#145395 - 23/02/2003 21:27 emphatic install problems
kswish0
Loc: Virginia, USA
Im having trouble getting emphatic working. Im trying to use the @EXEC way of running it this time instead of preinit like I have in the past and it is not showing up in the hijack menu. Here's what I have done:
1) put emphatic in /drive0/var using rz through hyperterminal (I was too lazy to walk downstairs to my router to plug it in down there and ftp)
2) added notify=1 and ;@EXEC_ONCE /drive0/var/emphatic
Is there more that I need to do than this? It is not even showing up in the hijack menu. Any help would be appreciated.
#145396 - 23/02/2003 21:32 Re: emphatic install problems [Re: kswish0]
My guess is that when you used Zmodem to xfer emphatic to your empeg, it wasn't written with executable permissions. Drop to a shell and type chmod +x /drive0/var/emphatic and see if that helps your cause. Otherwise, post a serial boot log for more information.
#145397 - 23/02/2003 21:42 Re: emphatic install problems [Re: tonyc]
kswish0
Loc: Virginia, USA
I just did this and when I tried to mount read only to exit out, it said /drive0 is busy. I dont want to exit without doing this so what should i do. I have a very limited knowledge of linux.
#145398 - 23/02/2003 21:45 Re: emphatic install problems [Re: kswish0]
Umm. Maybe there's a process running that's using /drive0.. Quite possibly emphatic.
Run this:
ps -ef
And if you see anything running on the music partition (emphatic, or whatever else) kill it by noting the process ID (the number in the first column) and typing:
kill 123
assuming the process ID is 123. Then try running rom and ro again to mount read-only. My guess is you botched the chmod command and accidentally ran emphatic.
#145399 - 23/02/2003 22:02 Re: emphatic install problems [Re: tonyc]
kswish0
Loc: Virginia, USA
Thanks. That worked to let me mount read only but emphatic still isn't showing up in the hijack menu. So here is the boot log you asked for...
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com)-xr-x 4 0 0 1024 Feb 6 2000
If there is anyone present who wants to upgrade the flash, let them speak now,0 0 1024 Aug 28 1999 var............ done, booting the kern
or forever hold their peace...it seems not. Let fly the Penguins of Linux!drive-: No such file or directoryrmk5-np17-empeg52-hijack-v312 (root@ibbm)
e000 v1.04 cd /drive
Copying kernel...
empeg:/drive0#
Calling linux kernel...
total 476
.3
Processor: Intel StrongAR
drwxr-xr-x 2 0 0
l.12
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v312 (root@i.94.1 (c) 1
Calibrating delay loop... 207.67 BogoMIPS 501718 Jan 13 2033 database
Memory: 14996k/16M available (992k code, 20k reserved, 372k data, 4k init) 0 18664 Jan 13 2033 playlists conformance testing by UNIFIX
Dentry hash table entries: 2048 (order 2, 16k) 1 0 0 377 Jan 13 2033 t
empeg:/drive0/var# mv emphatic /drive0/var
Page cache hash table entries: 4096 (order 2 emphatic: No such f
NET4: Linux TCP/IP 1.0 for NET4.0otocol (Dag Brattli)
empeg:/drive
IP Protocols: ICMP, UDP, TCP/drive0# mv emphatic /drive0
TCP: Hash tables configured (ehash 16384 bhash 16384)create regular file `/drive0/var/emphatic': Read-only
IrDA (tm) Protocols for Linux-2.2 (Dag Brattli)rq = 15) is a SA1100 UART
empeg:
IrCOMM protocol (Dag Brattli)
empeg:/drive0# mv emphatic /
Starting kswapd v 1.5
drwxr-xr-x 2 0 0 120832 Jan 13 2033 fidsre
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UARTund cust
drwxr-xr-x 2 0 0 12
ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UARTialised.
empeg dsp
empeg RDS driver
-rw------- 1 0 0
empeg remote control/panel button initialised.(first boot)
empeg usb initialised, PDIUSBD12 id 1012 18664 Jan 13 2033 playlists
empeg state support initialised 0089/88c1 (save to d0005600).-r--r-- 1 0 0 377 Jan 13 2033 tagse...
empeg RDS driver initialisedhda: IBM-DJSA-220, ATA DISK
empeg power-pic driver initialised (first boot)x000-0x007,0x038 on irq 6
empeg:/drive0/var# l
SMC9194:
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63 0 18664 Jan 13 2033 playlists
e
Partition ch
-rw-r--r--
smc chip id/revision 0x3349 377 Jan 13 2033 tags
smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)empeg:/drive0/var# ro
empeg:/drive
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:agout
Shell exit
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds ToStarting play
er
hijack_do_execve: execve() failed, errno = 2
hijack_exec("/drive0/emphatic"), rc=-2 (ERROR)
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
#145400 - 23/02/2003 22:08 Re: emphatic install problems [Re: kswish0]
Happy Birthday Daria
Well, your output says you actually added
;@EXEC_ONCE /drive0/emphatic
I think. Is that really where it is?
#145401 - 23/02/2003 22:15 Re: emphatic install problems [Re: Daria]
Yeah, what he said. errno -2 is "file not found" so I think your EXEC_ONCE entry is broken.
#145402 - 23/02/2003 22:18 Re: emphatic install problems [Re: Daria]
kswish0
Loc: Virginia, USA
Yep, that was it. I forgot to include the var in the config.ini. Thanks for your help. I got it working now. This sure is a lot easier than doing it the old preinit way now that I know how to do it this way.
