#153045 - 04/04/2003 16:39
Re: 80GB HD in empeg!
[Re: Roger]
Loc: Lochcarron and Edinburgh
...the databases don't matter -- they can be rebuilt...
True, but it's quicker to copy than to rebuild them. Worked for me, anyway.
#153046 - 04/04/2003 23:03
[Re: image]
can i delete the *1 fids and tell emplode/emptool to rescan the tags?
No. emplode/emptool don't look at the ID3 tags once the files are on the player. They deal entirely with the *1 files (actually, they read from /empeg/var/database and write to the *1 files).
Moreover, if you delete the *1 file, this is equivalent to deleting the *0 file -- emplode/emptool will treat that FID as unused, and will overwrite it the next time that you upload some new music.
If you were to port ID3 tagging to the player, it would be of very little use, unless you planned to retrieve the files from the player -- since once the files are on the player, nothing uses the ID3 tags.
I guess if you were using Hijack to stream from the player, it would be quite useful, though.
Anyway, if you're going to port ID3 tagging to the player, just make your app update the *1 files (and rebuild the databases) while it's there.
#153047 - 04/04/2003 23:06
[Re: SE_Sport_Driver]
these are a lot thinner than those
Cool. I was keeping my eye out for the 60Gb Toshiba, but nobody seems to have any in stock. Maybe I'll look for the 80Gb disks instead. There's probably a large price premium on them at the moment, though.
#153048 - 05/04/2003 01:32
[Re: tman]
Loc: Swindon, UK
the new 80gb is 9.5mm which is the same size as the 40gb toshiba gas (which I have in another device). Not sure about the 60gb tosh.
Andy
MK2a 60GB Amber 040103916 32mb/Light Kit
MK2a 50GB Amber 030102560 32mb
#153049 - 05/04/2003 04:57
Heat question
Greetings!
I don't want to raise concerns, but has anyone else dealing with the 80s noticed that they run a bit warm? Taking the drives out and swapping them around, I notice that they are quite warm (I don't have any accurate way of getting a temperature estimate - warm / hot to the touch, where you can handle them, but don't want to hold them for too long without letting them cool down).
Keep in mind, I don't do this that often, and this might be normal. Also, the drives in question had been copying data non-stop for 15 hours or so, with the player sitting in a wooden docking station.
Okay... checking the specs, the 80s are slightly lower power and operating noise. It might just be that I am not used to it.
#153050 - 05/04/2003 05:11
Re: Heat question
[Re: pgrzelak]
...the drives in question had been copying data non-stop for 15 hours or so,...
Your drives are warm from the constant copying, no doubt about it. I imagine with regular Empeg use they will be even cooler than the previous drives because they operate at lower power. (though I don't think it will be possible to feel the difference)
#153051 - 05/04/2003 05:17
Re: Heat question
[Re: BartDG]
Good. I thought it shouldn't be a problem, but I just wanted to get a reality check.
#153052 - 05/04/2003 06:46
Re: Heat question
[Re: pgrzelak]
Mmm.. if it worries you much, then the fan speed in your docks can be adjusted -- disconnect the power, pop off the bottom panel (4 screws), and look inside for a potentiometer (variable resistor) soldered to one of the pins on the power jack. Space is tight, so be careful not to mess anything up. The pot can be adjusted with a tiny slotted screwdriver inserted into the middle slot. A small twist goes a long way.
#153053 - 05/04/2003 07:00
Re: Heat question
Greetings!
Oh, it is not a problem during normal operation. The players have been through a lot of use recently - they are on their third and final batch of drives now. They have been copying files solidly for days now. I will keep that in mind, though. Good to know if I need to adjust in the future.
Edit: Cool! Promoted!
Edited by pgrzelak (05/04/2003 07:00)
#153054 - 05/04/2003 08:03
Re: Heat question
[Re: pgrzelak]
Yeah. The first two docks I built (#002 is in circulation, #001 is being saved to raffle off at a future Empeg meet) had fixed resistor values. After those, I switched to variable resistors to allow field adjustment for warmer environments. Here in the GWN is probably not the best place for calibrating the fans..
Edited by mlord (05/04/2003 08:05)
#153055 - 05/04/2003 08:26
Re: Heat question
Very cool Mark! That's great to know! Maybe you could add a note about this on your page incase anyone needs it in the future?
Don't listen to me, I'm a hoser.
#153056 - 05/04/2003 08:46
Re: Heat question
Too much work for me, so, like, take off, eh!
#153057 - 05/04/2003 13:05
Loc: Wellingborough, UK
The problem is with software and hardware engineers redefining the meaning of the SI prefixes (mega, giga, etc). The IEEE and IEC have tried to rectify the situation, but few have adoped their recomendations.
In essence, this standardization means that the hard drive manufacturers have got it right and the memory manufacturers haven't.
Funny thing is, IT professionals usually pride themselves on adapting to change. I doubt we will be able to walk into a PC World or Staples and ask for 1 Gibibyte of memory any time soon without some very blank looks from the staff.
#153058 - 06/04/2003 07:27
Loc: Dallas Texas USA
I am just in awe that you guys actually have that much music.
Carl Aydelotte
Dallas Texas USA
empeg MKII 080000506 40gb-green
#153059 - 06/04/2003 07:57
[Re: avatarTX]
Loc: Virginia, USA
I am just in awe that you guys actually have that much music. ditto
#153060 - 06/04/2003 08:14
[Re: kswish0]
Actually what amazes me is that when the Mk. 1 empeg came out, you could get it in 2GB, 4GB and 6GB capacities! IIRC
That may be one reason the empeg didn't sell more units. It was ahead of its time in more ways than one (and still is) but the HD manufacturers weren't caught up yet. I remember thinking that a 10GB model would only store a small fraction of my music, and only if I encoded at 128kps. But knowing how easy it was to add a HD was a major factor in me buying one.
#153061 - 06/04/2003 15:34
Greetings!
Finished. It took all weekend, but I now have 37.3GB free on the player! I have room to expand again!!! Now, I just need to wait for Harry Potter 5 to come out...
