#122608 - 23/10/2002 12:16 SMD UV LEDs are to be had
acurasquirrel_
I finally found some http://www.sander-electronic.de/be00027.html these would work well in the buttons kit to better illuminate the buttons.
Catapultam habeo. Nisi pecuniam omnem mihi dabis, ad caput tuum saxum immane mittam.
#122609 - 23/10/2002 12:19 Re: SMD UV LEDs are to be had [Re: acurasquirrel_]
What, you mean if you cast the buttons with fluorescent material in the plastic?
#122610 - 23/10/2002 12:20 Re: SMD UV LEDs are to be had [Re: acurasquirrel_]
robricc
This was discussed in in the past. I guess nobody tried it yet....
#122611 - 23/10/2002 12:22 Re: SMD UV LEDs are to be had [Re: tfabris]
acurasquirrel_
Yeah I would imagine with the 110 degree viewing angle and the buttons cast with some type of flourescing(sp?) material in the mix should lead to pretty neat looking buttons.
#122612 - 23/10/2002 12:25 Re: SMD UV LEDs are to be had [Re: robricc]
acurasquirrel_
Well until the became available in SMD you really couldnt pull it off.
#122613 - 23/10/2002 12:35 Re: SMD UV LEDs are to be had [Re: acurasquirrel_]
Um, keep in mind that the button LED's aren't SMD, only the knob LEDs.
The button LEDs are through-hole, they're just the smaller ones not the larger ones.
#122614 - 23/10/2002 12:49 Re: SMD UV LEDs are to be had [Re: tfabris]
acurasquirrel_
Yes Im aware but would it not look odd to have the buttons lit with UV and the knob not? Now with these LEDs you can light up both via UV.
