#165169 - 11/06/2003 14:52 Problem with uploading a kernel
miko
Loc: Poland
Hello,
I have uploaded a hijacked kernel v270 some time ago, and it did work. Now when I try do upload a new kernel (I mean any kernel: hijacked v338, or Empeg's car-developer-v2.0beta13) it will not work. I had some problems with external power supply, so I am afraid it could destroy something. The player (MK2a) seems to work, except that left half of the VFD is dead (see another topic).
I am trying to upload from linux, using download.c, with serial cable. All I get is:
Turn on empeg unit now
found empeg unit: entering program mode
Couldn't find manufacturer ID!
Looking at download.c I can see the comment:
Look for '#' then 4 hex digits
I guess I don't get those digits. The output of my bootlog ends like this:
kftpd: listening on port 21
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
! mp3_decoder.cpp : 1049:Failed to find valid sync after seeking to offset 3862714, error=0xc0044000
And there is no '#' followed by 4 hex digits.
Am I right that the log file is incomplete? What could be the cause? Could it be an error in the flash memory? I do not get a shell, the console just dies... Will I be able do force a new kernel upload?
Michal
#165170 - 11/06/2003 15:01 Re: Problem with uploading a kernel [Re: miko]
Do you have access to a Windows computer? Please try this on a Windows computer using the current version of my Logoedit program. See if that works.
#165171 - 11/06/2003 15:37 Re: Problem with uploading a kernel [Re: tfabris]
miko
Loc: Poland
Yes, I tried with logoedit1.7 - it looked like it worked (it "detected" manufacturer ID and product ID, and was showing "erasing" and "program" messages). But after I rebooted the player, I saw it still announces itself as a beta11, which is my previously uploaded kernel. So it did not work, and this is because I don't get a shell on the serial console - I guess.
BTW, how do you quote the sentence in this forum?
Michal
#165172 - 11/06/2003 15:44 Re: Problem with uploading a kernel [Re: miko]
That's the PLAYER SOFTWARE talking.
The kernel is not the same as the player software. Please read this and this.
#165173 - 11/06/2003 15:46 Re: Problem with uploading a kernel [Re: miko]
Explained here.
#165174 - 11/06/2003 18:05 Re: Problem with uploading a kernel [Re: tfabris]
miko
Loc: Poland
You are right, I have missed a line from the kernel. The kernel upgrade worked. So I upgraded the software also (with emplode) which also have worked. So it looks like everything is working - thanks! Now the only remaining problem is the display, but it is quite different story I will try to get display server to see the remaining half of the display
Michal
#165175 - 12/06/2003 03:49 Re: Problem with uploading a kernel [Re: miko]
Greetings!
Getting the display replaced is not a difficult thing. Have you contacted support about it? I know that there are a number of extra display modules floating around right now, and I am sure Rob has a few. Replacing the glass module is something that can be done fairly easily.
#165176 - 12/06/2003 10:52 Re: Problem with uploading a kernel [Re: miko]
Remember that the software upgrade overwrites the kernel with the factory kernel. So if you want the hijack kernel, you need to re-install it.
If you have the hijack kernel installed, just use CharcoalGray99's XML interface, or write your own routine to retrieve http://your.empeg.ip.address/proc/empeg_screen.png. Displayserver has kind of been replaced by that feature hijack.
#165177 - 12/06/2003 11:42 Re: Problem with uploading a kernel [Re: tfabris]
miko
Loc: Poland
Of course I did reinstal hijack kernel after upgrade, sorry I didn't mention it.
Actually I have installed CharcoalGray as well as empegVNC. I have read about displayserver about a year ago, and didn't check for new software for empeg - I found out about these new programs just yesterday. It is good to see that there is still new software developed for empeg!
BTW, all programs mentioned use ethernet connection. I wonder if there is similar USB-based solution?
Michal
#165178 - 12/06/2003 11:45 Re: Problem with uploading a kernel [Re: miko]
No, not at this time. However there has been some discussion about writing a driver shim to make the Mk1 empeg appear as if it were an external USB-to-ethernet converter dongle so that these programs could be run on a Mark 1 player. This project hasn't had any action recently, so I don't know if it's going to happen.
