#129534 - 07/12/2002 12:02 Can't search for a backslash character in Emplode?
Has this been mentioned before? I get strange errors in Emplode when attempting to do searches for a backslash character.
Situation is... I'm trying to search through all of my song tags and locate instances where the file would produce illegal-file-name results when downloaded to the PC. For instance, if a song title contains a question mark ("Are You Okay?"), it would get converted to an underscore in the file name when downloaded to the PC ("Are You Okay_"). I'm trying to make sure my collection is edited to avoid that problem.
The illegal characters are:
In addition, I'm going to search for underscores, and certain patterns of hyphens and parentheses in certain fields which would screw up my ability to use my preferred filenames-to-tags pattern in Tag Studio.
By the way, how do I search for a double quote in a field using the emplode advanced search?
#129535 - 07/12/2002 13:59 Re: Can't search for a backslash character in Emplode? [Re: tfabris]
mschrag
Loc: Richmond, VA
I would _guess_ that backslash is the escape character in Emplode ... try searching for \\ and quote as \". This is just a conjecture, mind you.
#129536 - 07/12/2002 18:10 Re: Can't search for a backslash character in Emplode? [Re: mschrag]
First thing I tried.
#129537 - 07/12/2002 19:44 Re: Can't search for a backslash character in Emplode? [Re: tfabris]
How 'bout:
title contains "\""
That's double-quote, backslash, double-quote, double quote.
#129538 - 07/12/2002 20:20 Re: Can't search for a backslash character in Emplode? [Re: tonyc]
Second thing I tried. Produces a different error message, but produces one nonetheless.
#129539 - 07/12/2002 20:39 Re: Can't search for a backslash character in Emplode? [Re: tfabris]
You sure? It worked for me...
#129540 - 07/12/2002 21:30 Re: Can't search for a backslash character in Emplode? [Re: tonyc]
I get an error box saying Expected closing quote in 'title contains "\"'.
#129541 - 07/12/2002 21:43 Re: Can't search for a backslash character in Emplode? [Re: tfabris]
That's what I get when I do this:
title contains "\"
But when I do this:
title contains "\""
It finds songs with a double-quote in the title. The two outside double-quotes designate it as a string, and the backslash escapes the "middle double-quote"
#129542 - 07/12/2002 23:03 Re: Can't search for a backslash character in Emplode? [Re: tonyc]
Ah, OK, so that's how I find a quote. How do I find a backslash?
#129543 - 07/12/2002 23:19 Re: Can't search for a backslash character in Emplode? [Re: tfabris]
Um, get Roger to fix Emplode.
#129544 - 09/12/2002 03:35 Re: Can't search for a backslash character in Emplode? [Re: tonyc]
Unfortunately, Peter was smoking crack when he wrote the string tokeniser -- it can't cope with a backslash before the closing quote. I'll fix it later. In the meantime, search for:
title like "*\\*"
#129545 - 09/12/2002 05:17 Re: Can't search for a backslash character in Emplode? [Re: Roger]
FITNR. Backslash inside a string literal now treats the next character literally. In other words...
"abc\"def\\gh\ijkl"
...is treated as the string literal...
abc"def\ghijkl
#129546 - 09/12/2002 07:08 Re: Can't search for a backslash character in Emplode? [Re: Roger]
And there was much rejoicing.
#129547 - 09/12/2002 10:40 Re: Can't search for a backslash character in Emplode? [Re: Roger]
Roger, YOU DA MAN.
And get Peter into a 12-step program.
#129548 - 13/12/2002 07:50 Re: Can't search for a backslash character in Emplode? [Re: tfabris]
sirmanson
Loc: Tucson, AZ USA
A short term solution you can use my access application to import an emplode CSV dump of your database and search for slashes.
http://empeg.comms.net/php/showflat.php?Cat=&Board=empeg_general&Number=129202&page=0&view=collapsed&sb=5&o=0&fpart=2&vc=1
----- RioCar 60gb
#129549 - 13/12/2002 08:43 Re: Can't search for a backslash character in Emplode? [Re: sirmanson]
revlmwest
Loc: Hartsville, South Carolina for...
Ok... I have no business in this forum, much less this thread, but I always read through them anyway. I guess I do it hopes that I will some how gleen bits of knowledge from the masters. As I read this thread there was so much I didn't understand that my brain was desperately searching to find words it recognized. So much that I read this
as Unfortunately, Peter was smoking crack when he wrote the string TOLKIENISER....cool so does it convert all the tags to tengwar.
Michael West
#129550 - 13/12/2002 10:28 Re: Can't search for a backslash character in Emplode? [Re: revlmwest]
