Page 3 of 5 < 1 2 3 4 5 >
#140428 - 22/05/2003 01:09 Re: General Parts list.... [Re: loren]
We have dozens of spare encoders - contact Rob Schofield!
#140429 - 22/05/2003 04:54 Re: General Parts list.... [Re: tfabris]
lopan
Loc: Manassas VA
Were those the smaller ones for the 4-LED board
These are the original large LEDs, I don't think we could get anyone to cough up those part numbers I actually used the big ones to make my 4 LED board.
Brett 60Gb MK2a with Led's
#140430 - 22/05/2003 09:41 Re: General Parts list.... [Re: maczrool]
MkIIa is Alps, MkII is a Meggitt part available from Farnell.
#140431 - 22/05/2003 09:53 Re: General Parts list.... [Re: tfabris]
Derek
Loc: NRW, Germany
nah, the only real difference is that the Mk II is surface mount and the mk IIa is thru hole. OK, so the mk IIa also has a keyed shaft and is from a different manufacturer, but electrically they are the same. If you are really clever you could probably fit a mk IIa switch to a mk II as the pin pitches are the same ...
#140432 - 22/05/2003 09:59 Re: General Parts list.... [Re: altman]
loren
Thanks Rob, i will. So what's the official/nonofficial support email now anyway? The FAQ still says carsupport@sonicblue.com, but is that still active? And other posts people are saying they emailed support@empeg.com. Bueller?
Thanks Hugo. I couldn't find it in the Farnell catalogue. Looks like it's one of these though:
http://www.ehag.ch/PDF-Files/Meggitt/Encoders/Encoders-Gesamt%C3%BCbersicht.pdf
|| loren ||
#140433 - 22/05/2003 10:23 Re: General Parts list.... [Re: loren]
I'm told that both of those addresses still work. Until I'm officially told otherwise, the FAQ is still correct.
#140434 - 18/05/2004 16:28 Re: General Parts list.... [Re: lopan]
Mach
Loc: Texas, USA
Can anyone verify the size of the fascia hex socket cap screws? I believe they are M2.5x10. Is this correct?
Also, has the parts list been added to the FAQ or is this thread the most recent info?
#140435 - 17/06/2004 13:45 Re: General Parts list.... [Re: Mach]
genixia
Bueller...Bueller...?
Does anyone know of a source for these? I need 4 new screws and Paul needs one. A few spares wouldn't hurt either.
#140436 - 17/06/2004 13:52 Re: General Parts list.... [Re: genixia]
"fastener supply shop" in the local yellow pages?
#140437 - 17/06/2004 14:34 Re: General Parts list.... [Re: genixia]
Ezekiel
Loc: NH USA
Maryland Metrics. MSC Industrial Supply. Fastenal. Digikey.
(google for 'em)
-Zeke
WWFSMD?
#140438 - 17/06/2004 14:36 Re: General Parts list.... [Re: Ezekiel]
genixia
Maryland Metrics apparantly don't sell black oxide 2.5x10, only plain steel.
Ditto for MSC Industrial Supply.
Fastenal's only metric hex screws are in expensive kits with a minimum size of M4. Didn't even bother to check finish.
Digikey don't sell any metric black oxide.
Next!?
#140439 - 17/06/2004 14:52 Re: General Parts list.... [Re: genixia]
matthew_k
Maryland Metrics apparantly don't sell black 2.5x10.
I'm fairly certain the empegs fascia screws were painted black specifically for empeg.
Ah yes...
#140440 - 17/06/2004 15:22 Re: General Parts list.... [Re: genixia]
Ezekiel
Loc: NH USA
I purchase an M2.5x6 DIN912 SHCS from Metric Screw and Tool Co. ($25 min. order) with a black oxide finish 1-800-METRIC1.
Also, Metric & Multistandard. http://www.metricmcc.com/
Search under Metric Item Only for 912 (the DIN #)
I'd be very suprized to see a bright zinc or uncoated steel socket head cap screw in that size. Stainless and High-Tensile would be more standard.
-Zeke
WWFSMD?
#140441 - 20/06/2004 22:37 Re: General Parts list.... [Re: Mach]
Mach
Loc: Texas, USA
Here's the link for Mcmaster-Carr for these. They can be found in alloy steel and stainless steel. They do not appear to have black oxide.
#140442 - 23/07/2004 08:49 Re: General Parts list.... [Re: Mach]
Mach
Loc: Texas, USA
I ordered the M2.5x10mm from McMaster Carr. After re-measuring the original socket head cap screws instead of the ones provided by 303 with my new face, I believe the originals were 12mm. I don't expect it will make much difference but thought I'd posit it.
On to HD screws, the originals were M3 but what length. I've ordered both 6mm and 8mm. Any idea if these are correct or not? Below are details from the order.
91801A151
Metric 316 SS Flat Head Phil Machine Screw M3 Size, 6mm Length, .5mm Pitch, Packs of 100, $6.76
91801A154
Metric 316 SS Flat Head Phil Machine Screw M3 Size, 8mm Length, .5mm Pitch, Packs of 100, $6.71
92290A060
Metric 316 SS Socket Head Cap Screw M2.5 Thread, 10mm Length, .45mm Pitch, Packs of 50, $6.88
#140443 - 25/07/2004 13:33 Re: General Parts list.... [Re: lopan]
Sheetzam
Loc: Annandale, VA
Well, I searched this thread, but didn't find the answer to my question:
Where can I get a replacement screw for the connector on the back of the empeg?
My wife's lost one of its two screws, and I know they're very specific parts, as they allow some slop on the connector. Anyone know where I can get a couple replacements?
#140444 - 25/07/2004 14:34 Re: General Parts list.... [Re: Sheetzam]
You could use a regular screw (as long as it was the right length) and just not screw it down all the way. Loctite the hell out of it, and you should be good to go.
#140445 - 25/07/2004 15:55 Re: General Parts list.... [Re: Sheetzam]
Just buy one of the connectors. The screws are included with it.
#140446 - 25/07/2004 16:47 Re: General Parts list.... [Re: Sheetzam]
matthew_k
Be careful using the empeg without one of the screws. It's a great way to get your empeg stuck in the sled, which in turn is a great way to break the handle trying to get it out.
#140447 - 14/08/2004 02:48 Re: General Parts list.... [Re: Mach]
Mach
Loc: Texas, USA
I got the hex screws but they're the wrong size. Time to try again.
#140448 - 14/08/2004 04:15 Re: General Parts list.... [Re: matthew_k]
SonicSnoop
Loc: Triangle, VA
Yea I found that out the hard way. It was ok for a while then one day it was jammed in good. I wiggled and pulled and then the handle snapped and even then the empeg didnt pop out. I have since drilled a hole in the two parts of the handle and glued in a needle. That helps hold it together til I can find a replacement handle. Just spend the $5 for the connector and 2 screws. I ordered mine the day before I broke the handle.
#140449 - 29/09/2004 00:05 Re: General Parts list.... [Re: lopan]
FireFox31
Loc: East Coast, USA
Does anyone have the part numbers and source that carries the blue and white button switches that connect to the display board and hold the lights and (stock) grey buttons? I want to buy a few so I can send them to molding companies to help determine the "tolerances" for the translucent buttons that are in progress. Thanks.
FireFox31
#140450 - 29/09/2004 07:26 Re: General Parts list.... [Re: FireFox31]
StigOE
They're mec switches and manufacturer partno is 3FTL6 and available from Farnell with order code 674-825.
Stig
#140451 - 29/09/2004 16:20 Re: General Parts list.... [Re: FireFox31]
schofiel
There is a dimensional PDF downloadable from both Farnell and the original manufacturer (ALPS, I think).
#140452 - 29/09/2004 20:33 Re: General Parts list.... [Re: schofiel]
StigOE
Nope, they're not Alps, it's the Multimec 3F line from mec. The homepage is www.mec.dk
Stig
#140453 - 01/10/2004 02:47 Re: General Parts list.... [Re: StigOE]
FireFox31
Awesome, thanks guys! That should help alot.
FireFox31
#140454 - 06/10/2004 09:26 Fan parts list [Re: lopan]
mdavey
Loc: Wellingborough, UK
Fans
pca suggests these:
Farnell 306-2600 40x6mm 5v 5.5cfm (2.6l/s) 26dB(A) ~£9
Farnell 306-2612 40x6mm 5v 4.35cfm (2.07l/s) 22dB(A) low noise ~£9
Farnell 306-2624 40x6mm 5v 3.5cfm (1.66l/s) 16dB(A) super low noise ~£9
(Philip O'Hare reports that the last of those three is quiet)!
Alternatives:
Panasonic panaflo fans available from http://www.dorothybradbury.co.uk/ and http://stores.ebay.co.uk/Panaflo-Fan. They don't seem to do a 40x12mm, 40x10mm or 40x6mm fan at the moment, though.
jaro1.com 40x6mm 5v or 12v
jaro1.com 40x10mm 5v or 12v
www.chenghome.com.tw 12v 40x12mm (cha2512)
www.chenghome.com.tw 5v 40x12mm (cha2505).
RS 197-4558 40x40x12mm 5.3cfm 21dB(A) ~£23+VAT (ELINA HDF-4012L-12LB)
ELINA HDF-4012L-12LB 40x12mm
Sunon KD1204PFB1 40x10mm 8.3cfm (8300rpm) 34.3dB(A)
Sunon KD1204PKB1 9.1cfm (7400rpm) 27dB(A)
Plycon 40x10mm (Sunon KD1204PFB1) 8.3cfm (8300rpm) 34.3dB(A) ~$9
Plycon 40x10mm (Sunon KD1204PKB1) 9.1cfm (7400rpm) 27dB(A) ~$9
ADDA AD0412MX-K90 12vdc 40x6mm 5.2cfm 23.8dB(A)
ADDA 40x10mm 4.7cfm 17dB(A)
(cookie_ARM reports this is very quiet)
MOUSER 664-D4006MX-12V (AD0412MX-K90 ADDA) 12vdc 40x6mm 5.2cfm 23.8dB(A) ~$9
Innovative Industrial Co. Ltd (Taiwan) SP401012M 12v 0.06A 6.2cfm 21dB(A)
Choose hypro bearings in preference to ball bearings if possible - they are quieter
Hardware
plastic rivets to hold fan in place: digikey SR-3055B-ND farnell 722-4321or request free samples from Richco US or Richco UK
Compiled from various postings including this thread:
http://empegbbs.com/ubbthreads/showflat.php/Cat/0/Number/47765/page//fpart/4/vc/1
Edited by mdavey (06/10/2004 15:35)
#140455 - 08/10/2004 15:51 Re: Fan parts list [Re: mdavey]
mdavey
Apparently, the ADDA AD0412MS-G70 40x10mm oil-impregnated sleeve bearing fan is not 17dB(A) 4.7cfm, but 21dB(A) 5.8cfm. The incorrect specifications are widely reported on websites but ADDAs own datasheet confirms the correct values. Rapid Electronics 37-0882, ~£4.50.
There is also the AD0412MX-G70 40x10mm 12v 5.7cfm 19dB(A) brushless with hypro-bearing. Mouser 664-D4010MX-12V, ~$9.
Edited by mdavey (08/10/2004 15:52)
Michael
Ex-owner of stolen empeg #030102741
#140456 - 09/10/2004 11:46 Re: Fan parts list/handle screws? [Re: mdavey]
newguy1
Loc: Massachusetts,USA
Anyone know the size screw that is used to hold the handle on to the player?
I know,REALLY F&!#KING SMALL
Seriously though any idea where I could get 1 or more?
MIKE 80Gb RIO
#140457 - 12/10/2004 01:32 Re: Fan parts list/handle screws? [Re: newguy1]
FireFox31
MK1 / 303 Face button caps from Farnell
Short length16mm (short) black button caps 917 450
Standard length 19 mm (long) black 914 461
Short/Standard transparent 311 2445/311 2457
Ripped from another thread
FireFox31
