#15777 - 28/08/2000 20:25 The synchronisation process failed during stage 2
hamzy
Loc: TX, USA
The synchronisation process failed during stage 2: Error 0xfffffff8
When I mount the root partition as r/w with the rw command and
make the following symbolic link:
When I do the following commands, I can reproduce this:
rw
ln -s /proc/mounts /etc/mtab
ro
logout
Emplode->Sync
Error!
Why I did this is because it makes the df command work. Ex:
before
empeg:/bin# df
df: cannot read table of mounted filesystems: No such file or directory
after
empeg:/bin# df
Filesystem 1k-blocks Used Available Use% Mounted on
/dev/root 15863 6976 8887 44% /
/dev/hda4 17463360 10801739 6661621 62% /drive0
#15778 - 29/08/2000 03:32 Re: The synchronisation process failed during stage 2 [Re: hamzy]
"Doctor, it hurts when I do this."
We know that it doesn't work. We have no immediate plans to fix it. It's a problem in either fsck, or df.
#15779 - 29/08/2000 07:13 Re: The synchronisation process failed during stage 2 [Re: Roger]
hamzy
Loc: TX, USA
Ahhh...
Didn't know if you knew or not ;)
#15780 - 29/08/2000 23:39 Re: The synchronisation process failed during stage 2 [Re: Roger]
bonzi
I would not bother, either. One can simply write a 3-line script to wrap df with creation and deletion of that symlink.
However, what about that missing command that checks whether filesystem is mounted (I don't have unit here now, but I think you know what I am talking about, I think it was already reported - I will try to provoke it again if you don't). I saw it once spying on serial while sync was done on Ether. Not that it seems to matter, either, since my unit dutyfully fscks every 20 or so syncs...
Dragi "Bonzi" Raos
Zagreb, Croatia
#15781 - 31/08/2000 04:15 Re: The synchronisation process failed during stage 2 [Re: bonzi]
mac
Loc: Cambridge, UK
It's just a safety feature in fsck - there's no missing command. It's just trying to see if the file system is mounted readwrite to determine if you're going to do something stupid by fsck'ing it.
Mike Crowe
I may not be speaking on behalf of empeg above :-)
Mike Crowe
