#125524 - 10/11/2002 19:47 rsync 2.5.5 with vfdlib hack
pim
In order to make rsync less boring, I've hacked a file progress indicator into rsync, using vfdlib.
You can download it here.
This binary is based on rsync 2.5.5. Enable the empeg display progress indicator by using the --empeg-progress command line switch. Otherwise, the binary works exactly the same as the non-hacked version that was available at the same location. Because this version is stripped, it's much smaller than its predecessor.
The binary does not require hijack.
Source to the hack is included. Have fun,
Pim
#125525 - 13/11/2002 03:23 Re: rsync 2.5.5 with vfdlib hack [Re: pim]
anti
Loc: BaWue, Germany, Europe
How about showing a screenshot ?
(I'd do it myself, but I'm upgrading my disks next weekend and won't fiddle with my setup until that is done.)
-------------------- MKII 08000073 40GB BLUE
#125526 - 13/11/2002 04:35 Re: rsync 2.5.5 with vfdlib hack [Re: pim]
skibum
Loc: Swindon, UK
oooh, this will be tried tonight.
#125527 - 13/11/2002 07:57 Re: rsync 2.5.5 with vfdlib hack [Re: skibum]
unsquare
Loc: Rignt here
what do it do?
:: john (24GB Mk2)
#125528 - 13/11/2002 12:53 Re: rsync 2.5.5 with vfdlib hack [Re: pim]
skibum
Loc: Swindon, UK
Pim, this is just yummie.
although my other riocar is setup with rsync, I hadn't done the one I'm rsyncing to now. So, I set this up, and while it was deleting all the music, the screen was blank.
After that, it looks wonderful. As this empeg is new, I'm not setup to do a capture of the display, but trust me. Add the --empeg-progress to you rsync script and you won't be disappointed.
#125529 - 04/02/2003 05:54 Re: rsync 2.5.5 with vfdlib hack [Re: anti]
pim
It took me a while to figure out how easily screenshots
are made with Hijack ...
So here's one:
This screenshots shows
- name of file currently being transmitted
- size of source file
- ETA (estimated time of arrival)
- current transfer speed
- number of transferred bytes
- progress bar and percentage indicating file progress
- progress bar and percantage indicating progress on number of files
Pim
#125530 - 14/02/2003 20:32 Re: rsync 2.5.5 with vfdlib hack [Re: pim]
fink08
When i try to run rsync with the --empeg-progress switch I get an unrecognized option error.
#125531 - 15/02/2003 02:41 Re: rsync 2.5.5 with vfdlib hack [Re: fink08]
skibum
Loc: Swindon, UK
works for me with :-
/bin/rsync \
--times \
--delete \
--verbose \
--recursive \
--copy-unsafe-links \
--exclude=config.ini \
--exclude=lost+found \
--exclude=khttpd \
--empeg-progress \
${rsyncserver}::${modulename}/drive? /
