#132374 - 30/12/2002 01:50 Strange noise after hard drive installation..
durden
Loc: Texas
I just got my 2nd hard drive installed, and its working great, thanks to the FAQ guide. (Thanks to whoever wrote that up, by the way). The only problem I have is an annoying sound that the release mechanism on the front of the player is making now. It happens when i lift it or let it down to put the player in the car / remove it, etc.
I realize that this is most likely caused by the hex screws being too tight or whatever, but I can only make them so loose! Iit seems that without them in at all, the sound is nonexistant, but when i get them even remotely secure, it returns. Any suggestions or ideas? WD-40? heh..
- durden -
#132375 - 30/12/2002 07:31 Re: Strange noise after hard drive installation.. [Re: durden]
mrfixit
Tfabris is the one you need to thank for the FAQ. For your problem look here I know it says My handle sticks in the "open" position. Can I fix it? but this will fix your problem.
Ben
hijacked
#132376 - 30/12/2002 12:04 Re: Strange noise after hard drive installation.. [Re: durden]
You're welcome.
Can you describe the "noise" in more detail?
#132377 - 30/12/2002 20:20 Re: Strange noise after hard drive installation.. [Re: tfabris]
durden
Loc: Texas
It sounds like the springs are rubbing up against the case, or something like that. I tried doing the stuck handle fix, but it didnt seem to fix the problem..
- durden -
#132378 - 30/12/2002 20:25 Re: Strange noise after hard drive installation.. [Re: durden]
My handle springs do make "tink-tink" noises when I open and close the handle. I never minded it. Is that all that's happening?
#132379 - 30/12/2002 21:00 Re: Strange noise after hard drive installation.. [Re: durden]
mrfixit
Hmm, I thought for shure the stuck handle fix would take care of it, wierd. Maybe the springs got a little smooshed when you took the drive out and really are rubbing the case.
Ben
hijacked
#132380 - 30/12/2002 22:54 Re: Strange noise after hard drive installation.. [Re: tfabris]
durden
Loc: Texas
Yeah, that is probably it. It really isnt that bad, I am just annoyed easily by rattles, squeaks, etc. . I just figured since it just started after I installed the new hard drive, that maybe I could undo it. But perhaps I did mess something up during installation.
- durden -
#132381 - 30/12/2002 23:51 Re: Strange noise after hard drive installation.. [Re: durden]
Anonymous
Unregistered
Damn wealthy spring manufacturers too greedy to pay any attention to making sqeak-free products. Sounds like a good mission for project mayhem...
#132382 - 31/12/2002 01:05 Re: Strange noise after hard drive installation.. [Re: durden]
lectric
Loc: New Orleans, LA
My springs used to rattle, 'till I coated everything they could easily touch with a thin layer of rubber cement. Fixed.
