#157400 - 27/04/2003 13:39 New Downloads
edsmiata
Loc: New Jersey
Is it at all possible, after downloading a new block of music, to figure out which of the songs in Emplode have just been downloaded, after the downloading has been finished?
The Rio definately being a labor of love, I have set up oplaylists alphabetically by artist A-E, etc. then all of the A's, the B's and so on......if I downlod a bunch of new songs, how can i be sure that when I update my playlist that I have captured ALL of the songs that I have downloaded???
Thanks,
Ed
#157401 - 27/04/2003 13:51 Re: New Downloads [Re: edsmiata]
When you use the word "Download" do you mean "added to the player"? Usually download refers to grabbing files off the player, not adding them.
I'm going to proceed under the assumption that you mean new songs you just added to the player, and answer the question from that point of view:
- Select "All Tracks" from the left-hand pane in Emplode.
- Select View/Details from the menu.
- Select View/Colums.
- Check the box next to "Created" and click "Move Up" enough times so that it will appear among the visible columns on your screen.
- Click on OK.
- Click on the column header for the column "Created". This will sort by that column. You can choose to have it sort upwards or downwards by clicking on it.
Now the screen shows the songs in the order they were added to your player. The songs that were just added are now either at the top of the list or the bottom of the list depending on whether it has been sorted upwards or downwards.
#157402 - 27/04/2003 15:36 Re: New Downloads [Re: tfabris]
lectric
Loc: New Orleans, LA
it sounds like he means downloaded off the net.
#157403 - 27/04/2003 16:30 Re: New Downloads [Re: tfabris]
edsmiata
Loc: New Jersey
download is from the PC to rio
#157404 - 27/04/2003 16:56 Re: New Downloads [Re: edsmiata]
Ah, that's upload. Download is the opposite (there's even a menu named "Download" in Emplode.
Anyway, I got it right, so those instructions count.
#157405 - 27/04/2003 17:23 Re: New Downloads [Re: tfabris]
edsmiata
Loc: New Jersey
O-TAY!
Thanks for the help
#157406 - 28/04/2003 19:51 Re: New Downloads [Re: tfabris]
- Check the box next to "Created" and click "Move Up" ...
- Click on OK.
- Click on the column header for the column "Created"...
Or if you don't want to go through all of that, set your shuffle to "Newest Additions" and press the "down" button three times.
