#16099 - 30/08/2000 10:57
Micro http server.
Loc: TX, USA
I have compiled a really small web server from here,and attached it.If you have installed the ftp server from this post,then all you need to do is add the following line to the following files. /etc/services micro_http 80/tcp # Micro HTTP server
/etc/inetd.conf micro_http stream tcp nowait nobody /bin/micro_httpd micro_httpd /
and do the following (in my example micro_http's new name is 9ae0):
rw cp /drive0/fids/9ae0 /bin/micro_http chmod ugo+x /bin/micro_http cd / tar -xvzpf /drive0/fids/9aa0 usr/bin/tail ro
restart/start inetd
However, I am not connected to the network at the moment, but testing from the command line seems to work.
2-15103-micro_httpd (230 downloads)
#16100 - 30/08/2000 20:10
Re: Micro http server.
[Re: hamzy]
Loc: TX, USA
Sigh, it looks like the default is text/plain so you cannot transfer the real mp3 files (ex: 1000) without making the default binary. I'll have to fix that. It also looks like I got some of the instructions wrong. They should be: /etc/services micro_httpd 80/tcp # Micro HTTP server /etc/inetd.conf micro_httpd stream tcp nowait root /bin/micro_httpd micro_httpd /
and do the following (in my example micro_httpd's new name is 9ae0):
rw cp /drive0/fids/9ae0 /bin/micro_httpd chmod ugo+x /bin/micro_httpd cd / tar -xvzpf /drive0/fids/9aa0 usr/bin/tail ro restart/start inetd
#16101 - 30/08/2000 20:17
[Re: hamzy]
Loc: San Francisco, CA
...will this server automatically transfer mp3's that've been symbolically linked? the default ftp server in that package doesn't:( -mark
...proud to have owned one of the first Mark I units
#16102 - 02/09/2000 03:52
[Re: dionysus]
I wrote the following script to build .mp3 filenames from the fids directory, maybe it's useful to others?
#!/bin/bash
for fid in `ls /drive0/fids/*1` do mp3file=`echo $fid | mawk '{printf("%s\n",substr($0,0,length))}'`
echo "mp3file: $mp3file"
ln $mp3file"0" "`grep title $fid | cut -f2 -d'='`.mp3" echo `grep title $fid | cut -f2 -d'='`
done
I hard link the files as I am running micro_http in a chrooted Debian system.
The only problem I have is that the webserver doesn't handle space chars in filenames/URLs, I have tried both Netscape and IE clients (IE replaces spaces with ), still no luck.
Works fine for filenames with no spaces though.
Philb
#16103 - 02/09/2000 06:42
[Re: philb]
...Pretty much the same as Bobo's slightly-altered script here: #!/bin/sh # bobo's dirty wrapper script # u15097@hs-harz.de
# target dir for symlinks: target="/drive0/mp3s"
files=`ls -1 *0`
for i in $files do fidname=$(echo $i | sed s/.$/1/) mp3name=$i album=$(cat $fidname | grep -i source= | sed s/source=//i) title=$(cat $fidname | grep -i title= | sed s/title=//i) artist=$(cat $fidname | grep -i artist= | sed s/artist=//i) if !(test -d "$target/$album/"); then mkdir "$target/$album/" fi verz=$(pwd) echo "creating symlink: /$album/$title.mp3" ln "$verz/$mp3name" "$target/$album/$artist - $title.mp3" done
...the problem w/ hardlinking comes into play with two-drive empeg's..half my music is in one drive, the other half is on the other.. and unfortunately, some of the tags/fids are even split, with the music being on one partition, and the tag info being on the other.. (that part's actually easy to fix.. ) if the web server followed symbolic links though, you could compile the list in one place and the web browser shouldn't know the differnce...
I don't know though; am I the only person who gets nervous opening an http server on a public/fast IP connection?:) -mark
#16104 - 02/09/2000 08:40
[Re: hamzy]
Does someone know why I get the Error below, when i make a http request to my empeg? ---- Index of ./ sh: tail: command not found ----
It seems that the shell can't find tail, but I installed it in usr/bin. Anyone have some hint's?
thank's Mirko
.: i love my empeg!!
#16105 - 02/09/2000 08:57
[Re: Blacksun]
looks like you're missing/don't have in your path the tail command.. -mark
MK2: 36gb Tivo 90gb Computer: 120gb disk space ...I think drive manufactureres love me!
#16106 - 02/09/2000 11:05
[Re: dionysus]
it seems all ok. My Path settings look like that: PATH=/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/sbin:/empeg/bin
and the tail command is in /usr/bin -rwxr-xr-x 1 root root 17028 Feb 21 1999 tail
Where do you have your tail command?
thank's Mirko
#16107 - 02/09/2000 15:14
[Re: dionysus]
Loc: TX, USA
It looks like it does. However, it still defaults to text which is a bad, bad, bad thing!
/me slaps micro_httpd
#16108 - 02/09/2000 15:17
[Re: Blacksun]
Loc: TX, USA
Can you run tail from the command line? Ex: empeg:/# tail /etc/passwd blah:blah:blah empeg:/#
#16109 - 02/09/2000 17:31
[Re: dionysus]
Loc: Canberra, Australia
Another (perhaps better) usage of a micro HTTP server on an empeg would be to be a MP3 stream server - e.g. shoutcast. Anyone had a look at the protocol specs for that? It'd have to be integrated into the player s/w too to either smash the stream down to some desired smaller bitrate (I don't know if the streaming protocols support VBR) or re-encode the raw audio. WinAmp can do it, but it's probably a floating point encoder or something.
Any possibilities?
Save the whales. Feed the hungry. Free the mallocs.
#16110 - 03/09/2000 03:35
[Re: PaulWay]
We have lots of shoutcast experience.
#16111 - 03/09/2000 13:26
[Re: hamzy]
I can run tail from the command prompt.
empeg:/# tail /etc/group root:*:0: ftp:*:1: nogroup:*:2:nobody tty:*:5: empeg:/#
Is there a permission problem?
.:Mirko
#16112 - 03/09/2000 19:20
[Re: rob]
Loc: TX, USA
#16113 - 03/09/2000 19:50
[Re: hamzy]
Loc: TX, USA
Ok. I made one change. If it sees "/fids/" in the path and the filename ends in "0", it will say that its an mp3 file. It looks like it already handles filenames that end in "mp3".
Now, keep in mind that this is only one of many web servers out there. I would like to see more ported to the empeg.
2-15752-micro_httpd.tgz (110 downloads)
#16114 - 03/09/2000 19:58
[Re: Blacksun]
Loc: TX, USA
Could be. Do you know how to tell? But /etc/inetd.conf says the micro_httpd will run as root, so if you can execute tail from the command line, I don't know what is wrong. Try this. Type: micro_httpd / <and hit enter> get / 1.0 <and hit enter> <hit enter>
You should see something like this:
HTTP/1.0 200 Ok Server: micro_httpd Date: Mon, 04 Sep 2000 21:53:45 GMT Content-type: text/html Last-modified: Sun, 03 Sep 2000 22:04:17 GMT Connection: close
<HTML><HEAD><TITLE>Index of ./</TITLE></HEAD> <BODY BGCOLOR="#99cc99"><H4>Index of ./</H4> <PRE> drwxr-xr-x 1024 Sep 3 20:25 <A HREF="bin/">bin/</A> drwxr-xr-x 1024 Sep 2 09:14 <A HREF="dev/">dev/</A> drwxr-xr-x 1024 Sep 4 20:59 <A HREF="drive0/">drive0/</A> drwx------ 1024 Jun 2 1999 <A HREF="drive1/">drive1/</A> drwxr-xr-x 1024 Jun 23 14:09 <A HREF="empeg/">empeg/</A> drwxr-xr-x 1024 Sep 2 20:55 <A HREF="etc/">etc/</A> drwxr-xr-x 2048 Sep 2 20:47 <A HREF="lib/">lib/</A> drwxr-xr-x 12288 Aug 4 14:57 <A HREF="lost+found/">lost+found/</A> drwxr-xr-x 1024 Jun 2 1999 <A HREF="mnt/">mnt/</A> dr-xr-xr-x 0 Sep 4 10:53 <A HREF="proc/">proc/</A> lrwxrwxrwx 3 Aug 4 14:57 <A HREF="sbin">sbin</A> -> bin/ lrwxrwxrwx 10 Aug 4 14:57 <A HREF="swapfile">swapfile</A> -> ./dev /hda6 drwxrwxrwx 1024 Sep 4 21:50 <A HREF="tmp/">tmp/</A> drwxr-xr-x 1024 Sep 3 20:04 <A HREF="usr/">usr/</A> drwxr-xr-x 1024 Sep 2 14:31 <A HREF="var/">var/</A> </PRE> <HR> <ADDRESS><A HREF="http://www.acme.com/software/micro_httpd/">micro_httpd</A></AD DRESS> </BODY></HTML>
#16115 - 04/09/2000 00:50
[Re: hamzy]
I'm not sure what the plans are with respect to shoutcast and the car player, or what the licencing issues are (if any). Hugo would be a better person to comment on this.
#16116 - 04/09/2000 09:14
[Re: Blacksun]
This looks as if you have a script that pipes some other command's output to tail, the whole shebang being executed by sh, and sh has not been told to continue on single error. You should look at the command you are feeding tail with. One of the few remaining Mk1 owners... #00015
#16117 - 13/10/2000 07:01
[Re: rob]
Loc: Ipswich, MA
Hugo... Any comments on this old post? I just showed a friend the displayserver (Found here) running on my empeg. And he asked about streaming the audio. It would seem that this has been done by Empeg Ltd. with the diamond rio home player. What about the Empeg..... Any plans to add this to the player software? Say while it's on a home network stream it out to a player or a PC?? John
___
John Turner
"It's easier to ask for forgiveness than to ask for permission"
#16118 - 14/10/2000 09:25
[Re: jwtadmin]
No immediate plans for such streaming, though it may get added in a future version; it'd be nice for 128k ricochet users ;)
#16119 - 16/10/2000 06:27
[Re: altman]
Loc: Denmark, Kbh Ø
what about that the empeg can conect to a streaming service and play it, as there is no radio avalible while it is sitting on your desk.
Mark wait for mk III with a USB Host/slave (USB->GPS)(USB->Bluetooth)(USB->You name it)
Mark
#16120 - 17/10/2000 05:39
[Re: altman]
Loc: BaWue, Germany, Europe
If I remeber correctly there is an arm icecast .deb.
How hard would it be to let the player stream to a (pseudo) "input"-device or a fifo? And then just use shout to ... well, shout.
MKII 08000073 40GB BLUE
