/2003 11:58 Re: Hard Drive Issues [Re: kazama]
Oh well, I suppose if it never gets running well enough to do a "sync", then you'll have to consult the FAQ for the exact instructions on fixing the filesystems. That's what you need to do at this point.
#173813 - 05/08/2003 13:57 Re: Hard Drive Issues [Re: mlord]
That would be this FAQ.
#173814 - 05/08/2003 14:32 Re: Hard Drive Issues [Re: wfaulk]
kazama
Loc: Boston, MA
However, I can not get to a shell prompt to issue the fix the FAQ suggests. If I try to do a 'q'(enter) at boot it just ignores it and freezes at the stop point. I can apply a new kernel to the system but I come up with the same problem. I can get to the pump prompt but I don't think I can issue shell commands there. Can I?
#173815 - 05/08/2003 14:52 Re: Hard Drive Issues [Re: kazama]
The pump prompt is not a shell prompt.
Try hitting Ctrl-C instead of just q.
#173816 - 05/08/2003 16:24 Re: Hard Drive Issues [Re: wfaulk]
And if that fails, then reapply one of the developer upgrades (v2.00 final is okay) to restore the more critical files. Might even fix the whole deal in one go.
#173817 - 05/08/2003 17:43 Re: Hard Drive Issues [Re: wfaulk]
kazama
Loc: Boston, MA
Again, the BBS comes through with flying colors. I used cntr-C to get into the prompt, the instructions from the FAQ to fix the drive, and I am doing a simple sync through Emplode to fix the database.
A big THANK YOU to everyone who helped out and got me back on my feet.
Greg
