Page 2 of 2 < 1 2
#160879 - 10/05/2003 20:08 Re: empeg self started while in my docking station [Re: tfabris]
Laura
Loc: Greenhills, Ohio
Ok, now that I am done painting for the night I'll give it a go and report back.
Laura
MKI #017/90
whatever
#160880 - 10/05/2003 20:41 Re: empeg self started while in my docking station [Re: Laura]
Laura
I installed Hijack, had to read how to edit config.ini again (been so long I forgot) and I have hyperterminal open and waiting.
And as I was writing this it woke up and started so here is what happened. So what does this mean?
Poll wait
Poll fail
Vcb: 0x4086d000
Poll wait
Poll fail
16743: IA1:0000000b,dk=00ffffff,dr=0,lk=0
16743: IA2:0000000b.P,dk=00ffffff,dr=0,lk=0
16743: ENQ.I: @c0124cc8: 0000000b.0
16744: DEQ.I: @c0124cc8: 0000000b.0
16744: ENQ.P: @c0124e54: 0000000b.0
Wakeup
Wakeup
Poll ok
16745: DEQ.P: @c0124e54: 0000000b.0
Poll wait
Poll fail
16748: IA1:00fffffe,dk=00ffffff,dr=0,lk=0
16748: IA2:00fffffe.P,dk=00ffffff,dr=0,lk=0
16748: ENQ.I: @c0124cd0: 00fffffe.0
16749: IA1:00ffffff,dk=00ffffff,dr=0,lk=0
16749: IA2:00ffffff.P,dk=00ffffff,dr=0,lk=0
16750: DEQ.I: @c0124cd0: 00fffffe.0
16750: ENQ.P: @c0124e5c: 00fffffe.0
Wakeup
Wakeup
Wakeup
Poll ok
16752: DEQ.P: @c0124e5c: 00fffffe.0
Poll wait
Poll fail
16860: IA1:0000000a,dk=00ffffff,dr=0,lk=0
16860: IA2:0000000a.P,dk=00ffffff,dr=0,lk=0
16860: ENQ.I: @c0124cd8: 0000000a.0
16861: DEQ.I: @c0124cd8: 0000000a.0
16861: ENQ.P: @c0124e64: 0000000a.0
Wakeup
Wakeup
Poll ok
16862: DEQ.P: @c0124e64: 0000000a.0
Poll wait
Poll fail
Laura
MKI #017/90
whatever
#160881 - 11/05/2003 06:54 Re: empeg self started while in my docking station [Re: Laura]
Did all of that happen AFTER it woke up?
I'd like to see the entire sequence from when you put the player into standby, if possible.
#160882 - 11/05/2003 07:03 Re: empeg self started while in my docking station [Re: mlord]
Laura
Ok, will do.
Laura
MKI #017/90
whatever
#160883 - 11/05/2003 07:03 Re: empeg self started while in my docking station [Re: Laura]
Oh, and in answer to "what does it mean", here's the button presses that the player sees from the sequence you posted:
0000000b = KnobLeft
00fffffe = IR_FAKE_INITIAL <--- internally generated by hijack
0000000a = KnobRight
#160884 - 11/05/2003 07:12 Re: empeg self started while in my docking station [Re: mlord]
Laura
Here is a bootup sequence of it now.
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v334 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Sat Apr 26 10:31:47 EDT 2003
empeg-car player (hardware revision 9, serial number 40103872)
Command line: mem=16m
Memory: 14996k/16M available (996k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
IrCOMM protocol (Dag Brattli)
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005980).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: IC25T060ATCS05-0, ATA DISK drive
hda: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: IC25T060ATCS05-0, 57231MB w/1768kB Cache, CHS=7296/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:2
0
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
khttpd: listening on port 80
kftpd: listening on port 21
Poll wait
Poll fail
Vcb: 0x4086d000
1306: IA1:00fffffe,dk=00ffffff,dr=0,lk=0
1306: IA2:00fffffe.P,dk=00ffffff,dr=0,lk=0
1306: ENQ.I: @c0124cc8: 00fffffe.0
1307: IA1:00ffffff,dk=00ffffff,dr=0,lk=0
1307: IA2:00ffffff.P,dk=00ffffff,dr=0,lk=0
1307: DEQ.I: @c0124cc8: 00fffffe.0
1308: ENQ.P: @c0124e54: 00fffffe.0
Wakeup
Wakeup
Wakeup
Poll ok
1310: DEQ.P: @c0124e54: 00fffffe.0
Poll wait
Poll fail
2334: IA1:00000006,dk=00ffffff,dr=0,lk=0
2334: IA2:00000006.P,dk=00ffffff,dr=0,lk=0
2334: ENQ.I: @c0124cd0: 00000006.0
2335: DEQ.I: @c0124cd0: 00000006.0
2335: ENQ.P: @c0124e5c: 00000006.0
Wakeup
Wakeup
Poll ok
2336: DEQ.P: @c0124e5c: 00000006.0
Poll wait
Poll fail
2355: IA1:00000007,dk=00000006,dr=0,lk=0
2355: IA2:00000007.R,dk=00000006,dr=0,lk=0
2355: ENQ.I: @c0124cd8: 00000007.0
2356: DEQ.I: @c0124cd8: 00000007.0
2356: ENQ.P: @c0124e64: 00000007.0
Wakeup
Wakeup
Poll ok
2358: DEQ.P: @c0124e64: 00000007.0
Poll wait
Poll fail
2846: IA1:00000002,dk=00ffffff,dr=0,lk=0
2846: IA2:00000002.P,dk=00ffffff,dr=0,lk=0
2846: ENQ.I: @c0124ce0: 00000002.0
2847: DEQ.I: @c0124ce0: 00000002.0
2847: ENQ.P: @c0124e6c: 00000002.0
Wakeup
Wakeup
Poll ok
2848: DEQ.P: @c0124e6c: 00000002.0
Poll wait
Poll fail
2864: IA1:00000003,dk=00000002,dr=0,lk=0
2864: IA2:00000003.R,dk=00000002,dr=0,lk=0
2864: ENQ.I: @c0124ce8: 00000003.0
2865: DEQ.I: @c0124ce8: 00000003.0
2865: ENQ.P: @c0124e74: 00000003.0
Wakeup
Wakeup
Poll ok
2867: DEQ.P: @c0124e74: 00000003.0
Poll wait
Poll fail
2887: IA1:00000002,dk=00ffffff,dr=0,lk=0
2887: IA2:00000002.P,dk=00ffffff,dr=0,lk=0
2887: ENQ.I: @c0124cf0: 00000002.0
2888: DEQ.I: @c0124cf0: 00000002.0
2889: ENQ.P: @c0124e7c: 00000002.0
Wakeup
Wakeup
Poll ok
2890: DEQ.P: @c0124e7c: 00000002.0
Poll wait
Poll fail
2905: IA1:00000003,dk=00000002,dr=0,lk=0
2905: IA2:00000003.R,dk=00000002,dr=0,lk=0
2905: ENQ.I: @c0124cf8: 00000003.0
2907: DEQ.I: @c0124cf8: 00000003.0
2907: ENQ.P: @c0124e84: 00000003.0
Wakeup
Wakeup
Poll ok
2908: DEQ.P: @c0124e84: 00000003.0
Poll wait
Poll fail
2926: IA1:00000002,dk=00ffffff,dr=0,lk=0
2926: IA2:00000002.P,dk=00ffffff,dr=0,lk=0
2926: ENQ.I: @c0124d00: 00000002.0
2928: DEQ.I: @c0124d00: 00000002.0
2928: ENQ.P: @c0124e8c: 00000002.0
Wakeup
Wakeup
Poll ok
2930: DEQ.P: @c0124e8c: 00000002.0
Poll wait
Poll fail
2943: IA1:00000003,dk=00000002,dr=0,lk=0
2943: IA2:00000003.R,dk=00000002,dr=0,lk=0
2943: ENQ.I: @c0124d08: 00000003.0
2944: DEQ.I: @c0124d08: 00000003.0
2944: ENQ.P: @c0124e94: 00000003.0
Wakeup
Wakeup
Poll ok
2946: DEQ.P: @c0124e94: 00000003.0
Poll wait
Poll fail
2966: IA1:00000002,dk=00ffffff,dr=0,lk=0
2966: IA2:00000002.P,dk=00ffffff,dr=0,lk=0
2966: ENQ.I: @c0124d10: 00000002.0
2967: DEQ.I: @c0124d10: 00000002.0
2967: ENQ.P: @c0124e9c: 00000002.0
Wakeup
Wakeup
Poll ok
2969: DEQ.P: @c0124e9c: 00000002.0
Poll wait
Poll fail
2983: IA1:00000003,dk=00000002,dr=0,lk=0
2983: IA2:00000003.R,dk=00000002,dr=0,lk=0
2983: ENQ.I: @c0124d18: 00000003.0
2985: DEQ.I: @c0124d18: 00000003.0
2985: ENQ.P: @c0124ea4: 00000003.0
Wakeup
Wakeup
Poll ok
2987: DEQ.P: @c0124ea4: 00000003.0
Poll wait
Poll fail
3035: IA1:00000006,dk=00ffffff,dr=0,lk=0
3035: IA2:00000006.P,dk=00ffffff,dr=0,lk=0
3035: ENQ.I: @c0124d20: 00000006.0
3036: DEQ.I: @c0124d20: 00000006.0
3036: ENQ.P: @c0124eac: 00000006.0
Wakeup
Wakeup
Poll ok
3037: DEQ.P: @c0124eac: 00000006.0
Poll wait
Poll fail
3055: IA1:00000007,dk=00000006,dr=0,lk=0
3055: IA2:00000007.R,dk=00000006,dr=0,lk=0
3055: ENQ.I: @c0124d28: 00000007.0
3056: DEQ.I: @c0124d28: 00000007.0
3056: ENQ.P: @c0124eb4: 00000007.0
Wakeup
Wakeup
Poll ok
3057: DEQ.P: @c0124eb4: 00000007.0
Poll wait
Poll fail
Poll wait
Poll fail
I have it in standby now and will post when it wakes up which won't take it long.
Laura
MKI #017/90
whatever
#160885 - 11/05/2003 08:13 Re: empeg self started while in my docking station [Re: Laura]
Good.
Note that those ever-increasing numbers that prefix most lines are timestamps, in 100ths of a second.
When it wakes up again, you may note a huge gap in timestamps between earlier messages and the ones after it woke up.
I need to see all of the messages spanning that gap -- the two or three immediately beforehand, and everything afterwards.
#160886 - 11/05/2003 08:15 Re: empeg self started while in my docking station [Re: mlord]
Oh, I'm heading out for a long hike to a remote geocache.. might not be back for a while, but please post away!
#160887 - 11/05/2003 08:24 Re: empeg self started while in my docking station [Re: mlord]
Neat. I've only been geocaching twice but it was a good laugh each time. Luckily it was a nice day on both times.
You going to leave anything cool?
- Trevor
#160888 - 11/05/2003 08:25 Re: empeg self started while in my docking station [Re: mlord]
Laura
Usually it wakes right back up but it has decided that it is tired. Have fun and I'll post whatever it says
Laura
MKI #017/90
whatever
#160889 - 11/05/2003 11:59 Re: empeg self started while in my docking station [Re: tman]
Well, I picked up an E.T. toy, that probably has a tiny camera hidden inside, and left a hunting knife & scabbard that I found near another local cache last fall.
#160890 - 11/05/2003 12:26 Re: empeg self started while in my docking station [Re: mlord]
Laura
You're back and my empeg is still sleeping on the job. It figures that before I couldn't get it 'not' to turn itself on. I'm leaving it hooked up until he awakens even though I'd like to have it play right now.
Laura
MKI #017/90
whatever
#160891 - 11/05/2003 12:37 Re: empeg self started while in my docking station [Re: Laura]
Greetings!
A thought - could having an open, well behaved connection on the serial port change the results of the test?
Since we know that the player watches for serial commands as well as the remote / IR control, maybe the serial port (if there is a stray signal) would wake the player as well??? Perhaps it is not the IR control pathway that is in question, but the serial port?
Since this test involves having an active, well behaved serial connection active, maybe it is either changing the circumstances of the bug or the bug is in the serial port sending the signal instead of the IR, as originally thought.
One possible way to check this would be to disconnect the display board from the main board completely, and see if it still happens with nothing on the serial port. That would take the IR signal path out of the loop completely...
A thought.
Edit - reread the whole thread and saw that the bug happened with a serial link connected. So that is not it.
Edited by pgrzelak (11/05/2003 12:39)
#160892 - 11/05/2003 13:26 Re: empeg self started while in my docking station [Re: pgrzelak]
Laura
It's toying with me. Since I said I could easily recreate the bug, it's going to prove me wrong. Don't you hate when that happens
Laura
MKI #017/90
whatever
#160893 - 11/05/2003 13:39 Re: empeg self started while in my docking station [Re: Laura]
Greetings!
The only way to get a bug to perform on command is to say "watch this"...
#160894 - 12/05/2003 04:44 Re: empeg self started while in my docking station [Re: pgrzelak]
Laura
I left it on hyperterminal over night but it never turned itself on. Maybe the problem went away as fast as it appeared. If it starts happening again I'll post a log, in the meantime, I'm going to listen to it
Laura
MKI #017/90
whatever
Page 2 of 2 < 1 2
