#162644 - 24/05/2003 07:01 AHHHHHHHHHHH HELP!!!! Now I want 2 drives!!
duke
PLEASE!!! I've had my rio Mark 2 for almost 2 years now, and I've always had 1 drive, now I"m trying to add a drive and it's a fricken night mare... I was up till 5am last night trying to get this thing going!! Can somone PLEASE just give me the few basic steps in adding another HD to my RIO... AND YES I have been to: http://www.riocar.org/modules.php?op=modload&name=Drive_Upgrade&file=index
And the instructions are WAY to vague. Its like getting a whole happymeal when all I wanted was a burger.. dum analogy, but you get my point.. (no offense to the author).. I guess I"m just frustrated, and I can't extract the basic steps.. Could some merciful Pilgrim PLEASE, just list the basic steps, necessary for this process. Or another link. THANKYOU for ANYTHING!
Specs/ Problem:
Rio Mark 2
I'm adding a 20gig IBM Travelstar to a 30gig IBM Travelstar.
Both have update installed, and both work separatly.
When their together, With jumper on the slave, it boots up fine, however, I don't see the second drive in Emplode or the extra drive space I thought I would have at the bottom of emplode, all I see is the space on the master (30gig)...
nick
#162645 - 24/05/2003 07:09 Re: AHHHHHHHHHHH HELP!!!! Now I want 2 drives!! [Re: duke]
Greetings!
Okay. If both work individually in the player, but not together... You are saying that it boots fine? Could you please post a boot log, just in case. It sounds like it is not mounting the music partitions on the new slave 20GB drive. The boot log might help.
One other thing to check - do you have the hijack option installed that ignores the second hard drive? It is there to make it boot faster. This has caught people in the past.
Edit: Tony, I was searching the FAQ for the hijack disable second drive check, when I saw that the largest disk drive is still 60GB. When you have time, you might want to update this to the 80GB, with the caveat that Laura found about running builder on an 80GB drive from a Mark I.
Edited by pgrzelak (24/05/2003 07:15)
#162646 - 24/05/2003 07:30 Re: AHHHHHHHHHHH HELP!!!! Now I want 2 drives!! [Re: pgrzelak]
duke
ok.. lets pretend that I know nothing about linux first and foremost. All I do is install my automatic updates when I'm told to.
I know for a fact that I don't have the hijack option installed.
And Is a the boot log basically what pops up on Hyperterminal when I start my Rio Mark 2 ?? Is that what you need?
thanks
nick
#162647 - 24/05/2003 07:34 Re: AHHHHHHHHHHH HELP!!!! Now I want 2 drives!! [Re: duke]
Greetings!
The boot log is the text that hyperterm will show when the empeg is first powered up. Basically, I just want to verify that it finds the second hard drive, that the data it sees is (basically) correct for a 20GB travelstar and any errors it sees when it tries to mount the partition.
Assuming that both drives work when they are hooked up alone as master, I am thinking it might be...
a) a connector on your cable is bad, so that the second drive is not seen at all during the boot
b) the drive is seen, but the partition mount never happens
c) the drive is seen, it tries to load the partition, but fails and gives an error message
d) both partitions mount properly, but the player software is confused by what it sees
#162648 - 24/05/2003 07:41 Re: AHHHHHHHHHHH HELP!!!! Now I want 2 drives!! [Re: pgrzelak]
duke
Well here it is.. but I swear.. it's all greek to me!
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #12 Tue Apr 1 18:51:41 BST 2003
empeg-car player (hardware revision 9, serial number 40103242)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004a80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IC25N030ATCS04-0, ATA DISK drive
hdb: IBM-DJSA-220, ATA DISK drive
hda: IC25N030ATCS04-0, 28615MB w/1768kB Cache, CHS=58140/16/63
hdb: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0c:a
a
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init player.cpp : 385:empeg-car 2.00 20
03/04/01.
Vcb: 0x4086d000
#162649 - 24/05/2003 07:50 Re: AHHHHHHHHHHH HELP!!!! Now I want 2 drives!! [Re: duke]
Greetings!
Hm. Perfect. It also shows that both of the hard drives are being located, and that they are being read properly, showing up as the right type of drive and size:
It also shows that it is finding the partitions correctly on both drives (hda & hdb):
Partition check:
So... This gets a bit more interesting.
Do you have the developer version of the player loaded, or the consumer one? If you have the developer version, you can get to the shell prompt by typing "q" after it boots. If you can do this, please do the following and let me know what happens:
cd /drive0/var
ls
cd /drive0/fids
ls
cd /drive1
ls
cd /drive1/var
ls
cd /drive1/fids
ls
Basically, I just want to look around to see what the player thinks it sees in these directories.
#162650 - 24/05/2003 08:10 Re: AHHHHHHHHHHH HELP!!!! Now I want 2 drives!! [Re: pgrzelak]
duke
I did what you told me to and here's the results:
q
Starting bash.
no shell!
Shell exit
Vcb: 0x4086d000
cd/driveO/var
Vcb: 0x4086d000
ls
cd/driveO/fids
ls
cd/drive1
ls
cd/drive1/var
Vcb: 0x4086d000
ls
cd/drive1/fids
ls
#162651 - 24/05/2003 08:18 Re: AHHHHHHHHHHH HELP!!!! Now I want 2 drives!! [Re: duke]
Greetings!
Okay. Well, this will not help much, I am afraid. Basically, you are running the consumer version as seen by:
q
Starting bash.
no shell!
Shell exit
Vcb: 0x4086d000
The q command worked, but there was no shell to go back to. In order for me to go further, I would need to have you install the developer image. This would allow me (well, you) to get to the command line of the player, to examine the hard drives directly. I am guessing that you have a Mark2 or 2A.
Edit: oh, and there is a space between the cd and the slash (/). And it is drive0 (zero).
Edited by pgrzelak (24/05/2003 08:25)
#162652 - 24/05/2003 08:30 Re: AHHHHHHHHHHH HELP!!!! Now I want 2 drives!! [Re: pgrzelak]
duke
whoops.. sorry about the space... listen though I"m going to take a short recess for the rest of the day.. I appriciate your help, I have things I need to attend to. Hopfully if you're still around later we can pick up where we left off.. (the real world calls....) Thankyou so much for all your help so far.
nick
#162653 - 24/05/2003 08:32 Re: AHHHHHHHHHHH HELP!!!! Now I want 2 drives!! [Re: duke]
Not a problem. The next step (installing developer) will take a little time. I am usually around, somewhere...
#162654 - 24/05/2003 11:48 Re: AHHHHHHHHHHH HELP!!!! Now I want 2 drives!! [Re: duke]
SE_Sport_Driver
I know you must have been pretty stessed out when you posted this, but for the record, that Drive Upgrade Tutorial is the best writen tutorial I have ever read on the web. I didn't realize this until I went to a few car sites to learn how to bolt on parts to my car.
If anything, the Upgrade Guide is anything but vague. It lists every possibility and provides information for each situtation. My guess is that you didn't get a chance to read it before starting your upgrade, especially this part:
Make sure you also have the proper standard ".upgrade" file for your player ready. You will need to re-install the player software upgrade onto the new disk drive after formatting it. Make sure that it matches the currently installed software on the player, and is the correct one for your player model (Mark 1 or Mark 2). Make it the developer version so that you can drop to the shell prompt during the procedure if you have to (you can go back to the consumer version after you're all done if you want). If necessary, upgrade the player software before starting this procedure to make certain that it's the same one as what you'll be installing on the new disk. This is important, so that a mismatch between the flash kernel and the player on the disk doesn't happen as you swap disks.
This part is writen in the section listing things you need to get set before you take tools to your player.
Again, I know you were stressed when you wrote this, so no biggy. I don't know anything about Linux either, except what has been writen in that guide. And I am certainly NOT a hardware guy, so if you take the time to slowly read through it, I'm sure you'll find what you need.
#162655 - 24/05/2003 15:38 Re: AHHHHHHHHHHH HELP!!!! Now I want 2 drives!! [Re: pgrzelak]
duke
OK. I"m back.. I copied and pasted all the commands but nothing came up.. Listen... what would be the normal procedure for adding another drive?? This is what I did.
1.Physically Install it with the slave jumper, slave is plugged into the middle plug in the cable
2. run "car2-builder-20011022" then run the "consumer 2.00" update.
3. boot up and it works but emplode doesn't see the second drive (the slave 20gig drive)
q
Starting bash.
no shell!
Shell exit
Vcb: 0x4086d000
cd /drive0/var
ls
cd /drive0/fids
ls
cd /drive1
ls
cd /drive1/var
ls
cd /drive1/fids
ls
#162656 - 24/05/2003 15:53 Re: AHHHHHHHHHHH HELP!!!! Now I want 2 drives!! [Re: duke]
You need to install the developer build before you can run the commands. Download it from the empeg.com site.
It doesn't matter if you leave it with the developer build.
- Trevor
#162657 - 24/05/2003 18:26 Re: AHHHHHHHHHHH HELP!!!! Now I want 2 drives!! [Re: duke]
SE_Sport_Driver
Listen, you only run the Builder when the "virgin" drive is connected. If only the virgin drive is plugged in, it would be the Master and would not be jumped as Slave.
It sounds like you had both drives plugged in when you ran the builder which is a big NO NO in the Upgrade Guide (and has a very big warning about this). If the virgin drive was the only thing connected, and you had it jumpered as Slave when you ran the Builder, it would not have worked. If it didn't work, the virgin drive would never have been formatted and would explain why emplode does not see the extra space (but the drive would still show up as a physical device during the boot sequence).
Listen, even if you did that correctly, you'll need to install the Developer version of the 2.00 software here.
Listen, if I were you, I'd read the Upgrade Guide first, from beginning to end. And then start over from scratch and take you time.
#162658 - 24/05/2003 20:39 Re: AHHHHHHHHHHH HELP!!!! Now I want 2 drives!! [Re: SE_Sport_Driver]
duke
Thanks brad, I appreciate it... I think what happened, is that I did so many things wrong at first that I thought were right bc it was so late and I was very tired, that I forgot what I did.. but I"m going to do this from start and we'll see what happens. Thanks for your patience.
nick
#162659 - 25/05/2003 06:37 Re: AHHHHHHHHHHH HELP!!!! Now I want 2 drives!! [Re: duke]
Greetings!
It might be a good idea to retrace your steps. Only I would recommend using the developer version if possible. You will not see any difference when using it, but it will allow for more troubleshooting if you run into trouble. Give this a shot and let everyone here know if you have any trouble.
#162660 - 27/05/2003 10:00 Re: AHHHHHHHHHHH HELP!!!! Now I want 2 drives!! [Re: duke]
I'm glad I was gone for the weekend when this came up.
/me puts fingers in his ears and shouts "la la la la, I'm not listening... la la la la..."
#162661 - 27/05/2003 10:09 Re: AHHHHHHHHHHH HELP!!!! Now I want 2 drives!! [Re: tfabris]
Hahahahahah... I kind of thought you were away when I didn't see a reply on this thread.
By the way, Duke, did you get this working?
#162662 - 27/05/2003 10:15 Re: AHHHHHHHHHHH HELP!!!! Now I want 2 drives!! [Re: SE_Sport_Driver]
Awww, thanks man.
#162663 - 04/06/2003 09:01 Re: AHHHHHHHHHHH HELP!!!! Now I want 2 drives!! [Re: tfabris]
bbowman
Loc: Virginia, USA
I have to second that - After carefully reading the instructions and following each step, the upgrade went as smooth as glass. Don't skim through it - just read it - it's in there!
Brent
RioCar MK][a 20GB+80GB
'96 Saab 900s (Not any more)
#162664 - 04/06/2003 10:15 Re: AHHHHHHHHHHH HELP!!!! Now I want 2 drives!! [Re: bbowman]
Hey, thanks. I'm glad it went well for you.
