#162505 - 22/05/2003 20:16 Palantir / Empire Install Difficulty
Ezekiel
Loc: NH USA
Thanks to the Dell free Zire offer I now have the tools to finally try this out. I've got the Palm set & running with my database, and have installed the files & changed permissions on the empeg (MKII) to match the install page.
Unfortunately when Palantir looks for the empeg it never finds it. I verified that the IR LEDs are working with my nightvision camcorder.
One time (just once of perhaps 14 tries) I got a message that it was uploading the playlist, but it seemed to time out with no change in playlist on the empeg. Palantir said it lost contact.
The only part of the install I was a little fuzzy on was the link to the OBEX page. I don't think I was supposed to (and didn't) install anything directly from the OBEX webpage, rather the libopenobex files from the empire.zip file. Is that correct?
I'm kind of stumped. The only thing that looks funny is a line at the end of the boot sequence that says something like 'unknown IR received' (I've put the gadgets away for the night, and can get the specific message tomorrow, if need be).
The PalmOS version on the Zire is 4.12 and other than empire & my contacts/calender entries synced from MS Outlook, it's virgin. The empeg kernel is the precompiled hijack 230 kernel linked from Cushman's page.
Anybody have an idea what I might have botched? Thanks.
-Zeke
WWFSMD?
#162506 - 22/05/2003 20:58 Re: Palantir / Empire Install Difficulty [Re: Ezekiel]
cushman
Loc: Erie, CO
Does your serial log output verify that Empire is running, and that it has run AFTER the player has started? Post your serial log and I'll take a look at it. Also, remember that you have to be within a few inches of the Empeg to get within IrDA range, because of the lens, IR hardware, and a zillion other things.
Mark Cushman
#162507 - 23/05/2003 05:24 Re: Palantir / Empire Install Difficulty [Re: cushman]
Ezekiel
Loc: NH USA
I've attached a serial log showing the boot sequence and then ls -l of what I believe are the proper install directories. I did notice one other thing (not included) and that was a series of khttpd errors, which I assume are there because I haven't reinstalled charcoalgrey's web interface yet. Let me know what you think.
Further info (may or may not be important), I use the green AR face and did have the Palm 1-3 inches from the IR on the empeg.
-Zeke
160614-boot log.TXT (555 downloads)
WWFSMD?
#162508 - 23/05/2003 06:14 Re: Palantir / Empire Install Difficulty [Re: Ezekiel]
cushman
Loc: Erie, CO
Okay, you are starting ttsclock after empire starts, maybe that is delaying the start of the player for a second or so. Try increasing the time delay on start_empire from 10 (seconds) to 30, just for testing. Then start up the player, watch the boot log, and when you see these lines:
start_empire: Starting Empire...
IrDA: Registered device irda0
Then you can try to beam something over. The line:
irlap_driver_rcv(), Unknown frame ef received!
usually means that some other program was trying to use the irda port, in this case the player application. For some reason that I don't fully understand, Empire cannot be started until AFTER the player app has been started. This is the reason for the start_empire script, it just sleeps for x seconds then starts empire after the player has (presumably) started.
After you have verified that Palantir/Empire works with the delay setting at 30 or 60, then you can narrow it down to probably 11 or 12.
Mark Cushman
#162509 - 23/05/2003 06:32 Re: Palantir / Empire Install Difficulty [Re: cushman]
Ezekiel
Loc: NH USA
I upped it to 30 and for good measure, changed the @exec order in my config.ini (putting ttsclock first) and now it works. Killer. Thanks man!
-Zeke
WWFSMD?
#162510 - 23/05/2003 06:38 Re: Palantir / Empire Install Difficulty [Re: Ezekiel]
cushman
Loc: Erie, CO
If you changed the exec order, you could probably stick it back at 10 or 11 and it would work just fine now.
The only disadvantage of having it set to 30 though is that you have to wait 30 seconds from startup to beam.
Mark Cushman
#162511 - 23/05/2003 06:52 Re: Palantir / Empire Install Difficulty [Re: cushman]
Ezekiel
Loc: NH USA
I set it back to 11 (just because 'this one goes to eleven') and as you predict, it's still working.
Kewl.
This warms my geek heart to no end.
-Zeke
WWFSMD?
#162512 - 23/05/2003 17:46 Re: Palantir / Empire Install Difficulty [Re: cushman]
SE_Sport_Driver
Would database size effect this because the player takes longer to boot up? Or does the database only get loaded after the player ap has started?
I'm wondering if some of us that have a lot of songs will need to have a longer wait time for Empire to start..
#162513 - 04/06/2003 15:37 Re: Palantir / Empire Install Difficulty [Re: SE_Sport_Driver]
cushman
Loc: Erie, CO
Palantir already has the song database on the Palm device, that is what uploading the .pdb file does.
All Empire does (on the Empeg) is listen for FID's and insert them into the playlist, it has no idea what it's inserting, really.
Mark Cushman
#162514 - 04/06/2003 15:57 Re: Palantir / Empire Install Difficulty [Re: cushman]
SE_Sport_Driver
I just meant that players with larger databases take longer to boot up. And if it's critical that Empire start after the player starts, would the database size effect how long the "wait" has to be set to...
#162515 - 04/06/2003 18:00 Re: Palantir / Empire Install Difficulty [Re: SE_Sport_Driver]
cushman
Loc: Erie, CO
Ah yes, you're right. If you do have a HUGE database, you may need to crank the wait time on start_empire to 11. Because you CAN.
Mark Cushman
#162516 - 04/06/2003 18:41 Re: Palantir / Empire Install Difficulty [Re: cushman]
SE_Sport_Driver
Not sure if this is "huge" or not...
#162517 - 04/06/2003 21:20 Re: Palantir / Empire Install Difficulty [Re: SE_Sport_Driver]
cushman
Loc: Erie, CO
Good, then you can test it! Do you have start_empire set to 10 or 11?
Does it ever give you problems by not starting up in time?
Mark Cushman
#162518 - 17/08/2003 09:51 Re: Palantir / Empire Install Difficulty [Re: cushman]
Lupo
Loc: AC, Germany
Hi,
I have problems when trying to run the palantir PDB application; I doubleclick on the .jar file and winRAR opens it as an archive. I have downloaded and installed Java (from the link on your hp), but still, it doesn't work as it should. In total desperation, I copied the .jar file onto my mobile (Siemens S55), and there I can start it as a Java app, but then get an error that my mobile hasn't an FPU
Am I doing something wrong?
#162519 - 17/08/2003 10:00 Re: Palantir / Empire Install Difficulty [Re: Lupo]
cushman
Loc: Erie, CO
Your file associations have been changed by WinRAR. Re-associate .jar files with the java program, and it will work correctly.
Go to Windows Explorer, then click on Tools -> Folder Options. Then click on the File Types tab. After that, scroll to the file type JAR, and click Advanced. Click on the "open" action, then click Edit. Under Application used to perform action:, put this line in:
javaw.exe -jar "%1"
When you installed a Java Runtime Environment, this was the default setting, but you must have installed WinRAR afterwards (or let WinRAR modify your file settings). Alternately, you could re-install your JRE, run PalantirPDB from a command line, or write a batch file that would run PalantirPDB using javaw.exe -jar.
Mark Cushman
#162520 - 17/08/2003 13:19 Re: Palantir / Empire Install Difficulty [Re: cushman]
Lupo
Loc: AC, Germany
Hi,
I just messed around a bit; and finally got it working I just reinstalled a newer JRE and everything was fine.
I installed "empire" on the empeg, it seems to start somewhat, but after the 10 seconds, I get this:
Vcb: 0x4054d000
/usr/local/bin/empire: error in loading shared libraries: libopenobex-1.0.so.0:
cannot open shared object file: No such file or directory
Kinda strange to me, my /bin directory just looks as the example on your homepage; where did I go wrong?
#162521 - 17/08/2003 13:26 Re: Palantir / Empire Install Difficulty [Re: Lupo]
It can't find the OBEX libraries, did you install them properly? Look at step 4 on installation part two here
#162522 - 17/08/2003 15:24 Re: Palantir / Empire Install Difficulty [Re: tman]
Lupo
Loc: AC, Germany
Hi,
if I just re-copy them from my pc to the empeg following the instruchtions, do I need to delete the old files on the empeg first?
Will try it tomorrow.
#162523 - 17/08/2003 16:55 Re: Palantir / Empire Install Difficulty [Re: Lupo]
You'll have to delete the old lib files before as otherwise ln will fail. Or just change it to "ln -sf" instead of "ln -s" and it'll overwrite them.
#162524 - 18/08/2003 09:11 Re: Palantir / Empire Install Difficulty [Re: tman]
Lupo
Loc: AC, Germany
Hi,
it worked! Nice app!
just a question (I am a complete linux newbie): What does the "ln -s"-command do, and what changes with the "f"?
#162525 - 18/08/2003 09:19 Re: Palantir / Empire Install Difficulty [Re: Lupo]
ln creates a link between files and is used so you only need one copy of a file/directory even if you need it in more than one place. The -s bit makes it a symbolic link which basically means you can see the link when you do a ls. The -f means force and it'll overwrite any existing file.
#162526 - 18/08/2003 09:52 Re: Palantir / Empire Install Difficulty [Re: tman]
Lupo
Loc: AC, Germany
Ok thanks, I think I got it!
#162527 - 05/10/2003 08:51 Re: Palantir / Empire Install Difficulty [Re: Lupo]
Lupo
Loc: AC, Germany
Hello,
It's me again...since 2 days I observed a strange beaviour: I beam a playlist on the empeg and everything goes just like it should, empeg tells empire made a new playlist, but in reality nothing happens; I still have the old playlist going. Am I doing anything wrong without noticing it?
#162528 - 05/10/2003 12:54 Re: Palantir / Empire Install Difficulty [Re: Lupo]
cushman
Loc: Erie, CO
What is the setting in the Playlist screen in Palantir? It can either be Enqueue, Append or Replace. Are you appending the songs to your playlist?
Mark Cushman
#162529 - 05/10/2003 13:22 Re: Palantir / Empire Install Difficulty [Re: cushman]
Lupo
Loc: AC, Germany
Hi,
I tried the 3 options; but got no "response" from the player...Like I'm listening to a playlist with 450 songs; I beam one with 19 songs and I want palantir to replace the current one with the new and the player sticks to the one with 450 songs; although it displayed that it got the correct instructions from the palm. Very strange...
#162530 - 05/10/2003 13:36 Re: Palantir / Empire Install Difficulty [Re: Lupo]
cushman
Loc: Erie, CO
Please be clear. You say you have a playlist on your Empeg of 450 songs. You set the Playlist beam option to Replace (upper right hand corner). Then you select 19 songs on the Palm using Palantir, point the Palm at your Empeg, and press Beam on the playlist screen. Then the Palm brings up the beam dialog, the beam dialog ends, then your Empeg displays the message "19 Songs in playlist", but the playlist stays with the same 450 songs?
Can you do this while looking at the serial output of your player? This might give me more clues as to what your problem is. Also, has anything changed recently? Did it work before? Did you install any new software? Have you upgraded Palantir but not Empire, or vice versa? Did you upload new tunes onto your player but not put a new .pdb file on your Palm?
Mark Cushman
#162531 - 05/10/2003 16:08 Re: Palantir / Empire Install Difficulty [Re: cushman]
Lupo
Loc: AC, Germany
Yey, this is exactly what is happening. (sorry, if I didn't express myself clearly, my english is somewhat rudimental )
Yes, the program worked. I had a littlebit of trouble getting it to work (see my earlier posts in this thread) but then it finally worked flawless. The database on the palm is up-to-date with the files on the empeg; so that's not the cause. The only thing I did was to delete "emptris" and the corresponding line in the config.ini; do you think that could be the cause of my problem?
No secondary hard disk
Starting player
player starting with "-s-" flag
hijack_exec("/programs0/empacman"), rc=0 (okay)
hijack_exec("/bin/bash -c "/usr/local/bin/start_empire 10 &""), rc=0 (okay)
hijack: removed menu entry: "Tuner RDS Control"
empacman running as pid 18
start_empire: sleeping for 10 seconds...
empacman running as pid 24
/etc/preinit.d/M20emptris: /programs0/emptris: No such file or directory
/etc/preinit.d/M30emptriv: /programs0/emptriv/emptriv: No such file or directory
Vcb: 0x4054d000
This line is what I get in Hyperterminal when sending a playlist with one song:
#000001010
I guess that is the id of the track?
Thank you for trying to help me; I won't have internet access for the next week; so you don't need to hurry on this one
#162532 - 05/10/2003 18:44 Re: Palantir / Empire Install Difficulty [Re: Lupo]
cushman
Loc: Erie, CO
This is your problem. The player is starting up "disconnected" from the serial port, and will not take commands from any app over serial (which Empire uses to append/replace/enqueue songs). You should upgrade to the latest version of Hijack, and make sure that you aren't giving the serial port to an app (like gpsapp). The Hijack menu option: "Serial Port Assignment" should be set to the player, not applications.
Mark Cushman
#162533 - 05/10/2003 19:09 Re: Palantir / Empire Install Difficulty [Re: cushman]
Micman2b
Loc: Central, NC, USA
I have a problrm with Palantir every once in a while. After the second or third time or so that i beam a list to the empeg I can no longer beam anymore playlists. A reboot of the empeg always helps. Only a slight inconvenience however.
Sean in NC
_____________
Sean in NC
130gb MK2a w/ 32mb ram
80gb MK2a empeg spare
#162534 - 05/10/2003 19:31 Re: Palantir / Empire Install Difficulty [Re: cushman]
Lupo
Loc: AC, Germany
now that was quick
Yep, that was it; I must have messed around...
Thank you so much!
Edited by Lupo (05/10/2003 19:47)
