Page 1 of 3 1 2 3 >
#159212 - 05/05/2003 19:37 MKl hard drive upgrade help
Laura
Loc: Greenhills, Ohio
Ok, this is what I have got from hyper terminal, what does it mean?
empeg-car v0.04 19990121 (altman@empeg.com)
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux........................ done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #9 Tue Apr 1 18:47:56 BST 2003
Processor: Intel StrongARM-1100 revision 9
empeg-car player (hardware revision 4, serial number 00017)
Command line: mem=8m
Memory: 7324k/8M available (580k code, 20k reserved, 264k data, 4k init)
Dentry hash table entries: 1024 (order 1, 8k)
Buffer cache hash table entries: 8192 (order 3, 32k)
Page cache hash table entries: 2048 (order 1, 8k)
Linux NET4.0 for Linux 2.2
Starting kswapd v 1.5
Signature is ffffffff 'ÿÿÿÿ'
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg remote control/panel button support initialised (Using FIQs).
empeg usb initialised, USBN9602 revision 1
empeg state support initialised 0089/8893 (save to d0005180).
empeg RDS driver initialised
empeg power state driver initialised
Linux video capture interface: v1.00
empeg FM radio driver (Philips).
empeg dual channel IDE
Probing primary interface...
No drives found, retrying...
hda: IC25N080ATMR04-0, ATA DISK drive
Registering drives...
ide0 at 0x040-0x047,0x078 on irq 7
hda: IC25N080ATMR04-0, 76319MB w/7884kB Cache, CHS=9729/255/63
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
VFS: Can't find an ext2 filesystem on dev ide0(3,4).
Tried to mount /dev/hda4 as ext2 but got error 22
No primary hard disk
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComplùStarti
ng player
! tags.cpp : 61:Failed to open tags (0xc0041002).
Prolux 4 empeg car - 2.1425 Mar 26 2003
Vcb: 0x4028d000
Laura
MKI #017/90
whatever
#159213 - 05/05/2003 19:38 Re: MKl hard drive upgrade help [Re: Laura]
It means you have one working 80GB hard drive, with nothing on it yet (?)
EDIT: actually, there IS something on it.. I just missed the partition check first time I looked. Does it work?
Edited by mlord (05/05/2003 19:39)
#159214 - 05/05/2003 19:40 Re: MKl hard drive upgrade help [Re: mlord]
Laura
Well, then that is good, that's what it has. But for some reason emplode will not open so I wasn't sure. It keeps giving me that "performing illegal operation" crap.
Laura
MKI #017/90
whatever
#159215 - 05/05/2003 19:41 Re: MKl hard drive upgrade help [Re: Laura]
Mmm.. have you run the diskbuilder .upgrade on that drive to prepare it for Empeg use?
#159216 - 05/05/2003 19:48 Re: MKl hard drive upgrade help [Re: mlord]
Laura
Yes but I wasn't sure if it ran right or not. Maybe I should try again?
Laura
MKI #017/90
whatever
#159217 - 05/05/2003 19:49 Re: MKl hard drive upgrade help [Re: Laura]
Might as well.. the music partitions /dev/hda4 does not appear to have been completely created on it.
#159218 - 05/05/2003 19:52 Re: MKl hard drive upgrade help [Re: mlord]
Laura
Applying it again now. I'll let you know how it goes.
Laura
MKI #017/90
whatever
#159219 - 05/05/2003 19:58 Re: MKl hard drive upgrade help [Re: mlord]
Laura
Ok, here is what it said after reapplying the builder image.
Freeing unused kernel memory: 4k initVFS: Can't find an ext2 filesystem on dev i
de0(3,4).
mount: wrong fs type, bad option, bad superblock on /dev/hda4,
or too many mounted file systems
warning: can't open /etc/mtab: No such file or directory
umount: /drive0: not mounted
Making first drive...
mke2fs 1.14, 9-Jan-1999 for EXT2 FS 0.5b, 95/08/09
hda4 is mounted.
no room for private writable mapping
error: -12
/dev/hda4: Memory allocation failed while setting up superblock
hdstress.cpp 189 ( 14): Poll result=0 on fd=5
Stressing /dev/hda: Spinning down.
Stressing /dev/hda: Spinning up.
Speed checking /dev/hda3
Read/write of 8Mb took 7.47 seconds
Drive length is 156301488 blocks, seek testing
Seek test complete: 38.00 seconds.
Read/write of 8Mb took 7.54 seconds
e000 v1.04
Copying kernel...
empeg state support initialised 0089/8893 (save to d0005080).
Partition check:
Mounting proc
ng player
Vcb: 0x4028d000
e000 v1.04
Copying kernel...
empeg state support initialised 0089/8893 (save to d0005100).
e000 v1.04
Copying kernel...
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
Partition check:
Mounting proc
Tried to mount /dev/hdc4 but got error 15
Press 'q' now to go into development mode. You Have Zero Seconds To ComStarting
player
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
e000 v1.04
Copying kernel...
Partition check:
Mounting proc
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting
player
! tunedb_disk.cpp :1224:Database size mismatch error.
Prolux 4 empeg car - 2.1425 Feb 7 2002
Vcb: 0x4028d000
e000 v1.04
Copying kernel...
Partition check:
Mounting proc
ng player
Vcb: 0x4028d000
Read/write of 8Mb took 7.50 seconds
Seek test complete: 38.31 seconds.
Laura
MKI #017/90
whatever
#159220 - 05/05/2003 20:06 Re: MKl hard drive upgrade help [Re: Laura]
Ouch:
hda4 is mounted.
error: -12
Basically, it ran out of memory (Mk1 has only 8MB) while trying to create the filesystem for the music partition. The drive is just plain too big for the diskbuilder.
I suppose one might be able to create the filesystem "by hand", with parameters that require less memory. But first, try the Mk2 diskbuilder on it in a mk2 machine (ugh!). Once that succeeds (it will), then install the Mk1 .developer image onto it.
If all that fails, we'll have to do it the "hard way".
Cheers (?)
#159221 - 05/05/2003 20:16 Re: MKl hard drive upgrade help [Re: mlord]
Laura
Ah, I must be the first to try and put an 80GB in the MKl. I'll have to wait until tomorrow night to try and build the disk in the MKll first. I'll update the thread then.
I'm glad to know that it isn't a problem with the hard drive itself.
edit: Thanks for the help Mark
Edited by Laura (05/05/2003 20:18)
Laura
MKI #017/90
whatever
#159222 - 05/05/2003 22:55 Re: MKl hard drive upgrade help [Re: Laura]
Good idea. That should work. Run the builder with the drive in a Mk2, reapply the mk2 developer upgrade while it's still in the Mk2 so you don't fry whatever disk you plug into the Mk2 afterward, then plug it into the Mk1 and apply developer Mk1 onto it on its first powerup. Tricky, but I think it'll work.
Mark, that was a quick diagnostic. Cool. Nice catch.
Does this not bode well for the Mk1 in terms of upgrades? Or could code tweaks to the mk1 version of the builder image take care of it? As I recall, the builder images are going to need an update to allow bigger than 127gb anyway, maybe we can bribe the right people with curry and/or beer?
#159223 - 06/05/2003 02:09 Re: MKl hard drive upgrade help [Re: tfabris]
Ouch!
Sorry about all the trouble. I have been recommending the 80GB drives - I did not know that they would not build "new, out of the packet" on a Mark 1.
#159224 - 06/05/2003 03:18 Re: MKl hard drive upgrade help [Re: pgrzelak]
Laura
That's ok. I consider it an honor to get to be the first to experiment with getting an 80GB working in the MKl, I like a challenge.
Laura
MKI #017/90
whatever
#159225 - 06/05/2003 03:47 Re: MKl hard drive upgrade help [Re: Laura]
Would it be possible to build a swap partition first and have the builder software be able to key off that? I would think that the partitions themselves can be built easily by the builder code, it is just the new filesystem generation that seems to be locking up.
It would probably require a rebuild of the builder software in order to get it to use swap, though...
A thought...
#159226 - 06/05/2003 03:48 Re: MKl hard drive upgrade help [Re: tfabris]
Oh 'eck. I suppose we have run mkswap by that stage, so we could enable swap for making the music partition.
I'd be worried, though, that a Mark 1 won't have enough memory for the size of database occasioned by 80 or 160 gigabytes of music...
#159227 - 06/05/2003 04:02 Re: MKl hard drive upgrade help [Re: peter]
Laura
Do you know what the largest size drive that it could handle with the memory that it has?
Laura
MKI #017/90
whatever
#159228 - 06/05/2003 04:14 Re: MKl hard drive upgrade help [Re: Laura]
That would likely depend on the number of files, the amount of compression, etc. From what I have seen, and if this is a good estimate, my 120GB of music only generates a database file of about 2.5MB.
Now, I don't know what other memory is in use, but I would be interesting to find out...
#159229 - 06/05/2003 05:25 Re: MKl hard drive upgrade help [Re: pgrzelak]
Ah. Laura could have a problem then. A Mark 1 has a total of 2.5M available for caching and database. If the database alone is larger than that, the player will not start. If the database is larger than about 1.75M, there will be so little cache that the player can never spin the disk down.
#159230 - 06/05/2003 07:35 Re: MKl hard drive upgrade help [Re: pgrzelak]
The immediate limit here is not the number of files (which is currently ZERO when it fails), but the memory that the filesystem maker wants.
By doing the diskbuilder in a Mk2, this step will be avoided, and a subsequent Mk1 consumer image (or developer) .upgrade would complete the install... will probably even work!
THEN the database and file counts become the new limit.
#159231 - 06/05/2003 07:35 Re: MKl hard drive upgrade help [Re: Laura]
Hi, I put a 60gb in my Mark 1 a couple of months ago and ran across this problem. What I did do (and posted about it here) was to just run builder in the Mark II and put the drive back in the M1, apply player, and all is well.
#159232 - 06/05/2003 07:37 Re: MKl hard drive upgrade help [Re: mlord]
I believe that Paul's post was in response to Peter's:
#159233 - 06/05/2003 07:40 Re: MKl hard drive upgrade help [Re: wfaulk]
Oops. Yes. I read the BBS in flat mode, as opposed to threaded. I keep forgetting about that...
#159234 - 06/05/2003 07:40 Re: MKl hard drive upgrade help [Re: Laura]
Here's an easy thing to try, if you have not already simply moved the disk to a Mk2 for the diskbuilder step:
Install the Mk1 developer image, with the disk still in the Mk1. This will fail at some point, but ignore it. Then, reboot the player with the serial link hooked up, and hit 'q' or 'control^C' to quit back to a shell prompt.
From the shell prompt, try:
mkswap /dev/hda6
swapon /dev/hda6
mke2fs /dev/hda4
<--- Peter can tell us the exact parameters to use here
Then reboot and see what happens.
Edited by mlord (06/05/2003 07:41)
#159235 - 06/05/2003 07:42 Re: MKl hard drive upgrade help [Re: mlord]
I always prefer a software solution than digging out a screwdriver and allen wrench.
#159236 - 06/05/2003 10:26 Re: MKl hard drive upgrade help [Re: peter]
Well, if they encode everything as WAV or 320cbr, then probably no big deal.
#159237 - 08/05/2003 05:31 Re: MKl hard drive upgrade help [Re: mlord]
In theory, you can solder 4 more RAM chips onto a Mk1 on the underside, then enable them in the SA1100 and tell linux it has a full 16MBytes. I've not tried it, but it definitely should work. Not sure what the player would make of it, as it wouldn't be expecting a Mk1 to have that much ram...
#159238 - 08/05/2003 10:25 Re: MKl hard drive upgrade help [Re: mlord]
Laura
I've been busy and haven't tried it yet but I should get around to it this weekend. I'll go ahead and try building the drive in the MKll first. As I only have enough songs at the moment to fill a little more than half the space, hopefully the database won't be too big for the memory to handle.
Laura
MKI #017/90
whatever
#159239 - 08/05/2003 20:23 Re: MKl hard drive upgrade help [Re: altman]
Hugo, in your wildest imaginings, when you were designing the Mark I did you ever think the day would come when people would be trying to cram 80 GB (or even 160 GB) of storage into it?
#159240 - 10/05/2003 15:51 Re: MKl hard drive upgrade help [Re: tanstaafl.]
No, but we did want to allow the player to be fully expanded. The factory didn't like the pads on the bottom of the boards (like the mk1) as they kept getting shorted during flow soldering of the through-hole parts... so we had to take them off for the mk2.
Thinking back, maybe the ring-o-lights is less useful than the option of taking a mk2a to 48Mbytes (6 chips)
#159241 - 10/05/2003 17:08 Re: MKl hard drive upgrade help [Re: altman]
I don't know about that. The ring-o-lights is a very nice feature...
By the way, did you get the drive built?
Page 1 of 3 1 2 3 >
