#13050 - 08/08/2000 01:37 Suddenly Crosstalk
teemcbee
I haven't installed the Mk2 yet ('cause it's currently on the way to me) but I have prepared my car for the Mk2 3 or 4 months ago.
And since about a week or two I have some crosstalk from the engine on the speakers. I don't know where it comes from and why it hasn't been there from the beginning. Maybe I have something like a ground loop - I'll try to find out as soon as I install the Mk2.
But if I can't find it - what else could it be? What could I do against it? Would a capacitor help and where should I best place it?
TeeMcBee
Reg#948 - already ordered a Mk2.
TeeMcBee
#13051 - 08/08/2000 03:01 Re: Suddenly Crosstalk [Re: teemcbee]
Possibly one of the RCA leads you installed is now touching the car metalwork and picking up the ground differential between the amp and where it touches the metal.
#13052 - 08/08/2000 03:13 Re: Suddenly Crosstalk [Re: altman]
teemcbee
This is exactly what I thought already. I'll have a look at it, thanks!
TeeMcBee
TeeMcBee
#13053 - 08/08/2000 03:24 Re: Suddenly Crosstalk [Re: altman]
mkaye
I usually wrap the RCA's with insulation tape to prevent this kind of thing happening.
M
---- MKII #080000528 - 40Gb Blue
#13054 - 08/08/2000 11:12 Re: Suddenly Crosstalk [Re: teemcbee]
Tee, your original post was a little unclear as to whether you're getting the problem with a mark1 or a mark2. If it's a Mark1, please read this message and its follow-up.
#13055 - 09/08/2000 00:16 Re: Suddenly Crosstalk [Re: tfabris]
teemcbee
I don't have the problem with any Mk.. I HAD the problem with my factory headunit. (I've connected an amp so the sound goes out from the headunit into the amp and then to the speakers. =preparation for the Mk2)
But I've already solved this - Getting my Mk2 yesterday and installing it into the car I figured out what the problem was - it was a partially broken cable on the RCA-jack feeding the amplifier. That was causing the problem.
Now - with the Mk2 (instead of a really cheap tapedeck) the sound is great!!! (I already replaced the factory speakers (they were made with a plastic-chassis!!!) - so Tony - please don't slam the door again !
Thanks for all help on that (I also did the insulation-tape-thing to make for sure nothing bad can happen to the sound)
TeeMcBee
TeeMcBee
