#135193 - 14/01/2003 20:08
help -- need to reset unit
Loc: South Bay, CA: USA
ouch... i just really hosed up my unit. rather than trying to figure out what i did, what is the easiest way to erase everything and resetting it to the state it was when shipped? hope there is something reasonably simple...
thanks
-ted
#135194 - 14/01/2003 20:22
Re: help -- need to reset unit
[Re: TedP]
Hard Disk Builder Image followed by a normal software install.
#135195 - 15/01/2003 00:41
thanks for the reply.
when i loaded the image, i fot a "drive(s) appear to be already built". subsequently, i reloaded the normal s/w, and got back to the state i was in before. did i do something wrong?
thx
-t
#135196 - 15/01/2003 00:49
[Re: TedP]
Did you select to continue anyway?
#135197 - 15/01/2003 04:23
[Re: Biscuitsjam]
Yes, you have to open a terminal session and hit return to proceed from that point.
#135199 - 15/01/2003 08:50
[Re: mschrag]
well... i wish i would have known about the terminal part yesterday because i went through the process several times flawlessly... today when i tried it, i was able to get through the flash programming, but the RIO just started making clicking noises (i assume from the drive) when trying to select the pump partition. finally, it culminated with a "bad pump response in section 25"
how deep in it am i?
thx
-t
#135200 - 15/01/2003 09:06
[Re: TedP]
Loc: Richmond, VA
are you using jEmplode to upgrade? incidentally, the drive on one of my Empegs clicks too ... no idea what it is. seems to be working still though (it's been doing this for a while)
#135201 - 15/01/2003 09:09
[Re: mschrag]
man you guys are quick... i've actually been using EMPLODE to upgrade. however, i said what the hell.. and opened up the RIO and pulled the drive bay out, and reseated the cables. guess what... looks like it's upgrading now. weird coincidence?? who knows. we'll see how it all pans out after i put the drive bay in.
thanks for all the help from everyone... did i ever mentioned what a cool crew of people are on this board?
-t
#135202 - 15/01/2003 09:50
[Re: TedP]
the latest...
i did the builder image... reformatted the drives (i stopped the performance test after about 10 minutes). loaded the latest s/w, and now i get a failure when doing the media check...
0xc0041016
well, at least im making forward progress..
-t
#135203 - 15/01/2003 10:01
[Re: TedP]
ok.. here's the output from hyperterminal.. i think im still hosed. oh well. gotta run to work. any help would be much appreciated
-t
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315
(release)) #16 Wed Jul 24 18:19:54 BST 2002
empeg-car player (hardware revision 9, serial number 10101994)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004680).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-230, ATA DISK drive
hdb: IBM-DJSA-230, ATA DISK drive
hda: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
hdb: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:07:c
a
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
EXT2-fs error (device ide0(3,4)): ext2_check_descriptors: Block bitmap for group
64 not in group (block 3)!
Remounting filesystem read-only
EXT2-fs: group descriptors corrupted !
Tried to mount /dev/hda4 as ext2 but got error 22
No primary hard disk
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComplùStarti
ng player
! tags.cpp : 61:Failed to open tags (0xc0041002).
Vcb: 0x4086d000
#135204 - 15/01/2003 10:09
[Re: TedP]
Greetings!
I had this happen to me yesterday when I was working with a player. I re-applied the builder, reloaded the software and it worked fine. I do not know a "root cause" though.
#135206 - 15/01/2003 10:53
I thought that was your job?
#135207 - 15/01/2003 10:54
I would have done, but I was too busy making short, easy posts to push my post count past 1,000...
#135208 - 15/01/2003 10:58
[Re: Biscuitsjam]
Loc: Manassas VA
I was amazed it took him that long to post! Tony are you OK?
Brett
60Gb MK2a with Led's
#135209 - 15/01/2003 11:04
i found it on my own tony.. thanks anyways for the info anyways.
-t
#135210 - 15/01/2003 11:16
[Re: lopan]
Just fine. Once in a while, I have to go offline for maint... er... sleep.
#135211 - 15/01/2003 11:24
Loc: Manassas VA
Speaking of sleeping.... do you have the empeg mounted in your alcove?
Brett
#135212 - 15/01/2003 13:23
[Re: lopan]
Nah, I connect to it remotely through the Collective's ethernet link.
