#130462 - 12/12/2002 03:23
Button Code Hack FAQ
Hey everyone,
If you've got some button code hacks on your empeg I'd like to invite you to PM them to me because I'd like to put together a new section on RioCar.org
If you could put it together in this format:
Name of publisher: <you>
Name of hack:
Brief description and uses:
Hack Codes:
I'll try to sort it all out from there. Please note that there isn't any specific section in RioCar.org yet, (so don't look) when I've got some in, I'll figure out what's needed.
The idea is that the codes can be copied and pasted directly into the config file.
Can't wait to hear from everyone.
Murray
Murray
Is it the 'N', or the 'Zero'?
#130463 - 12/12/2002 07:45
Re: Button Code Hack FAQ
[Re: muzza]
Loc: Erie, CO
Why don't we reply to this post to discuss as well? I'm sure that some of the button hacks that we have come up with could be either improved upon or done in a different way. I'll start:
Mark Cushman
Quick In-Car Dimmer
Because I own a car that has Daytime Running Lights, I never turn off the headlight switch. When I shut my ignition off, the car will shut down all the lights, too (this is a Subaru Outback). Because of this, the headlight sense wire in my dash is always high, and the built-in dimmer in the Empeg will not work for me. I came up with a quick way to change the dimmer level with the remote using the vol+ and vol- buttons.
VolUp.CN=Bottom,Left,Left,Left,Left,Bottom,Bottom,Right,Bottom
VolDown.CN=Bottom,Left,Left,Left,Left,Bottom,Bottom,Left,Bottom
#130464 - 12/12/2002 22:09
[Re: cushman]
Odd. Never knew cars would do this. Mine turns on the daytime running lights the second I pull the gear shifter out of park. Turning on the headlights results in the parking lights first, then another notch will turn off the daytime lights and turn on the normal headlights. The headlight line is only high when the selector is moved away from the "off" position.
#130465 - 12/12/2002 22:12
[Re: drakino]
Actually I thought he meant that since the headlights were on all the time, he just left the switch in the "on" position (assuming his cars turns them off after he shuts it off).
#130466 - 12/12/2002 22:16
[Re: drakino]
Loc: Erie, CO
Yeah, I didn't realize they worked that way either. I like it, though, because I never have to worry about weather I've left my lights on. Also, I never have to shut off the light switch, just the ignition. When I pull up somewhere at night, I just turn my car off, and it turns it's headlights off. If I were to leave the switch off, my lights would come on if my parking brake is off (manual trans.) so I can shut them off while the car is parked if I like.
The only downside is the Empeg dimmer not being automatic. Therefore the button hack.
#130467 - 13/12/2002 04:18
[Re: cushman]
Thanks Mark, First one!
Keep them coming.
I only asked for them in PM as it's easier to keep track of.
Any more?
Murray
#130468 - 13/12/2002 18:58
[Re: muzza]
Bump
I can't believe Mark is the only one with button hacks. C'mon, Share!
Murray
#130469 - 15/02/2004 22:36
[Re: muzza]
Loc: Erie, CO
I'm going to put a few more keywords in here in case someone was searching for ir_translate or macros. I tried searching the BBS for those keywords, along with button code macro or something like that and I still had to look for a while.
I'm sure there are a few members around that have more macros they could share.
#130470 - 15/02/2004 22:54
[Re: cushman]
Loc: East Coast, USA
I know I should search for this, but I'm too tired and I'll just ask (maybe we can add this to the Button Code FAQ, haha).
So, you can program macros? Into the remote, I'm assuming.
So, since I never use my remote, I could set it up so, say, 1 moved to previous EQ and 2 moved to next? And 3, 4, 5 mapped to my favorite info modes? And... then there's the "favorite visual" mode, so I could map a button to cycle through those? And maybe map buttons to do genre searches for my favorite genres??
I think this may be the (unfortunately un"elegant") solution to my UI quirk issues.......
#130471 - 15/02/2004 23:06
[Re: FireFox31]
Loc: Erie, CO
Here, let me kick you in the FAQ
Yes, you could do some of those things. Sometimes the menu items move around (like the Info menu is ordered depending on what mode you are in currently), so you have to be careful when mapping buttons to traverse menu items. It is kind of inelegant, but I've found it's quickly done in the UI so most of the time I don't even see a menu pop down. Sometimes I'll get a flicker, but I only use the macros above to change dimmer levels, so it's not that often.
#130472 - 15/02/2004 23:15
[Re: cushman]
Mark, it seems like you're happy with the DRLs in your Subby, but if you'd ever like to disable them, perhaps just to try it out, there is just one connector under the hood you pull. The lights work like normal after that and there is no safety issue.
#130473 - 15/02/2004 23:30
[Re: SE_Sport_Driver]
Loc: Erie, CO
Cool, got a link to a more detailed description? I don't think I'd ever disable them permanantly, but if I ever decide to race the Cannonball Run with night vision goggles it might be nice to shut them down.
#130474 - 15/02/2004 23:33
[Re: FireFox31]
Here's the number one hack for nice visuals browsing:
[ir_translate]
Visual.L=Visual.L
Visual=VisualSeek
[hijack]
fake_tuner=1
#130475 - 15/02/2004 23:39
[Re: cushman]
Hehe, I like it just because it allows me to pull into my driveway without flashing the neighbors bedroom with my headlights.
I did mine a couple of years ago, and I can't find the detailed Tutorial on it, but this one shows what the module that you unplug looks like. I assume it's the same on the Outback.
Edit (again): That link was for a new age Impreza, which might work, but here is one for the Legacy. (You have an Outback Legacy right?)
Edited by SE_Sport_Driver (15/02/2004 23:53)
#130476 - 16/02/2004 16:13
Loc: Los Angeles, CA
i just discovered this.... a while back, i lost my rio remote, so i got a creativelabs remote and mapped everything one-to-one by their hex code. when i added visual=visualseek, it didn't work at all, with the remapped button.
y=z // visual to visualseek
x=y // custom button to visual hex code
one would expect that hijack would see the relationship, and would automatically do x=z, which is the custom button to visualseek, but it isnt the case.
#130477 - 16/02/2004 16:22
[Re: image]
#130478 - 16/02/2004 17:15
[Re: image]
could you post those mappings?
actually, what remote is this?
#130479 - 17/02/2004 00:50
[Re: muzza]
Loc: Stockport, UK
Next / Previous playlist using sony stalk shift/seek
[ir_translate]
000034=Bottom,Bottom.L,Top,Right,Bottom,Bottom,null
000035=Bottom,Bottom.L,Top,Left,Bottom,Bottom,null
#130480 - 17/02/2004 04:05
[Re: Daria]
it was the remote that came with this cdrom. you need the codes? all i did was use the hijack menu to find them, and then map accordingly.
#130481 - 17/02/2004 07:45
[Re: image]
Loc: Lochcarron and Edinburgh
No, because that would stop you (for example) swapping two buttons on a standard remote, or doing this one of mine:
;; Increase stalk volume control speed
KVolUp=VolUp,VolUp,VolUp,VolUp
KVolDown=VolDown,VolDown,VolDown,VolDown
(well, it would if I'd used KVol{Up,Down} on the RHS, anyway).
