#138179 - 29/01/2003 17:34 Converting a PDF to Excel
visuvius
Hi,
Does anyone know how to do this without having to buy Adobe Acrobat 5.0? There is a rather large price sheet in PDF format here at work that i needed converted to excel. The only method i've seen is the one here.
We have Acrobat 4.0 here, but that page says you need 5.0.
#138180 - 29/01/2003 17:52 Re: Converting a PDF to Excel [Re: visuvius]
AndrewT
Loc: Oxford, UK
I don't know how to do this but I do have full Acrobat 5.0 installed at work. I'll be there in about 8 hours from now and I'm happy to try and convert it for you using those instructions if you're still stuck.
#138181 - 30/01/2003 03:31 Re: Converting a PDF to Excel [Re: visuvius]
muzza
If you have some OCR software you could print it, scan it and format it. It would take a while though.
Could you request the info as a spreadsheet from the supplier?
#138182 - 30/01/2003 09:28 Re: Converting a PDF to Excel [Re: muzza]
visuvius
We have requested it as a spreadsheet and they've been pretty unhelpful on that front. I hope this isn't a testament to their future service.
I hadn't thought of the scan and formating angle. I suppose that would be a littl better than manualy entereing in the info.
<shiver>
#138183 - 30/01/2003 11:49 Re: Converting a PDF to Excel [Re: visuvius]
With the right software tricks, you could probably get the PDF to print to a bitmap image file instead of a printer, then get the OCR software to read that file. Thus saving the analog/realworld step and getting a better image and a more accurate OCR.
One other question...
It's not as simple as selecting all the text in the PDF document, hitting "Edit/Copy", pasting it into a text file, and importing that text file into Excel (with the proper formatting instructions)... is it?
#138184 - 30/01/2003 13:32 Re: Converting a PDF to Excel [Re: tfabris]
jasonc
Depends on the Document Security set by the person who created the document, but is techinically possible.
#138185 - 30/01/2003 13:33 Re: Converting a PDF to Excel [Re: tfabris]
lectric
Loc: New Orleans, LA
It should be that simple.... You will still likely have to do some cleaning up after, but it is a much better way.
#138186 - 30/01/2003 13:34 Re: Converting a PDF to Excel [Re: lectric]
lectric
Oh, and I'd paste into wordpad first, to set up the delimiters better.
#138187 - 30/01/2003 13:42 Re: Converting a PDF to Excel [Re: lectric]
Screw the intermediary program.
I just typed some random columns of data into a text editor, hit edit/copy, and then hit edit/paste in excel and it dropped in perfectly.
So if the text in the PDF document can be selected and copied to the clipboard, just paste directly into excel.
#138188 - 30/01/2003 13:45 Re: Converting a PDF to Excel [Re: tfabris]
lectric
That works assuming it's standard length data. If some of the fields have extra spaces or tabs, it could be a problem. Then again, you're going to have to fix it regardless, so I gess the middle step isn't really necessary.
#138189 - 30/01/2003 14:55 Re: Converting a PDF to Excel [Re: tfabris]
AndrewT
Loc: Oxford, UK
You should be able to do pretty much what you said. visuvius even linked to some instructions specially geared towards exporting Acrobat tables to a .txt file but it's not that simple in this instance.
I spent 10-mins today trying with his file and there's something wierd going on;
- Acrobat's 'edit/copy' errors with something like "cannot copy selection to clipboard"
- The special table select then save-as .txt file method just produces a file full of non-printing characters
Illustrator 10 warns of a missing font in the .pdf and makes a mess of displaying it which I think is a major clue. I suspect this file was generated by a non-Adobe application and there's a compatibility problem with it's file format.
I'll be having another play with it @ work tomorrow
#138190 - 30/01/2003 15:02 Re: Converting a PDF to Excel [Re: AndrewT]
IIRC, that's because it's specifically denied. Check File->Document Security.
Check File->Document Properties->Summary.
