#136585 - 23/01/2003 12:40 Acceptable Mounting Angle
DBALKUNJR
I would like to install my spare sled in my Jeep Wrangler. I have an aftermarket security console that is made to mount a car stereo vertically. I remember reading that the Empeg had to be mounted horizontal or within +/- 15 degrees. Would mounting the unit vertically greatly affect the drive life or the shock mounting? Otherwise I may just be forced to use the Aux in and hook up my Ipod to the existing aftermarket deck.
Dave
Dave
MK2 12Gb
MK2a 60Gb
#136586 - 23/01/2003 12:44 Re: Acceptable Mounting Angle [Re: DBALKUNJR]
Mine's been mounted in my '87 BMW 325e, which has an inverse mounting angle (the face of the empeg points very slightly down), for a couple of years with no apparent ill effects.
#136587 - 23/01/2003 12:45 Re: Acceptable Mounting Angle [Re: DBALKUNJR]
#136588 - 23/01/2003 16:44 Re: Acceptable Mounting Angle [Re: tfabris]
I've been running mine at about a 40 degree angle for over a year with no problems.
#136589 - 23/01/2003 16:58 Re: Acceptable Mounting Angle [Re: DBALKUNJR]
matthew_k
Well, with hard drive prices coming down every day, I don't see any reason why not to try it, and just figure that you're shortening the life of your drive... If your drives keep dieing, you might want to consider a different solution.
matthew
#136590 - 24/01/2003 11:11 Re: Acceptable Mounting Angle [Re: DBALKUNJR]
DBALKUNJR
Thanks for the info. It would be an expensive experiment to try since the aftermarket console costs like $250. I think I'll just suffer by plugging my IPOD into the aux in on my CD deck as this is not my primary vehicle, just summer ride.
Dave
MK2 12Gb
MK2a 60Gb
#136591 - 24/01/2003 15:34 Re: Acceptable Mounting Angle [Re: DBALKUNJR]
mcomb
Loc: San Carlos, CA
Your talking about the Tuffy console right? Have you considered their overhead console instead? The mounting angle would still be a bit off since it angles down, but at least it wouldn't be totally vertical.
-Mike
