#165907 - 15/06/2003 12:44 DNS and BIND
I'm have a FreeBSD box running BIND9 to provide caching internet DNS queries but also to provide DNS for our imaginary internal domain (shocknet.all). Now, I've got the forwarding working so I look for www.bbc.co.uk it resolves correctly as does the reverse. If I do my lookup for andymlaptop.shocknet.all it resolves to 192.168.1.10. Now here's the problem if I try to do a lookup on 192.168.1.10 it fails.........
included here are the configurations files....
================named.conf====================
options
directory "/etc/namedb";
listen-on
127.0.0.1;
192.168.1.1;
//forward only;
forwarders
10.0.0.2;
zone "shocknet.all"
type master;
file "shocknet.all";
zone "."
type hint;
file "named.root";
zone "1.168.192.IN_ADDR.ARPA"
type master;
file "1.168.192.in_addr.arpa";
zone "0.0.127.IN-ADDR.ARPA"
type master;
file "localhost.rev";
==============shocknet.all====================
$TTL 3600
shocknet.all. IN SOA ns1.shocknet.all. admin.shockradio.co.uk (
1
10800
3600
604800
86400 )
;DNS Servers
@ IN NS ns1.shocknet.all.
;Machine Names
localhost IN A 127.0.0.1
ns1 IN A 192.168.1.1
andymlaptop IN A 192.168.1.10
;Aliases
www IN CNAME @
;MX Record
@ IN MX 10 ns1.shocknet.all.
==============1.168.192.inn_addr.arpa====================
$TTL 3600
@ IN SOA ns1.shocknet.all. admin.shockradio.co.uk (
20030615
3600
900
3600000
3600 )
;DNS Servers
;Machine Names
1 IN PTR brendan.shocknet.all.
10 IN PTR andymlaptop.shocknet.all.
======================named.root========================
; formerly NIC.NORDU.NET
; $FreeBSD: src/etc/namedb/named.root,v 1.9.2.1 2002/11/06 09:24:12 dougb Exp $
; This file holds the information on root name servers needed to
; initialize cache of Internet domain name servers
; (e.g. reference this file in the "cache . <file>"
; configuration file of BIND domain name servers).
; This file is made available by InterNIC
; under anonymous FTP as
; file /domain/named.root
; on server FTP.INTERNIC.NET
; last update: Nov 5, 2002
; related version of root zone: 2002110501
; formerly NS.INTERNIC.NET
. 3600000 IN NS A.ROOT-SERVERS.NET.
A.ROOT-SERVERS.NET. 3600000 A 198.41.0.4
; formerly NS1.ISI.EDU
. 3600000 NS B.ROOT-SERVERS.NET.
B.ROOT-SERVERS.NET. 3600000 A 128.9.0.107
; formerly C.PSI.NET
. 3600000 NS C.ROOT-SERVERS.NET.
C.ROOT-SERVERS.NET. 3600000 A 192.33.4.12
; formerly TERP.UMD.EDU
. 3600000 NS D.ROOT-SERVERS.NET.
D.ROOT-SERVERS.NET. 3600000 A 128.8.10.90
; formerly NS.NASA.GOV
. 3600000 NS E.ROOT-SERVERS.NET.
E.ROOT-SERVERS.NET. 3600000 A 192.203.230.10
; formerly NS.ISC.ORG
. 3600000 NS F.ROOT-SERVERS.NET.
F.ROOT-SERVERS.NET. 3600000 A 192.5.5.241
; formerly NS.NIC.DDN.MIL
. 3600000 NS G.ROOT-SERVERS.NET.
G.ROOT-SERVERS.NET. 3600000 A 192.112.36.4
; formerly AOS.ARL.ARMY.MIL
. 3600000 NS H.ROOT-SERVERS.NET.
H.ROOT-SERVERS.NET. 3600000 A 128.63.2.53
. 3600000 NS I.ROOT-SERVERS.NET.
I.ROOT-SERVERS.NET. 3600000 A 192.36.148.17
; operated by VeriSign, Inc.
. 3600000 NS J.ROOT-SERVERS.NET.
J.ROOT-SERVERS.NET. 3600000 A 192.58.128.30
; housed in LINX, operated by RIPE NCC
. 3600000 NS K.ROOT-SERVERS.NET.
K.ROOT-SERVERS.NET. 3600000 A 193.0.14.129
; operated by IANA
. 3600000 NS L.ROOT-SERVERS.NET.
L.ROOT-SERVERS.NET. 3600000 A 198.32.64.12
; housed in Japan, operated by WIDE
. 3600000 NS M.ROOT-SERVERS.NET.
M.ROOT-SERVERS.NET. 3600000 A 202.12.27.33
; End of File
(END)
==========localhost.rev===============
; operated by IANA
; End of File
================localhost.rev==============================
; From: @(#)localhost.rev 5.1 (Berkeley) 6/30/90
; $FreeBSD: src/etc/namedb/PROTO.localhost.rev,v 1.6 2000/01/10 15:31:40 peter E
xp $
; This file is automatically edited by the `make-localhost' script in
; the /etc/namedb directory.
$TTL 3600
@ IN SOA brendan.salford.ac.uk. root.brendan.salford.ac.uk. (
20030615 ; Serial
3600 ; Refresh
900 ; Retry
3600000 ; Expire
3600 ) ; Minimum
IN NS brendan.salford.ac.uk.
1 IN PTR localhost.
2 IN PTR monkey.
(END)
Any ideas?
#165908 - 15/06/2003 12:57 Re: DNS and BIND [Re: andym]
Is the file really so named, with the extra "n", or is that the typo you're looking for?
#165909 - 15/06/2003 13:03 Re: DNS and BIND [Re: peter]
You're right, I changed it and now it throws up an error when I start the server.
#165910 - 15/06/2003 13:15 Re: DNS and BIND [Re: andym]
genixia
Did you change the serial?
#165911 - 15/06/2003 22:13 Re: DNS and BIND [Re: peter]
jimhogan
Loc: Seattle, WA, U.S.A.
The "nn" typo aside, what happens if you replace the underscore with a hyphen? Hmmm, later BIND no worky with underscores in domains, true? (Or so I remembered...I think...)
Jim
#165912 - 16/06/2003 06:09 Re: DNS and BIND [Re: jimhogan]
I'll have a tweak, a kind soul in my office has lent me a copy of the O'Reilly BIND book so I've got some light bedtime reading tonight! I'll let you know how I get on....
#165913 - 16/06/2003 07:23 Re: DNS and BIND [Re: andym]
That should ensure a good night's sleep tonight ;-)
#165914 - 19/06/2003 10:15 Re: DNS and BIND [Re: andym]
Well joint first prize went to Peter and Jim, typo with the extra n and the underscore instead of an hyphen It now works a treat, thanks!
Edited by marria01 (19/06/2003 11:45)
