#12621 - 02/08/2000 10:34 Player signal suport
schofiel
Is there any BSD-style signal handling built into the player application, or do all the signals default to the default signal action (SIGKILL)?
Mike, could you build in a set of signals to pause the player (INT), re-start the player (HUP)?
#12622 - 03/08/2000 10:23 Re: Player signal suport [Re: schofiel]
mac
Loc: Cambridge, UK
To quote David R. Butenhof "It is always best to avoid using signals in conjunction with threads. When signals and threads meet, beware"[1]
I'd rather not have to handle signals. I'm sure we can come up with another way that would work just as well - how about a named pipe which uses exactly the same commands as the serial port? (Not that I'm volunteering to write it anytime soon!)
[1] Programming with POSIX Threads, David R. Butenhof, Addison Wesley. section 6.6.
Mike Crowe
I may not be speaking on behalf of empeg above :-)
Mike Crowe
#12623 - 03/08/2000 12:18 Re: Player signal suport [Re: mac]
Couldn't someone do something like intercept.c which intercepts the IR codes, but intercept the serial port instead ?
__
