#149418 - 20/03/2003 17:24
What's a good disk space usage graphing tool?
Does anyone have a link to a free tool that will quickly show me which folders on my hard disks are taking up the most disk space?
For instance, let's say I'm down to a few hundred megs on drive c: and I want do do some cleanup. I don't mind deinstalling programs, but I'd love to be able to see a graph of which folders on drive C are taking up the most space, and would therefore get me the most bang for my buck in terms of which programs to deinstall.
An example of the sort of thing I'm looking for is here (look at the second screen shot), but that link is for an Access 2000 application. I'm looking for a straight windows-app that doesn't piggyback off of Access.
Anyone got a good one they know about or use?
#149419 - 20/03/2003 17:53
Re: What's a good disk space usage graphing tool?
I regularly use TreeSize Pro.
It displays quite well how much space is in each folder, and does so in an explorer-type fashion coupled with a pie chart of the results. Excellent program.
#149420 - 20/03/2003 18:04
I don't know how quick you'll find it (it scans the whole drive when starting, although it does cache data somehow, not that I know that any other one would be faster), but I've used Scanner with good success. I find its visualization very intuitive, and it allows for deleting files directly from the utility itself.
Oh, and it's absolutely free (of cost).
#149421 - 20/03/2003 18:08
Loc: Seattle, WA, U.S.A.
Hmmm, what would be an example of using something with bad success?
Jim
#149422 - 20/03/2003 18:12
[Re: jimhogan]
Windows.
Edit: Okay. To be less glib, I mean that it succeeds at what it claims to do, and it does it well, making it very useful. There are other utilities that do what they claim, but they do it in such a backwards fashion that, although you can get the job done with it, it takes a lot of effort to get it to do what you want, whether that means that it has a poor UI or that it forces you down a path you don't want to go. Both of those describe Windows to me. Neither of them describe Scanner
Edited by wfaulk (20/03/2003 18:19)
#149423 - 20/03/2003 18:18
Windows.
/me... aspirating a Stoned Wheat Thin
I surrender! Bitt, please don't ever do that to me again! I'll be nice!!
Jim
#149424 - 20/03/2003 18:24
I'll accept that statement, but I think that is very subjective. I have the opposite reaction to Windows and feel the same way about Macs.
I also feel that every single Adobe program is a "bad success" as we are defining it
#149425 - 20/03/2003 18:31
Hmmm. I checked out TreeSize Pro. I don't think I like it:
See if you can figure out why.
#149426 - 20/03/2003 18:36
I'm not sure I can tell. Why? From the screen shot it doesn't look like it has finished scanning your drive yet.
#149427 - 20/03/2003 18:49
Loc: Bellingham, WA USA
I've used the PC Magazine utility Diskpie for this task. It is free, and graphically showed me the large files that were filling my ever shrinking drive, now to convince myself to delete them ...
I have not tried Scanner yet, so I can't compare them.
- Mark
#149428 - 20/03/2003 19:00
Bitt, that "Scanner" utility is exceptionally cool for my personal PC at home. Haven't tried it at work, yet. Wonder if it would a problem there because I have lots of mapped network drives and I'd want to control which ones it scanned and which ones it didn't. We'll see how it goes tomorrow. But for now, it looks like a winner. I love its method for graphing file usage, it tells me everything I need to know at a glance. COOL. Thanks for that link.
#149429 - 20/03/2003 19:50
Because it doesn't give the sum of the sizes of the subdirectories under the highlighted directory.
#149430 - 20/03/2003 19:59
Very nice. This has been tossed onto my network archive folder.
And no, I don't have that many games installed...
Oh, Tony, it dosen't scan network drives unless you click on one. I have 4 mapped here on my home PC, and had no network activity until I selected one from the list.
#149431 - 20/03/2003 20:39
I'm not sure I can tell. Why? From the screen shot it doesn't look like it has finished scanning your drive yet. Ah. There didn't seem to be any indication that it was still scanning. I assumed that it was done and was screwed up. There wasn't even any real disk activity. Is there something on that screen that indicates that the scan isn't complete?
(The one thing that I don't like about Scanner is that it basically blocks until it's done scanning, with no apparent way to cancel, but it does give a progress indicator, and you at least know when it's done.)
#149432 - 20/03/2003 20:43
Because it doesn't give the sum of the sizes of the subdirectories under the highlighted directory. While that's a good reason, the bigger one is that it didn't even list all the directories. Dignan claims that it wasn't done scanning, but I don't know where the indicator is. Maybe that blue and white bar? I assumed that was disk space remaining.
#149433 - 20/03/2003 21:02
Yes. When the scan is done, the blue bar next to the drive letter will be full.
Another thing I like about the program (I don't know if Scanner does this), is that it loads a shell script so that you can right click on any folder and have Treesize analyze it. I'm going to try out Scanner now and see how I like that one.
#149434 - 20/03/2003 21:29
Interesting.
Pros:
-I like how visual it makes the whole structure of your hard drive. I prefer seeing what all sections are like at once
-it is very easy to move throughout the folders
-very quick scan! I am definitely impressed by how fast it scanned. I'm not just talking the parallel scanning stuff, but just how fast it could scan a single disk, let alone many, each of which was nearly full (60/80GB, 95/100GB). very impressive.
-very small and simple program
Cons:
-like Tony said, how do you tell it if you don't want a certain drive scanned at the program start? just curious
-I prefer seeing the list of all the folders at once
-Is there way to "order" the results around the pie chart? It appears to list alphabetically, but I prefer storage space. that's the reason I use a program like this. I don't see much use in alphabetizing the list.
-small nit-picking, but in some folders, especially when you get down to just the file level, it inserts white space in seemingly random places around the pie chart. is there a reason for this?
All that said, I'm probably going to use this program too, while using Treesize for more of my file management. Thanks for linking it!
#149435 - 20/03/2003 22:14
Loc: New Orleans, LA
The ONLY con to scanner I can find is that it doesn't show all directories, only big ones.
#149436 - 20/03/2003 23:28
[Re: lectric]
Wow! You're right! I think that might be the white space I was talking about. It's leaving out some smaller files.
#149437 - 21/03/2003 00:36
[Re: drakino]
Oh, Tony, it dosen't scan network drives unless you click on one. I have 4 mapped here on my home PC, and had no network activity until I selected one from the list. Fantastic, then. It should meet my needs perfectly. I'll find out tomorrow.
Like they say, sometimes the best things in life are free.
#149438 - 21/03/2003 00:39
(The one thing that I don't like about Scanner is that it basically blocks until it's done scanning, with no apparent way to cancel, but it does give a progress indicator, and you at least know when it's done.) This wasn't the experience I had. I was able to select a different drive icon while it was still scanning, and it seemed to Do The Right Thing: it stopped the existing scan and began scanning the drive I clicked on. Maybe I downloaded a newer version than the one you're running?
#149439 - 21/03/2003 00:44
like Tony said, how do you tell it if you don't want a certain drive scanned at the program start? just curious If it behaves well on my win2k box on the company network (i.e., I can abort it while it's in the middle of a scan so that I can start drilling down to other drives), then I actually don't need that feature. All I want to do is to say "Okay, who are the biggest gluttons on this disk drive or this network share?" so I know where to concentrate my cleanup efforts first. As long as I can freely select drives without getting locked out, I don't care if it starts out scanning extra drives. On my home machine, it looks like it behaves well, so I think I'll be OK.
#149440 - 21/03/2003 00:46
Wow! You're right! I think that might be the white space I was talking about. It's leaving out some smaller files. Which happens to be a good feature, for my purposes. I only want to see the gluttons.
#149441 - 21/03/2003 06:14
Loc: Hants, UK
I'll second TreeSize - very effective at finding those several-hundred meg folders that you forgot about.
My cousin told me that her drive was full and she started deleting documents and stuff to make more room but it didn't seem to have any effect. I found the problem - a 900Mb file in her Temp folder, seems she scanned an A4 page at 19,200dpi and it crapped out and left the file there!
At the time she had a 1.6Gb hard drive and 5 kids who doodled a lot in paint and saved them as BMPs so it was pretty full.
Gareth
#149442 - 21/03/2003 07:38
blocks until it's done scanning I was able to select a different drive icon while it was still scanning, and it seemed to Do The Right Thing: it stopped the existing scan and began scanning the drive I clicked on. Maybe I downloaded a newer version than the one you're running? Nah. You've probably just got a faster hard drive than I do. Mine's ridiculously slow.
#149443 - 21/03/2003 13:55
Well, the Scanner program worked well on my work system, does everything I need it to do. Thanks again.
By the way, you can right-click on a drive and un-check "Summary" to prevent it from including that drive in the boot-up summary if you like.
#149444 - 21/03/2003 17:12
This BBS is great. I could have really used one of these tools the other day when I had an urgent need to create space on a 'doze box.
I'm going to check these out later. I found enough space to deal with the issue at the time, but I'm sure that more can be found.
#149445 - 21/03/2003 17:38
For Unix, there's a tool called kdirstat, that uses treemaps, which are just a generally cool way of visualizing things like disk space usage.
You can get free TreeMap classes in Java or the original TreeMap stuff at U. Maryland. The original inspiration for TreeMaps was mapping out your directory usage, and it's built in to the Maryland tool (which slammed my hard drive for almost a minute, but managed to produce a decent map showing me that I'm burning an awful lot of disk space on my image files).
#149447 - 21/03/2003 20:35
Loc: Seattle, WA. USA
Funny... After seeing that groovy screen shot I had to download that utility... only to be told I already have it in my Downloads/Utilities folder. Heh... guess why my hard-drive is getting full.
It looks awfully complicated. What I usually do when I run out of space is search the drive for folders over a certain Megabyte size... say 25MBs. Then I sort by size and I can selectively delete the larger files... Doesn't help if you have big folders with lots of little files.
Brian H. Johnson MK2 36GB Blue, currently on life support "RIP RCR..."
