#161184 - 13/05/2003 06:15 frozen in Aux in
Whodat
Hi - read through the faq and tried to search this forum and couldnt find my specific problem. Screwing around with the player and got it in Aux in while its sitting on my desk here. It is sitting in "waiting" mode and I cant get it out with any remote button or the panel buttons. I tried to reinstall the firmware with no success. Suggestions are appreciated.
#161185 - 13/05/2003 09:25 Re: frozen in Aux in [Re: Whodat]
Do any of the front panel buttons respond to your input? For example, can you bring up the main menu? If so, what happens when you select "Source"?
You said you reinstalled the firmware. What version of the firmware?
#161186 - 13/05/2003 10:16 Re: frozen in Aux in [Re: tfabris]
Whodat
I have 2.0 consumer image, none of the front buttons respond. Thanks for the reply.
#161187 - 13/05/2003 10:27 Re: frozen in Aux in [Re: Whodat]
Wow, that's interesting. So when you unplug it and plug it back in again, it boots into Aux mode and then stays stuck there with the buttons non-responsive? Interesting.
Are you by any chance using Hijack and setting it so that it switches to the Aux input when the mute line goes high?
If not, get a boot log and post it here. Let's see if there's any odd errors coming up.
#161188 - 13/05/2003 11:20 Re: frozen in Aux in [Re: tfabris]
foxtrot_xray
Loc: Atlanta, Georgia
I had a very similar problem with my FIRST player. Support ended up having to replace the whole thing.
To get it unstuck, try this:
Get to a shell prompt over the serial connecton, and run the player manually with the option to ignore persist data. That always seemed to get it for me. Of course, you lose your volumne and current playlist as well..
Me.
#161189 - 13/05/2003 11:22 Re: frozen in Aux in [Re: tfabris]
foxtrot_xray
Oh, and it had nothing to do with HiJack - my old player did it with and without HiJack installed.
As far as I can remember, there were no error-messages on the boot-log, however, the player process itself ran extremely high. Load averages topped 8.0 across the board.
(Now, thinking of it, I think that on mine, at least, you COULD get into the Hijack menu..)
#161190 - 13/05/2003 12:00 Re: frozen in Aux in [Re: Whodat]
Whodat
Well I am glad I have you all interested lol. I will work on that bootlog for you now. In the meantime I can tell you I have 0 3rd party software installed. Just the regualr old Consumer image 2.0
Well that was easier than I expected here is the log from when I powered up the unit (which I can only do by unplugging it btw)
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #12 Tue Apr 1 18
empeg-car player (hardware revision 9, serial number 40104301)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
ttyS00 at 0xf8010000 (irq = 15) is a
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005200).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHM2100AT, ATA DISK drive
hda: FUJITSU MHM2100AT, 9590MB w/2048kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:c
d
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...hange_root: old root has d_count=1
Freeing unused kernel memory: 4k init player.cpp : 385:empeg-car 2.00 20
03/04/01.
Vcb: 0x4086d000
Edited by Whodat (13/05/2003 12:11)
#161191 - 14/05/2003 08:43 Re: frozen in Aux in [Re: Whodat]
Whodat
Today I loaded Beta 2.13 and it seems to have reset the system and is working fine - thanks for your help let me know if you have any questions about what went wrong.
#161192 - 14/05/2003 09:09 Re: frozen in Aux in [Re: Whodat]
Ezekiel
Loc: NH USA
I wonder if part of the 2.0 consumer/final file was corrupted during download causing the strange behavior you saw? Others here can probably comment on the probability of this guess being right.
Glad it's going now.
-Zeke
WWFSMD?
