#153969 - 07/04/2003 19:59 Problems w/ ir_translate since upgrade to 2.0
xn00dlesx
Ive upgraded to ver 2.0 and from HiJack 302 to the latest 329. Once I did this my knobleft and knobright definitions in config.ini stopped working. Here is what I had:
[ir_translate]
KnobRight=Visual+.N,KnobRight.U
KnobLeft=Info.N,KnobLeft.U
For some reason this no longer works. Does it have anything to do with the new .V parameter? And If someone could post how to make KnobLeft do Visual- instead that would RULE!!
Thanx dudes!
#153970 - 07/04/2003 20:03 Re: Problems w/ ir_translate since upgrade to 2.0 [Re: xn00dlesx]
Your KnobLeft probably still works, but maybe not, because the KnobRight is what's causing the problem, and it comes first in your file.
I got rid of the Visual+ name, replaced it with Visual/NextVisual and PrevVisual (new!).
#153971 - 07/04/2003 20:13 Re: Problems w/ ir_translate since upgrade to 2.0 [Re: mlord]
xn00dlesx
OMG! That was the fastest reply I have ever seen. And you were right as always!! Woot, ive been waiting a long time for the PrevVisual command.
Thanx Mark!
#153972 - 07/04/2003 20:15 Re: Problems w/ ir_translate since upgrade to 2.0 [Re: xn00dlesx]
But rather than using either Next/Prev Visual, I recommend VisualSeek instead. It's on the Hijack PopUp0 menu by default, but you can put it on any button/menu you like. Use the knob and/or next/prev track to cycle through the visuals with it.
#153973 - 07/04/2003 20:17 Re: Problems w/ ir_translate since upgrade to 2.0 [Re: xn00dlesx]
xn00dlesx
Oh yeah, one more thing. How could I get:
Knob=Info.N,Knob.U
to work without interferring with entering the HiJack menu?
#153974 - 07/04/2003 20:18 Re: Problems w/ ir_translate since upgrade to 2.0 [Re: xn00dlesx]
Time to discover "PopUp"s, if you haven't already.
