#127740 - 24/11/2002 20:59 Stair Dismount
BleachLPB
Loc: Maryland
Some of you may have seen this before - but you gotta check out the Stair Dismount... something that came to my attention recently.
This is hilarious. Make sure to turn up the volume so you can hear the guy's screams. I managed to get 69319 damage the other day.
BleachLPB ------------- NewFace MK2a
#127741 - 24/11/2002 22:17 Re: Stair Dismount [Re: BleachLPB]
DeadFire
Pretty funny... managed to pull 78985. Don't think I'll do better than that any time soon.
#127742 - 24/11/2002 22:49 Re: Stair Dismount [Re: DeadFire]
Yeah, it's harder to get the points to register in real life.
#127743 - 25/11/2002 10:06 Re: Stair Dismount [Re: BleachLPB]
lectric
Loc: New Orleans, LA
Wheee
#127744 - 26/11/2002 17:33 Re: Stair Dismount [Re: lectric]
I scored 114k. His head left his body, and the screams were great. My machine crashed while trying to upload the pic, though. I saved it for when I'm brave enough to try to upload again.
#127745 - 26/11/2002 17:49 Re: Stair Dismount [Re: Tim]
BleachLPB
Loc: Maryland
Damn, that score is impressive. I wish you could export the fall sequence as a little vide clip.
#127746 - 26/11/2002 18:21 Re: Stair Dismount [Re: BleachLPB]
I wanted to try to figure out how, and actually had the thing still saved (didn't play again) until the computer died. I wasn't happy. Trying it again, I was only able to hit like 74k.
#127747 - 26/11/2002 18:28 Re: Stair Dismount [Re: Tim]
Trying again...
Edit: It worked!!!! Serious neck and head wounding. Previous to this score, the head and neck added up to my old high score
Edited by Tim (26/11/2002 18:30)
#127748 - 26/11/2002 21:38 Re: Stair Dismount [Re: Tim]
I just nailed 118k. I shouldn't have installed this game on a night when i was evading school and homework and instead drinking beer...
#127749 - 26/11/2002 23:40 Re: Stair Dismount [Re: Tim]
Waterman981
Loc: Salt Lake City, UT
Woo Hoo!!!!
-Michael
#040103696 on a shelf
#127750 - 26/11/2002 23:47 Re: Stair Dismount [Re: Tim]
ithoughti
Loc: Boston, MA USA
cool... Unfortunately you would think the screams would have been better for so much damage...
//matt
#127751 - 27/11/2002 18:29 Re: Stair Dismount [Re: ithoughti]
DeadFire
My lucky break (no pun intended).
#127752 - 22/12/2002 11:10 Re: Stair Dismount [Re: DeadFire]
AndrewT
Loc: Oxford, UK
It's all downhill from here
Edited by Rue (22/12/2002 11:15)
#127753 - 22/12/2002 21:24 Re: Stair Dismount [Re: AndrewT]
lectric
Holy Crap.... Poor leg....
#127754 - 23/12/2002 01:58 Re: Stair Dismount [Re: AndrewT]
DeadFire
My method was to go for the head... heh. But yours seems to be working out much better.
#127755 - 23/12/2002 20:28 Re: Stair Dismount [Re: DeadFire]
AndrewT
Loc: Oxford, UK
That's a truly awesome score and I doubt I could repeat that easily. Did you notice that we are essentially exploiting a physics bug in the code? You are punching a portion of the body (seemingly) through the environment which gives these disproportionate scores.
#127756 - 23/12/2002 21:25 Re: Stair Dismount [Re: AndrewT]
DeadFire
I do know that we're exploiting a bug; that's how I got my 180,000 from head shots. The head would come clean off the body and then return, taking massive damage while it was moving at such a high speed. But I also believe there's a bit of luck involved. If you find a setting like yours, that works well, and stick to it, eventually you'll get a lucky fall that rewards you with much more damage than normal.
#127757 - 23/12/2002 21:43 Re: Stair Dismount [Re: DeadFire]
AndrewT
Loc: Oxford, UK
Sorry, I'm a total fraud, I Googled for help and didn't discover the (rough) settings myself
I agree about the luck part. Often my mousing [is that a real word?] doesn't resolve to the exact XYZ parameters that'd I'd like to try and add to that the power setting where all-bars-lit (or whatever you're trying to achieve) doesn't necessarily mean the same as the time before when it looked the same.
#127758 - 23/12/2002 22:36 Re: Stair Dismount [Re: AndrewT]
BleachLPB
Loc: Maryland
#127759 - 23/12/2002 22:40 Re: Stair Dismount [Re: AndrewT]
BleachLPB
Loc: Maryland
I googled it too. It looks like a little bit more than just a flesh wound on his shin.
This is another amusing combo, I forget if I mentioned it before or not (too lazy to scroll back). Set your heading to 0 and your pitch to about 45, and bop him hard on the head. He'll fall and bounce in such a way that he should land right on his head. Don't always get the most impressive scores, but it looks damn amusing.
Oh, and my new little picture/avatar to the left works
#127760 - 23/12/2002 22:48 Re: Stair Dismount [Re: AndrewT]
ricin
Loc: US: CA
There is a readme you know.....
Keys
Alt-Enter Switch between window and fullscreen
Space Dismount / Reset
Q Select previous body part
W Select next body part
R Replay (when dismount is finished)
P Pause
Ctrl-P Step the time a little bit forward when paused
C Next camera viewpoint
E Reset pitch and heading
S Turn score view on/off
M Manual camera (hold the key)
Ctrl-F Enable/Disable fog (disabled by default, see notes)
Ctrl-M Turn music on/off
Ctrl-S Turn sound effects on/off
0-9 Hotkeys for the camera viewpoints
Arrow keys Finetune heading & pitch (see notes)
Escape Quit the game
Notes
* Hold shift for even finer grain when finetuning heading & pitch
with arrow keys. Hold ctrl for bigger steps.
* Manual camera controls:
Drag with left button down: Change camera direction
Drag with right button down: Change camera position (x & y)
Drag with both buttons down: Change camera height (z)
* Fog causes problems on some graphics cards so it's disabled by default.
* All shown values are rounded from the exact value.
Donato
MkII/080000565
MkIIa/010101253
ricin.us
