#163924 - 03/06/2003 02:04 Problems with riocar.org?
skibum
Loc: Swindon, UK
Is it me, or has riocar.org got problems currently. I keep getting :-
Warning: Too many connections in /home/drakino/riocarorg/html/mainfile.php on line 42
Warning: MySQL Connection Failed: Too many connections in /home/drakino/riocarorg/html/mainfile.php on line 42
Unable to select database
#163925 - 03/06/2003 03:44 Re: Problems with riocar.org? [Re: skibum]
Greetings!
It is not just you.
#163926 - 03/06/2003 04:11 Re: Problems with riocar.org? [Re: pgrzelak]
CrackersMcCheese
Me too.
#163927 - 03/06/2003 05:46 Re: Problems with riocar.org? [Re: skibum]
Don't tell me they've been using Marvin as a web server.
#163928 - 03/06/2003 09:54 Re: Problems with riocar.org? [Re: skibum]
There were some problems with Apache on the server (BBS down, timezones getting confused), and he made some tweaks to the Apache server to fix them. The "too many connections" errors were a result of these tweaks, so he's reversed the tweaks until he can find a proper solution for both issues.
#163929 - 04/06/2003 13:36 Re: Problems with riocar.org? [Re: tfabris]
(I finally braved the 2500 unread posts to get back into general)
It seems something with a recent Apache upgrade broke the BBS from being able to use persistant MySQL connections. The apache process was holding it open, so over time it built up to the limit. I have since disabled persistant connections for the board, and tweaked Apache a bit more, so things should be fixed for now.
I'm going to try and do the update to 6.2 here by the end of the month to gain any optimizations out of the new code. The recent events put the BBS in the spotlight on the box it is hosted on, and thats a bad thing if I want to keep the boards hosted there free.
