#123257 - 27/10/2002 10:54 jEmplode 43
mschrag
Loc: Richmond, VA
Pretty must just a bugfix release, but here are the changes:
jEmplode - removed "drive" tag
jEmplode - fixed human-readable size format
jEmplode - fixed "pos" tag for downloading
jEmplode - insufficient permission to read mp3 during import = skipped mp3
jEmplode - multiple-select w/ Play/Insert/Append is kinda fixed (it doesn't do one request yet)
jEmplode - if tracknr == -1 or is blank during download, tracknr gets replaced with pos
jEmplode - genre import/export works
jEmplode - much more accurate failed-to-connect-to-Hijack error messages
jEmplode - Thanks to tms13 for fixing some issues with internationalized characters in XML export
http://www.jempeg.org/jemplode20.jar
Mike
P.S. and I remembered to set the version number this time! <homer>woohoo!</homer>
#123258 - 27/10/2002 10:56 Re: jEmplode 43 [Re: mschrag]
How's tag-writing-on-download doing in this version?
#123259 - 27/10/2002 12:30 Re: jEmplode 43 [Re: tfabris]
mschrag
Loc: Richmond, VA
Works for me ... Make sure the settings are turned on in Tools=>Options, but give it a shot and let me know.
#123260 - 27/10/2002 20:18 Re: jEmplode 43 [Re: mschrag]
eliceo
in another post it was mentioned that pc to empeg time sync is possible. Ive installed jEmplode 43 but cant seem to find this feature. Ive also searced through the bbs. How is this feature accessed?
#123261 - 27/10/2002 20:39 Re: jEmplode 43 [Re: eliceo]
mschrag
Loc: Richmond, VA
If it's possible, it's not through jEmplode ... I would check the faq at riocar.org.
#123262 - 27/10/2002 21:27 Re: jEmplode 43 [Re: mschrag]
eliceo
Yeah I probably read the post wrong and hoped that it was possible, thanks for the quick reply though.
#123263 - 27/10/2002 22:09 Re: jEmplode 43 [Re: mschrag]
I don't have anything in the main FAQ at riocar.org on that topic. I believe that in order to do PC-to-empeg time sync, you would have to compile some special software for the empeg. Because it's not built in to the empeg. I could be wrong, though.
#123264 - 27/10/2002 23:14 Re: jEmplode 43 [Re: mschrag]
jbauer
Loc: San Francisco, CA
Thank you Mike!
- Jon
#123265 - 27/10/2002 23:34 Re: jEmplode 43 [Re: mschrag]
jbauer
Hm. I can't get v43 to do what I would think it does...
I have "Write ID3v2 Tags to Downloaded Files" checked and it writes the data in the ID3v1 tag area.
This would be ok, except that a lot of my song names are very long and I think there's a much shorter song name limit in ID3v1... right?
The POS feature is outstanding. Great idea filling it in only when it's blank!
- jb
#123266 - 28/10/2002 05:13 Re: jEmplode 43 [Re: jbauer]
mschrag
Loc: Richmond, VA
That's strange ... it shouldn't be writing in the v1 area... try turning on remove ID3v1 tags and see if that makes any difference?
#123267 - 28/10/2002 09:07 Re: jEmplode 43 [Re: mschrag]
jbauer
If I check "remove ID3v1 tags", then I get no tag at all...
- Jon
#123268 - 28/10/2002 09:36 Re: jEmplode 43 [Re: jbauer]
mschrag
Loc: Richmond, VA
I'll take a look at this tonight ...
#123269 - 29/10/2002 07:58 Re: jEmplode 43 [Re: mschrag]
tms13
Loc: Lochcarron and Edinburgh
On http://www.jempeg.org/, the link entitled "jemplode20-43.jar" points at jemplode20-42...
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#123270 - 29/10/2002 08:10 Re: jEmplode 43 [Re: tms13]
mschrag
Loc: Richmond, VA
try it now ...
thanks
ms
#123271 - 29/10/2002 17:58 Re: jEmplode 43 [Re: mschrag]
jbauer
Any luck yet Mike?
- Jon
#123272 - 29/10/2002 19:01 Re: jEmplode 43 [Re: jbauer]
mschrag
Loc: Richmond, VA
workin' on it ... i switched back to an older version of dan's id3 lib to try to work around something else, and I think I regret it.
#123273 - 30/10/2002 04:41 Re: jEmplode 43 [Re: mschrag]
tms13
Still looks wrong to me. I waited a while for the proxies to clear their caches, but of course I can't be sure.
Toby Speight
#123274 - 30/10/2002 05:36 Re: jEmplode 43 [Re: tms13]
mschrag
Loc: Richmond, VA
Oh ... you're saying the href was wrong .. i thought you were talking about the symlink (like the reference on the filesystem was pointing to the wrong one). I'll fix the link right now...
#123275 - 30/10/2002 06:00 Re: jEmplode 43 [Re: jbauer]
mschrag
Loc: Richmond, VA
It's going to be a little longer than I hoped ... I'm talking with Dan to figure out what is going on.
#123276 - 30/10/2002 08:45 Re: jEmplode 43 [Re: mschrag]
tms13
Thanks, Mike - looks better now.
I prefer to download the numbered file so I don't have to rename it here (I like to keep a directory of jars, and point a symlink to the "current" one in case I need to downgrade).
Toby Speight
