#164411 - 06/06/2003 11:57 Empeg mk1 working slowly
decay
Yeh!
So, I have a mk1 (again mentionin' about it) and two HD's, 6GB and 20GB. There's about 3GB free on the player.
I have Hijack 33x or 32x installed. Empeg software 2 final.
Problem is that my player is slow. For doing the down-down-down, it could take ~5-10 secs to play. That's a long time to be w/o music incar d=/
Another thingie is the remote, trying to search the right artist / tune and there's a slight pause after each letter. So typing 'Garbage' with my instant-typing-sms-oriented-fingers and I'll see only 'Ga' on the screen, and slowly the rest of the letters are coming from somekind of cache..
Meepmeep! Normal activity or a software issue? Anything to be done?
No, I don't want to solder an extra block of RAM on it d=/
Thinking about upgrading the HD's to bigger ones, but if the database gets too large on these...
- Decay
#164412 - 06/06/2003 11:59 Re: Empeg mk1 working slowly [Re: decay]
Are you running any third party programs from the @EXEC feature of Hijack?
#164413 - 06/06/2003 12:03 Re: Empeg mk1 working slowly [Re: decay]
decay
No.
There was ynot's emphatic running a month ago, for a week or so.
well, maybe I'll check the config.ini once again.
- Decay
#164414 - 06/06/2003 12:06 Re: Empeg mk1 working slowly [Re: tfabris]
decay
Here's the end of my config.ini
[ir_translate]
00B94604=20df04
[output]
notify=1
[emphatic]
button=menu 00b94615
button=left 00b9460c
button=right 00b9460d
[hijack]
[shuffle]
deduplicate=1
Can't remember what the ir_translate is for, and as far as I remember the emphatic sections remaps didn't work. They don't make any load, do they?
- Decay
#164415 - 06/06/2003 12:36 Re: Empeg mk1 working slowly [Re: decay]
Remove the following lines:
00B94604=20df04
notify=1
See if that fixes it. Is there anything else of note in your config.ini we should see?
#164416 - 06/06/2003 12:39 Re: Empeg mk1 working slowly [Re: tfabris]
decay
notify=1
umm, i thought this was used to something i need? what could it be, can't remember. I remember emphatic needed this, but since I'm not using it anymore..
What else needs that?
- Decay
#164417 - 06/06/2003 12:42 Re: Empeg mk1 working slowly [Re: decay]
Certain third-party programs need it. But as you said, you're not running any. So check and see if removing it fixes the problem.
#164418 - 06/06/2003 12:44 Re: Empeg mk1 working slowly [Re: tfabris]
decay
Ok. This is the end of my config.ini now:
[aux]
source=
title=
artist=
[ir_translate]
[output]
[hijack]
[shuffle]
deduplicate=1
Dunno, maybe the downdowndown is a little faster, maybe not. I'll see it next time when I'm driving around and fiddle w/ my remote
Thanks Tony!
- Decay
#164419 - 06/06/2003 12:50 Re: Empeg mk1 working slowly [Re: decay]
Down Down Down is always slow for a large database. That's normal.
It was the other problems you listed that I was thinking might be solved with removal of the Notify.
