#168875 - 03/07/2003 08:31 EMPEG is taking a LONG time to start (> 5 minutes)
thedon
I noticed in the car yesturday that my EMPEG got horribly slow. To the point where pressing "play" didn't do anything until approximatly 2 minutes later... Today, when I powered it up at home, it took approximatly 5-6 minutes to fully turn on... Each part of the boot-up process (loading visuals, etc) took 1-2 minutes each...
Any idea what might be happening?
I'm scared!
#168876 - 03/07/2003 09:54 Re: EMPEG is taking a LONG time to start (> 5 minutes) [Re: thedon]
Could be a hard disk on its way out. It'll get progressively slower as it tries multiple times to read each failing sector.
With the empeg plugged into AC power, listen to the drives -- if it's going whir, whir, click, click, click, click, whir, then it's probably failing.
#168877 - 03/07/2003 09:59 Re: EMPEG is taking a LONG time to start (> 5 minutes) [Re: Roger]
Would you also see errors in the boot log? That might be a good thing to capture anyway, if possible.
#168878 - 03/07/2003 11:00 Re: EMPEG is taking a LONG time to start (> 5 minutes) [Re: pgrzelak]
thedon
I'm not framiliar with how to do that, is it easy
#168879 - 03/07/2003 11:05 Re: EMPEG is taking a LONG time to start (> 5 minutes) [Re: thedon]
