#145366 - 23/02/2003 19:29
Jemplode making my PC reboot!
Loc: Manassas VA
I just totally reconfigured my computer with XP, installed all service packs and updates then I installed Jemplode, I can open it use it and it works great but when I close it.. the app goes away and within 2 seconds the computer beeps and starts the boot process again. Everytime! I tried to uninstall it.... it got all the way through the process and rebooted my machine, it's still in the list of software when it gets rebooted.
Anyone had this issue? I really wanna use Jemplode...
Brett
60Gb MK2a with Led's
#145367 - 23/02/2003 20:18
Re: Jemplode making my PC reboot!
[Re: lopan]
Wasn't XP the one where they didn't ship it with a Java runtime engine?
Anyway, to get Jemplode working well on my Windows box, I had to install the Sun JRE and use it just for Jemplode. But in order to run certain other web-based Java stuff from within IE, I have to use the Microsoft JRE. Someone here on the BBS showed me that there's an advanced option in IE to deselect the Sun JRE for IE.
Anyway, so I installed the Sun JRE, then I deselected it in the IE advanced options, and now Jemplode works great and all web-based Java stuff works great in IE.
#145368 - 23/02/2003 20:18
[Re: lopan]
Loc: Jesusland
I've been using Jemplode for almost a year now with Windows XP and I have never had any issues. I'm currently using version 44 but have used a couple of other versions also.
Edit: Downloaded Java from http://www.sun.com/
#145369 - 23/02/2003 20:39
[Re: Jerz]
Loc: Manassas VA
Cool, thanks guys, I figured it probably had something to do with java. Just haven't had the time to fix it up right (until it started making my computer crash)...
Brett
#145370 - 23/02/2003 21:56
Loc: Manassas VA
Wow this blows... downloaded the latest Jre... no dice, I know it's a java issue now because even when I open the webstart utility (came with the Jre) and close it, the computer reboots. I re-installed IE, slapped on directx 9 (don't know what I thought that would help but hey ya never know), re-installed Sp1 for XP and went through all the settings for the java plugin and all the settings for IE... I'm at a loss now..
Oh, and it only seems to do this for programs that deal with java (other then the microsoft vm)
Brett
#145371 - 23/02/2003 22:20
[Re: lopan]
Wait a minute, you expect us to believe that the Microsoft VM works and the Sun one doesn't? On a Windows OS? Say it ain't so!
#145373 - 23/02/2003 22:36
[Re: tonyc]
Loc: Manassas VA
Thats not what I'm saying at all... Windows broke it for everything else except it's own.... damn you Gates!
Brett
#145374 - 23/02/2003 22:38
[Re: Daria]
Loc: Manassas VA
Honestly, I think something has gone terribly wrong with this new installation... hyperterm is acting funky, the java thing... I think after I get all my music back in place (lost it all thanks to MS dynamic disks, damn you microsoft, why are you so user friendly) I'm going to do a full reinstall and start from scratch.
Brett
#145376 - 24/02/2003 13:31
Loc: Manassas VA
 but XP is so cute and fluffy... 2k was what i'd been using before, I noticed some pretty convicing speed increases with XP especially with booting (but then again if my PC's not rebooting every 5 minutes it wouldn't matter). I might go ahead and use 2k again... without dynamic disks of course.
Brett
#145377 - 24/02/2003 18:27
[Re: lopan]
I've also seen this with JEmplode 45 and had to go back to version 44. I don't know if the Java versions are different in 44 vs 45 - I didn't have time to check into it.
-Chuck
#145378 - 24/02/2003 20:19
[Re: Chuck]
Loc: Manassas VA
he he.... get this... Video Drivers... more specifically ATI All in wonder radeon drivers, I don't get why it only acted up when closing java applications. Actually tried everything and ended up using the XP system restore feature. Working like a charm now.
Brett
#145379 - 24/02/2003 20:29
[Re: lopan]
Bet ya can't guess what the video card in this machine is?
Yup, you guessed it - ATI Radeon...
-Chuck
#145381 - 25/02/2003 07:08
[Re: Chuck]
Loc: Manassas VA
In ATI's feeble defense, it is a first gen Radeo in fact I believe the model is simply All in wonder Radeon. But still no excuse for ATI's crappy drivers.
Brett
#145382 - 25/02/2003 07:28
[Re: lopan]
This is a known issue (to an extent) with ATI's drivers. Its stems from sun's use of D3D calls in their latest java machine and there less then steller use of those calls. Anyway, i've been looking around rage3d and found this tidbit:
quote:
"You can use Java 1.4.1_01, but you have to disable Direct3D hardware support in Sun Java.
You can either use the command line option of "-Dsun.java2d.d3d=false" or set it in the Sun Java plugin control panel.
Here's the steps you need to take:
Note: if you can't disable the use of ddraw by java prior to
installing it, you can still disable the use of ddraw by the
system, install java, set the -Dsun.java2d.d3d=false in
the plugin control panel, and then enable ddraw in the
system again.
The ddraw can be disabled by either running "Program
Files/DirectX/Setup/dxsetup" application, or in the Display
Properties panel: click 'Advanced' button, then go to
'Troubleshoot' tab, and set the slider on the second mark
from the left."
taken from: http://www.rage3d.com/board/showthread.php?s=&threadid=33666213&highlight=java+reboot
I really hope this fixes the problem; I'm going to try it when i get home.
mike
#145383 - 25/02/2003 07:52
[Re: madavis2045]
Loc: Manassas VA
Very interesting, thanks!
Brett
#145384 - 25/02/2003 08:59
[Re: madavis2045]
I can't believe that ATI (or an ATI defender) can possibly say that it's Java's fault that your computer reboots because it uses an API that ATI implements. Perhaps Sun doesn't use it correctly, but that means that ATI should return an error, not reboot.
#145385 - 25/02/2003 09:13
I believe i stated in the first line of my post that this is an Issue with ATI's driver's. I was simply attempting to expain why it was the JavaVM and not most windows apps that cause this issue. Quite frankly neither Sun nor ATI seems to show much proficency in writing windows Applications for their repsective products. ATI should prevent the reboot when it receives bad data, Sun should improve their writing for windows (alpha transparency is another example of these sort of problems).
mike
#145386 - 25/02/2003 09:15
[Re: madavis2045]
Sorry. Didn't mean to implicate you.
#145387 - 25/02/2003 09:27
Loc: Manassas VA
Believe me, when I say I'm no ATI defender, I've suffered through terrible drivers with 3 different All in wonder cards. Why I keep buying them is beyond me, but the functionality is pretty good. Supposedly ATI is really working hard on cleaning up their drivers, and for the most part this is the first abomination I've seen in a while, however I do believe ATI has a long road ahead of them as far as driver stability.
The Java issues come to no surprise to me, after talking to a few of our developers one being the co-author of this book and a few others (not to be a name dropper I just think it's cool that I work with a guy that writes books on java) but basically he said it's just like any other open source platform in that if it breaks theres normally a switch or something that will make it not break.
Brett
#145388 - 25/02/2003 10:18
[Re: lopan]
I am. Doesn't work for you? Send it to me. Works fine in my Linux machines.
#145389 - 25/02/2003 10:23
[Re: Daria]
You mean that your ATI hardware works fine when you avoid ATI software?
I think you made our point.
#145390 - 25/02/2003 10:29
ATI doesn't make any software for me to avoid, do they?
I'm not interested in running Bill the Gates' operating system.
#145391 - 25/02/2003 11:10
[Re: Daria]
Video drivers are software. Your ATI video card works fine. People running Windows have problems. Your video drivers are written by XFree86 contributors. Windows users' video drivers are written by ATI.
Draw your own conclusions.
Personally, I think that ATI software deveoplers spend way too much time trying to make their software avoid Windows UI specifications. I've always had problems with ATI software, both technically and aesthetically. I've occasionally had technical problems with nVidia drivers, but less often than with ATI. I've never had any aesthetic problems with them. So until ATI gets its software act together, I'll continue to avoid them, at least for my Windows machines. I'd prefer to avoid them elsewhere as well, in hopes that the lack of sales will encourage them to write better drivers for those stuck with crappy OSes.
#145392 - 25/02/2003 11:16
The point was, I'm not running Windows, so there is no ATI software for me to try.
You are doubtless correct; I've heard such complaints before. You won't like my answer, so I won't give it, but you're welcome to read between the lines and flame me for it
