Page 2 of 4 < 1 2 3 4 >
#153342 - 30/05/2003 22:10 Re: TTSClock r7 [Re: Ezekiel]
adavidw
Loc: Utah, USA
SuhWeeT! I want SB in my empeg.
Has anybody tried this yet? Is there some piece of software that could perhaps extract the sounds out of the Strong Bad Clock?
-Aaron
#153343 - 01/06/2003 20:01 Re: TTSClock r6 [Re: DomoKun]
Gazz
Loc: Alice Springs - Australia
What's the sexiest voice to use with TTS Clock and is there any way to get it to speak the time other than at Ingition, what would be cool is a button in my car that fires TTS Clock (stops the music, speaks the time starts the music) I guess I could ask my Girlfriend to record some custom voice files, has anybody done that?
Gazz.
#153344 - 02/06/2003 05:23 Re: TTSClock r7 [Re: adavidw]
Ezekiel
Loc: NH USA
Can it be done more elegantly than getting SB to say the time 71 times for each 'mood' and then do .wav file editing? Mr. Bad may let use use the sounds if we ask really nicely...
-Zeke
WWFSMD?
#153345 - 22/06/2003 23:42 Re: TTSClock r7 [Re: Ezekiel]
Anyone ever persue getting the StrongBad voice for TTSClock?
#153346 - 23/06/2003 06:04 Re: TTSClock r7 [Re: drakino]
Well he IS a member here... Shouldn't be too tough to get him in the studio to record some samples...
I have 90% of the sbemails in MP3 format on my empeg, but I think we'd be hard pressed to get good clock-worthy samples from them...
#153347 - 23/06/2003 07:07 Re: TTSClock r7 [Re: tonyc]
Did you see the StrongBad clock application in the first post of this thread?
#153348 - 23/06/2003 07:13 Re: TTSClock r7 [Re: wfaulk]
Evidently not...
#153349 - 03/07/2003 23:17 Re: TTSClock r7 [Re: tonyc]
JeepBastard
Loc: Brooklyn
Everyone laffs at me now that my car radio says
"All Automotive systems are nominal. All Clear. Prepare To Drive" after it says the time and date.
my current blog
#153350 - 11/07/2003 01:10 Re: TTSClock r7 [Re: JeepBastard]
PKi
Loc: Poland
How to upload the clock to an MK1 player ???
MK I - 00158
#153351 - 11/07/2003 02:28 TTSClock with alpha3 [Re: DomoKun]
303
Loc: Germany
does anyone have tested it with the alpha 3 version?
#153352 - 11/07/2003 04:39 Re: TTSClock with alpha3 [Re: 303]
mtempsch
Yep,
initially had TTS Clock installed on 2.0/Hijack334, upgraded to 3.0a3 and tossed the latest Hijack (340) onto that - works fine.
#153353 - 11/07/2003 06:34 Re: TTSClock with alpha3 [Re: mtempsch]
303
Loc: Germany
thanxx Michael!
now i just have to learn how to install it???
#153354 - 11/07/2003 10:37 Re: TTSClock with alpha3 [Re: mtempsch]
mcomb
Loc: San Carlos, CA
Hmm, hijack still works with the v3 alphas? I thought we where supposed to get upgraded to a 2.4 kernel (with ext3 support and updated drivers) as part of 3.0. Did that not make it?
-Mike
#153355 - 11/07/2003 10:51 Re: TTSClock with alpha3 [Re: mcomb]
mtempsch
Not sure what the plan was/is, or what's hidden below (haven't had time to look very much at it), but Hijack 340 works fine with 3.0a3, just as Mark said at the meet.
#153356 - 17/07/2003 01:12 Re: TTSClock r6 [Re: DomoKun]
303
Loc: Germany
is there any other sound format that can be used instead of PCM?
thanxx
#153357 - 18/07/2003 01:32 Re: TTSClock r6 [Re: DomoKun]
Nobbie
Loc: Herts, UK
This is a great add on, now running hi-jack 3.40, 2.00, and the TTS r7. Nearly pulled my hair out as it wouldn't work, but then decided to open my eye and read the DEVELOPER version is needed. All sorted now though, as like everyone else with it, i'm looking for sound files.
What about Knight Rider Kit??
'Good Morning Michael'
Getting Old.
#153358 - 19/07/2003 09:18 Re: TTSClock r6 [Re: Nobbie]
JeepBastard
Loc: Brooklyn
I already added a small thingie to the script to play random voice files on start up. it's quite nice.
my current blog
#153359 - 19/07/2003 11:28 Re: TTSClock r6 [Re: JeepBastard]
ilDuce
cool..... anything you would consider posting on the ttsclock page?... I have some cool movie sounds that would be perfect to have just before the time telling part...
edit: sorry JeepBastard... somehow i thought you were the original author of the ttsClock..... anyways.... anything you would like to release to the public?
Edited by ilDuce (19/07/2003 11:30)
#153360 - 20/07/2003 08:52 Re: TTSClock r6 [Re: ilDuce]
JeepBastard
Loc: Brooklyn
just add a line to ttsclock script such as
cat /drive0/var/tts/start.pcm | /drive0/var/pcmplay
where start.pcm is the audio file you want to play after the time starts. you do it more elegantly, I'll post the one that selects a random audio file later today. I added as an atttachment to this post the one i use that I like a lot as an example.
169945-start.pcm (186 downloads)
my current blog
#153361 - 20/07/2003 13:58 Re: TTSClock r6 [Re: JeepBastard]
ilDuce
cool.... thanks.... allthough.... your attachment didnt work.... I would really like to see the random script..... how you´ve done it....
I thought about it earlier today.... And I guess you have done so that I have to declare all PCM´s that I want randomized?...
No automatic searchstrings or something like that?...
I have quite alot of files that I would like to get randomized... But then again... I have to convert all of them to 44,1 kbps i guess? and I also have to convert them from wav to pcm.... bummer.... but what the hell..... What wouldnt I do to hear quotes from conan the barbarian every time I reboot the player...=)
#153362 - 20/07/2003 23:51 Re: TTSClock r6 [Re: ilDuce]
DomoKun
Loc: Pennsylvania
I used to have start up sounds a while ago before I made the TTS Clock script. If you just want a single start up sound you can add a hijack config.ini entry like this (assuming you have TTS Clock installed which installed pcmplay for you):
;@EXEC_ONCE /drive0/var/pcmplay < /drive0/var/startupsound.pcm
For random sounds, you can create a bash script like this:
#!/bin/sh
number=$RANDOM
let "number %= 7"
case "$number" in
'0')
/drive0/var/pcmplay < /drive0/startup/shortcircuit.pcm
'1')
/drive0/var/pcmplay < /drive0/startup/welcome.pcm
'2')
/drive0/var/pcmplay < /drive0/startup/playgame.pcm
'3')
/drive0/var/pcmplay < /drive0/startup/homeranykey.pcm
'4')
/drive0/var/pcmplay < /drive0/startup/homer7dohs.pcm
'5')
/drive0/var/pcmplay < /drive0/startup/hal9000.pcm
'6')
/drive0/var/pcmplay < /drive0/startup/butthead.pcm
esac
Save the bash script as a unix style text file, give it permissions, and also call it from a config.ini entry.
Also if you do this, it would be a pretty good idea to run setvol from the config.ini before any of the custom sounds, as you probably don't want the volume to be 0 or 100%:
;@EXEC_ONCE /drive0/var/setvol
#153363 - 21/07/2003 14:38 ....Like a heart attack [Re: drakino]
Mach
Loc: Texas, USA
Heads up...TTSClock StrongBad files. I couldn't do anything about the date unless someone has the date wavs. I think you'll like it just the same.
Install TTSClock per the original instructions and before resetting to RO
Move the PCM files from the zip to your drive0\var\tts directory and the ttsclock file to drive0\var\ directory
reset to RO
This will replace the original am, pm, thetimeis, and ttsclock files.
Let me know if you get it working. I had a heck of time editing the file.
#153364 - 21/07/2003 16:28 Re: ....Like a heart attack [Re: Mach]
Ezekiel
Loc: NH USA
Yes!
Woohoo!
-Zeke
WWFSMD?
#153365 - 21/07/2003 16:49 Re: ....Like a heart attack [Re: Ezekiel]
loren
oh man i can't wait to get home and try this.
|| loren ||
#153366 - 21/07/2003 18:31 Re: ....Like a heart attack [Re: Ezekiel]
cmcdonald
You legend... works for me!!
#153367 - 21/07/2003 22:53 Re: ....Like a heart attack [Re: Mach]
DomoKun
Loc: Pennsylvania
Awesome.
#153368 - 21/07/2003 23:47 Re: ....Like a heart attack [Re: DomoKun]
Mach
Loc: Texas, USA
Cool, glad to hear it worked. Enjoy.
#153369 - 22/07/2003 08:54 Re: ....Like a heart attack [Re: Mach]
ilDuce
coool!!!..... thanks!......
#153370 - 23/07/2003 02:06 Re: ....Like a heart attack [Re: Mach]
adavidw
Loc: Utah, USA
This is seriously awesome. Now all we need is someone to whip up a good SB boot logo.
-Aaron
#153371 - 23/07/2003 10:29 Re: ....Like a heart attack [Re: Mach]
Ahh, thank you. I'll get around to installing this once I track down my box of cables in the garage.
Moving sucks. At least now I don't have to worry about moving again for a long while.
