#160550 - 08/05/2003 16:46
Fixing that HD cable!
Loc: Berkshire, UK
Okay, for the fifth time in as many months, I've been getting that damn "No hard disk found contact support" message, and each time it's been because the cable has slipped loose from the primary drive.
What is the best way I can prevent this in future? Bearing in mind that I'm only about 3GB (~6 months, I guess) from needing a new primary drive, I don't particularly want to have to super-glue it in place. Is there any sensible way I can fix it more securely, yet leave it still simple to remove when I next upgrade?
Thanks,
Bryan.
#160551 - 08/05/2003 16:54
Re: Fixing that HD cable!
[Re: BryanR]
Duct tape?
#160552 - 08/05/2003 16:57
[Re: BryanR]
Hot-melt glue should work fine.
#160553 - 08/05/2003 17:01
yup, glue gun. quick and easy, and easy to remove.
#160554 - 08/05/2003 17:51
[Re: loren]
In fact this was done at the factory on all later units.
#160555 - 08/05/2003 23:27
[Re: BryanR]
Loc: Stockport, UK
bend all the pins ever-so-slightly on the HDD so you get a tighter grip on the cable connector. The pins must obviously remain straight enough to enter its respective 'lead in' chamfer on the cable connector.
Not sure if this method is solid enough to get a FAQ entry, but at least you dont have to start shooting hot glue everywhere
#160556 - 09/05/2003 01:34
[Re: pgrzelak]
Loc: Berkshire, UK
I haven't got a glue gun, so I'll give the tape a try.
Ta,
Bryan.
#160557 - 09/05/2003 05:44
[Re: BryanR]
Hot-melt glue guns are only about $5 or so.. and useful for lots of other stuff, too!
#160558 - 09/05/2003 05:59
...and I was half joking about the duct tape. It will work, but hot glue is a much better solution for long term.
#160559 - 09/05/2003 07:24
[Re: BryanR]
An alternative to hot glue would be a silicone rubber sealer such as Ratshack sell. It'll take a lot longer to cure though.
I'm sure that Home Depot type places sell something suitable as well, but make sure that you don't use something like 'plumbers goop' that is a bit 'permanent'.
But as Mark said, hot glue guns are cheap.
#160560 - 09/05/2003 08:09
[Re: genixia]
Most of the stuff that you get for kitchen and bathroom use produces acetic acid (vinegar) when curing. So make sure you get one that doesn't. It's not strong acid but it's best not to have it near the electronics.
- Trevor
#160561 - 09/05/2003 09:53
[Re: BryanR]
I haven't got a glue gun, so I'll give the tape a try. Do the glue. Hot glue guns are the second best invention in the world next to the empeg, you should definitely own one just for the sake of owning one. And as far as "how to do it" goes, the Drive Upgrade Guide has a very clear video of exactly how to do it. I highly recommend you look at it.
Another thing to consider is the way the drive cable is folded and positioned inside the player. If it's being pulled loose all the time, maybe it simply needs to be creased a little differently so it doesn't constantly have that pulling stress on it.
#160562 - 09/05/2003 17:17
[Re: genixia]
Don't do this.
The silicone sets up and holds too strongly, making it nearly impossible to remove the cable without damaging it.
I speak from experience, here.
#160563 - 10/05/2003 08:02
Loc: Berkshire, UK
Okay, okay, everyone, I get the point - I need a hot glue gun! Down to Maplins it is, then...
Thanks for your advice.
Bryan.
#160564 - 10/05/2003 08:35
Which brand was that?!
#160566 - 12/05/2003 17:33
[Re: genixia]
I don't recall, now. But perhaps I mis-spoke somewhat; I don't think it was pure silicone RTV sealant, but some sort of silicone goop for repairing running shoes. Whatever it was, it sticks really well to just about everything.
#160568 - 12/05/2003 17:57
A man's not well dressed if his shoes are a mess.
