#150324 - 25/03/2003 12:18 Emplode + drive upgrade problem
I just put a second drive in my empeg. The first drive was full. Obviously, the new drive was empty.
Now, a good portion (I'd say at least half) of the time, when I upload new music, emplode fils to upload a single song, claiming that the drive is too near capacity. This song is never the first song. When I go back and re-add the song, it works fine.
#150325 - 25/03/2003 12:32 Re: Emplode + drive upgrade problem [Re: wfaulk]
Added to the bugbase now, Bug 1900.
#150326 - 25/03/2003 13:35 Re: Emplode + drive upgrade problem [Re: wfaulk]
I'd be happy, personally, to move files around to even out the distribution, not that the problem shouldn't be fixed. (I realize that it's potentially outside the scope of traditional support, but it feels like a one-liner.)
What are the restrictions on moving files between the two drives, if any?
#150327 - 25/03/2003 13:38 Re: Emplode + drive upgrade problem [Re: wfaulk]
There are no restrictions. Any *0 or *1 fid can live on either drive; nothing in the player will get confused if you move stuff from one fids directory to the other.
#150328 - 25/03/2003 13:41 Re: Emplode + drive upgrade problem [Re: peter]
To be perfectly clear, not even matching *0 and *1 files need be on the same drive, right?
Does a synchronization need to occur after this, or does the player itself know to look in both places?
#150329 - 25/03/2003 13:41 Re: Emplode + drive upgrade problem [Re: peter]
I'm wondering if it'd be useful for Bitt to just leave it as-is... in case you want to try to fix it at the Emplode or Player level before 2.0 final... (to have him test it)
#150330 - 25/03/2003 13:47 Re: Emplode + drive upgrade problem [Re: wfaulk]
Right.
The player looks in both places every time. You don't need to sync.
#150331 - 25/03/2003 13:55 Re: Emplode + drive upgrade problem [Re: tfabris]
Oooh, good thinking Batman. At the very least, Bitt, could you let me know exactly how much space you've got left ("df /drive0 ; df /drive1")? I'm not sure I'll get round to sending custom builds out, though; unless there's something obviously wrong with the disk-full code, I'm very uninclined to meddle with it at this stage of the game. In normal use it's effectively impossible to have one drive full and the other empty.
#150332 - 25/03/2003 14:03 Re: Emplode + drive upgrade problem [Re: peter]
I agree, and, as such, it's not a big bug. I just thought I'd report it for completeness's sake.
I don't have a proper serial cable here, unfortunately, so it'll have to wait 'til I get home.
#150333 - 25/03/2003 20:48 Re: Emplode + drive upgrade problem [Re: peter]
empeg:/empeg/bin# df -k /drive0 /drive1
df: Warning: cannot read table of mounted filesystems
Filesystem 1k-blocks Used Available Use% Mounted on
- 11694088 11668660 25428 100% /drive0
- 9724804 1185822 8538982 12% /drive1
