Page 2 of 2 < 1 2
#13353 - 29/08/2000 04:43 Re: Solution Found! [Re: SuperQ]
teemcbee
Molding the rotary button would be bad - you wouldn't be able to remove/change the display..
TeeMcBee
Got my Mk2! # 080000143
TeeMcBee
#13354 - 29/08/2000 18:53 Re: Solution Found! [Re: teemcbee]
Ezekiel
Loc: NH USA
In that case I don't think I'll start fiddling around with mine just to check out the cover design! The scoring should still work though.
-Zeke
WWFSMD?
#13355 - 31/08/2000 04:01 Re: rotary button problem [Re: rob]
teemcbee
Will this happen on the new produced units only or will current customers get a replace or some other solution served by you? (Just for interest..)
TeeMcBee
TeeMcBee
#13356 - 31/08/2000 21:19 Re: rotary button problem [Re: teemcbee]
dtrounce
Well, I got my empeg back this morning, just over a week after I sent it to the hospital (aka Cygnet Court, Cambridge). Yay!- the display works again.
Hugo did his trick with the glue on the shaft to make the knob grip it. Absolutely no problems now, and it comes off easily if necessary. He sent me a pic which shows what he means which I've attached.
Once again, kudos to empeg's level of customer support.
Page 2 of 2 < 1 2
