#13281 - 12/08/2000 13:54
Re: Success!
[Re: rob]
Loc: BC
Success!
The IDE connector was almost entirely off the pins. I had to release the drive tray to be able to get at the connector to jam it on hard, but everything's cool now.
Could a guy just put some 3M two-way foam tape down in the empty side of the other drive bay to stick the loose-end of the cable to?
Everything's great so far. Release 1 is installed.
I do have one question: each time I sync, the "checking integrity" always comes up and takes forever (at least 5 minutes -- I don't see the progress bar move, and emplode behaves as if hung until suddenly its happy and moves on) before it gets down to moving files. Is this normal? Should it be checking integrity on EVERY sync?
-------------------- Reg #57xx, Ser #080000141, Rec'd Aug.11/00
MK2 #141 12GB Queue #5723 (SOLD)
MK2a 30GB + grn + tuner + blk empeg case
#13282 - 12/08/2000 14:05
Re: Success!
[Re: Fogduck]
Loc: Berkeley, CA
Set the clock; that should take care of it.
I don't know exactly what the algorithm is, but the Mk.2's seem to look at the RTC to see if it's time for an fsck. Once you set the clock, it will only check integrity every now and then (or if you've powered down in the middle of a synch, which you should never do)
-Zandr
-Zandr Mk.I #150 Mk.II #39
#13283 - 12/08/2000 15:51
Re: Success!
[Re: n6mod]
Ooo, good catch n6mod.
Should that one be in the FAQ? I mean, I've only seen it this once so far, but it strikes me as something that a lot of people might run into.
___________ Tony Fabris
#13284 - 12/08/2000 16:18
Re: Help Please!
Loc: Netherlands
Make that four...
I got mine on friday and it had the same symptoms as Alex Except the last two lines of the boot-sequence are different; I only get rubbish : empeg-car bootstrap v1.00 20000601 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
Copying kernel... Calling linux kernel... Uncompressing Linux.................................... done, booting the kernel . Linux version 2.2.14-rmk5-np17-empeg35 (mac@fatboy.internal.empeg.com) (gcc vers ion 2.95.2 19991024 (release)) #19 Fri Aug 4 15:58:47 BST 2000 Processor: Intel StrongARM-1100 revision 11 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 7, serial number 80000144) Command line: mem=12m temp=28 Calibrating delay loop... 207.67 BogoMIPS Memory: 11000k/12M available (968k code, 20k reserved, 292k data, 8k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 ) ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 ) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART empeg display initialised. empeg dspaudio driver initialized empeg audio-in initialised, CS4231A revision a0 empeg infra-red support initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0005900). empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... Probing primary interface... empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:00:9 0 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...•Ô•…¹¹½Ñ½Á•¹É½½Ñ‘•Ù¥•ÁÍéÁÕ)5oªK¹•±Á…¹¥éY MéU¹…‰±•ѽµ½Õ¹Ñɽ½Ñ™Í½¹ÁÍéÁÕ)5
I have mailed support@empeg.com but haven't received a reply yet. I hope the solution is as simple as pushing back a cable...
Frank van Gestel
Frank van Gestel
#13285 - 12/08/2000 16:40
Re: Success!
[Re: n6mod]
Loc: BC
Hmm. I had set the clock very early on and have done about 4 syncs since.
So far, only ONE sync did NOT go through the full integrity check.
I am wondering which end is deciding to do the integrity check, emplode or the empeg itself. If emplode is deciding, maybe it matters how the two clocks (PC vs. empeg) relate.
(Right now, my empeg is about two minutes ahead of my PC)
#13286 - 12/08/2000 16:48
Re: Help Please!
[Re: fvgestel]
Loc: Montana, USA, Bozeman
If the symptoms are the same, I'm sure thats the problem because it seems to be a recurring problem and they didn't realize it was that much of a problem before your's went out.
Alex Lear
Alex Lear
#13287 - 12/08/2000 16:53
Re: Help Please!
[Re: fvgestel]
Rob, have you been able to determine if the connectors are coming loose in shipping or if they were just not pushed on all the way to start with. I can't imagine any bumpy ride that would pull that connector off if it fully pushed on. Who knows, maybe Fedex delivers them by dropping them out the airplane hatch.
Alex Lear
Alex Lear
#13288 - 12/08/2000 17:46
Re: Help Please!
[Re: alear]
I suspect it may be a combination of four factors - assembly, shaking in transit, the 1mm stand-off and movement at the loose end of the cable.
In any case, whatever the true cause, a dab of hot melt glue is a universal solution. I'll instruct the manufacturer to apply it from Monday.
#13289 - 12/08/2000 22:53
Re: Help Please!
Loc: Newfoundland, Canada
It hangs loose... two pictures are attached... i hope... these Labatt Lite aren't helping much with my computer work right now... :) #170... I got SN: 080000101 12 gig Blue! Ok.. one will have to do right now.  Edited by ShadowMan on 13/8/00 06:55 AM.
12 gig empeg Mark II, SN: 080000101 30 gig RioCar SN: 30103114 My blog
#13290 - 18/08/2000 15:13
Re: Help Please!
[Re: fvgestel]
Make that 5... I'm waiting for a reply from support. Has anyone had any problems about Empeg honoring the warranty after the case has been cracked. I'm the impatient type with my own tools.
d
#13291 - 18/08/2000 15:27
Re: Help Please!
[Re: dangulo]
Empeg has been traditionally good about this sort of thing, but you shouldn't open the player without some proper instruction. You could possibly damage it if you don't know what you're doing.
I'd point you to our adding-a-disk-drive FAQ for instructions on how to properly open the player, but it's not up yet because we're waiting on Mike/Rob to post the formatter files.
More importantly, though, Rob said they should be putting a dab of glue on the connectors since last Monday (Aug 14). When was yours shipped? When you do eventually open the player and fix the loose connector, let us know if the glue was on there or not.
#13292 - 18/08/2000 17:59
Re: Help Please!
Tony,
I should send you my "how to open a Mk.2 without bending the case horribly and breaking the VFD" email template. It's worth including in the disk drive FAQ.
Few glued players have gone out so far, and I'm certain the connectors won't come off on these players.
#13293 - 18/08/2000 18:40
Re: Help Please!
[Re: rob]
Please do!
