#173351 - 01/08/2003 16:32
Solar powered buttons
Loc: Texas, USA
I've been playing around with new buttons but from a different angle.
I'm using some stuff called Sculpey to press into the molds. It's not transparent but it does raise some interesting possibilies since it comes in different colors (including 4 glow in the dark colors), is cheap and doesn't have a problem with bubbles.
You can buy it at any craft store (Fimo works too). It doesn't provide the true back lit buttons but it's another option. Just make sure you make your mold out of a silicone rubber that can take the heat (265 F).
I used Smooth-on's Evergreen 40 rubber. It's pours bubble free but has a low melt point (170F which I didn't find out until after I made the mold). If you want to do resin casting, it seems to work well and is a 1 to 1 by volume mix ratio.
Edited by Mach (01/08/2003 16:33)
#173352 - 01/08/2003 17:59
Re: Solar powered buttons
[Re: Mach]
Hmm... Interesting...
My only concern would be the "staying power" of the glow. It might be possible to mold this into a thin layer, combine it with backlighting (buttonhack) to constantly "charge" the material.
#173353 - 01/08/2003 18:32
[Re: pgrzelak]
Loc: Texas, USA
Yes, it fades fairly quickly. I was thinking about filling a Farnell transparent button with it for the new face. I think it would give an edge lit effect with a glowing center. I've also got some phosphorescent powder that I'm going to try mixing into some silicone that way you get the translucence and the glow.
Have you heard anything from Casting_Fool lately? It'd be nice to have someone with more experience solving this one.
#173354 - 01/08/2003 19:09
[Re: Mach]
Actually, yes and no. I have not heard a status recently, but Stu sent out a Eutronix newsletter. In it was a statement that he had the documentation for the button kits ready, and that castings would likely be available "soon". I presume that significant progress is being made, but nothing made available yet.
#173355 - 02/08/2003 07:30
[Re: Mach]
This is cool. Now I need to find some blacklight leds....
#173356 - 03/08/2003 16:59
[Re: larry818]
Loc: Minnesota
Exactly what I was thinking. They'll charge the buttons from behind whenever the empeg is on.
#173357 - 03/08/2003 17:19
[Re: larry818]
Loc: Texas, USA
I found some but all of them carry warnings like...
Never look directly into the LED - especially at close range.
Never point the LED at someone's face.
Wear UV filtering glasses/sunglasses.
How bad are these things on your eyes? Would putting them behind the buttons act as a sufficient filter?
http://www.etgtech.com/product_9.html
Edited by Mach (03/08/2003 17:20)
#173358 - 04/08/2003 06:53
[Re: Mach]
Here's an interesting link on UV:
http://wolfstone.halloweenhost.com/TechBase/blttip_BlackLightTips.html
The host is missing for the link to the leds, but just about anything filters uv out. These buttons would fer sure. I'd be sure that they are mega-sheilded from any leakage to your eyes and also from any plastic other than the buttons. Most plastics are not UV stable.
#173360 - 04/08/2003 11:17
[Re: Mach]
At the second link I spotted no 3 mm UV LEDs, but at the first site they have 3 mm ones WUV303-C395-C(395±5nm) , WUV303-C405(405±5nm).
IIRC, the supply voltage is 5V, so the 3.7V they sport should be OK. You might want a different resistor value than supplied (IIRC 1kOhm) in the resistor pack. I'd get the LEDs, hook one up with wires and trim potentionemeter, and trim until you had the output you wanted with the knobs you're using. Then measure what the pot says and get the closest available resistor pack...
But for the knob you need SMD LEDs, which the second site has (the first hints that all their LEDs aren't in their catalog, so you might want to ask them about SMD LEDs as well).
E1S09-OPOAP-02, 385 nm, 1.7 mW @ 20 mA, SMD, 3.0 x 3.4 mm˛, 110° viewing angle
looks to be the best match.
#173361 - 04/08/2003 11:38
[Re: Mach]
Mmmm.. which reminds me..
Here's Alvin playing with his Lego (Duplo) set:
#173362 - 04/08/2003 11:48
[Re: mtempsch]
Loc: Texas, USA
Ahh, thank you very much. I'll contact the othe site to see if they have 3mm also.
#173363 - 04/08/2003 11:59
Loc: Texas, USA
Those are hi-tech, RTV retaining walls. I only play with bionicles now.
#173364 - 04/08/2003 12:10
[Re: Mach]
Forgot to say - I think the size of the SMD LEDs vary between some of the kits/boards available - check which size fits the board you have/will get...
#173365 - 04/08/2003 14:02
[Re: Mach]
Loc: Louisiana, USA
I've got a couple of sources for the LEDs but am not sure they'll work with Stu's button kits. I've pinged Stu for an assist but does anyone else know if these will work?
Hmm, never got anything from you. The UV T1 LEDs should work fine. Their forward voltage is within 1/10 that of the white ones we use. I don't see a link for UV surface mount LEDs in your links. I can probably get them if you need them for the knob board. And as far as that goes, here are the dimension used in the surface mount pads we have on our knob boards:
Stu
#173366 - 05/08/2003 00:44
[Re: maczrool]
Loc: Texas, USA
I thought I sent an email but thanks for the reply here. If you have a source for either the UV T1 LEDs or the surface mount LEDs, I'll take you up on the offer. I've got an email in to a source in Taiwan and Austria but no response as of yet.
#173367 - 05/08/2003 08:58
[Re: Mach]
Loc: Louisiana, USA
How many do you need? The smaller the quantity, the less cooperative many distributors become. The ones I've found are a little oversized for the knob board, but not too bad. Availability is sketchy, especially on the SMDs, but I think I can get them.
Stu
#173368 - 05/08/2003 09:06
[Re: maczrool]
Loc: Texas, USA
A minimum would be 4 of the T1s and 4 of the SMD's. Depending on price ($5/range?), probably a max of 10 of the T1s and 10 of the SMDs.
Anyone else interested?
#173369 - 05/08/2003 10:10
[Re: Mach]
It's not transparent but it does raise some interesting possibilies since it comes in different colors (including 4 glow in the dark colors), is cheap and doesn't have a problem with bubbles. It looks very similar to the stuff I keep talking about... where it's milky-white translucent so that it diffuses the light. Can you see light through it at all?
#173370 - 05/08/2003 10:22
Loc: Texas, USA
Yes you can see light through it but it's not great. I'll take a pic tonight. The also make a translucent clay and fluid but I haven't tried it yet.
#173371 - 05/08/2003 10:35
[Re: Mach]
I'd love to see if you can mix the translucent stuff with the white stuff. My ideal would be a gray shade that looks similar to the original buttons when unlit, and faintly backlit when the LEDs are on.
#173372 - 05/08/2003 11:09
ooooh... that would be so sweet. A smoke grey color that slightly glows when backlit. Very nice. me wanty.
#173373 - 05/08/2003 11:51
[Re: Mach]
Loc: Texas, USA
Ok I'll give it a try. I'm making a new mold right now so it'll be a week or so. I've got some silicon rubber that I'm going to try soft touch buttons so I'll try to color it also.
#173374 - 05/08/2003 11:58
[Re: Mach]
Loc: Louisiana, USA
Somewhere in there. Maybe a little less.
Edit: I am expecting a call from a distributor regarding the SMD UV LEDs. If there is enough interest, I can already buy the SMD units from another distributor, but only in 100 unit minimums. The T1s I can get in a 25 unit minimum.
Stu
Edited by maczrool (05/08/2003 12:17)
#173376 - 05/08/2003 12:47
[Re: Mach]
#173377 - 05/08/2003 13:16
Loc: Texas, USA
I've got the mold for it but haven't tried it yet. The edges are very thin on that knob. I'll give it a whirl tho.
#173378 - 05/08/2003 14:00
[Re: Mach]
I'm going to try soft touch buttons Explain. Do you mean you can create buttons that have that rubberized feel to them? I was just thinking about figuring out how to do that.
#173379 - 05/08/2003 14:03
couldn't you coat a thin layer of some sort of vulcanizing rubber in the mold, then fill the rest with plastic?? Hm... you'd have to use a hard mold for that though wouldn't you... or do they have rubber molds than are compatible with other types of rubber...
#173380 - 05/08/2003 14:07
[Re: loren]
I don't know. Maybe.
The knobs in my new car are rubbery on the surface, but hard underneath and I thought it would be cool to have my empeg's knob be the same. Thinking about new buttons, too, but we'll see about that one.
Regardless, I need to get it installed first.
