#122188 - 22/10/2002 00:24
jemplode: sync goes into la-la land?
Had this problem with 42-pre5, so I upgraded to 42.
I set a wendy flag on one song, and make no other changes, then sync.
The status indicator bar window pops up, says "Locking Player Interface", then nothing. JEmplode no longer refreshes the screen, either. The player eventually gives up, per the serial port output:
server_protocol_handler.cpp:1383:Timeout during synchronise, restarting player
And in fact I then have to resynchronize to get a useful database...
I figure I'm going to have to look at this, but I was wondering if anyone had ideas. I think I'm going to sleep now.
#122189 - 22/10/2002 04:35
Re: jemplode: sync goes into la-la land?
[Re: Daria]
Loc: France, Champagne
Dont know if it can help but I had problem to sync my player but Error Message was 'Media Error' player rebooted and could not sync my player.
I stopped the applications daemon launched by preinit and then no error.
Empeg IIa - 10 Gb - Red Fascia -
Tuner, the day is coming
- I Will Strike From the Grey -
#122190 - 22/10/2002 11:26
[Re: Daria]
Loc: Richmond, VA
Can you consistently reproduce this?
#122191 - 22/10/2002 11:28
[Re: mschrag]
Very easily. I backed out to non-ext3. I suppose I can disable gpsapp and launcher, but i can sync songs to it, just not set these wendy flags, so that seems sort of an odd manifestation.
#122192 - 22/10/2002 11:31
[Re: Daria]
Loc: Richmond, VA
Definitely weird ... what if you change another tag at the same time? What if you JUST change title, and not wendy? Just trying to narrow the problem down .. curious if it's only when you ONLY sync tags with just wendy changed .... There must be an error that's being swalled somewhere...
#122193 - 22/10/2002 12:03
[Re: mschrag]
I tried changing other tags and the wendy and lost, I can try some other things, but the cycle time on this is like 30 minutes, because the player app times out, builds a database inline, then i reconnect with jemplode and it has to rebuild the database, so it's tedious. i'll try it this evening, after i get home, if you have a larger list of things to try, i'll try as many as i can before i sleep
#122195 - 22/10/2002 12:42
[Re: Daria]
Loc: Richmond, VA
If you can just do one last one where you just change a comment and sync, that's all i need ... just curious.
#122196 - 22/10/2002 12:48
[Re: Daria]
And of course now I remember why I had ext3; I need to not pull power on the player to get the app to restart when this happens. Sigh.
#122197 - 22/10/2002 12:49
[Re: mschrag]
Ok, as soon as it's back I'll change a comment in the same song, and sync.
#122198 - 22/10/2002 19:42
[Re: mschrag]
Changed just a comment, on the same song, and lost the same way.
Perhaps of some significance, perhaps not, is that I selected the song from the result in the large pane of a search for "marked=yes"
I intend to test this theory, but not until I play games with my cable company.
#122199 - 27/10/2002 06:50
[Re: Daria]
Loc: Richmond, VA
I'm doing this on 42 on my Win2k box and it's working fine ... What OS and Java VM version are you using?
#122200 - 27/10/2002 10:14
[Re: mschrag]
Started life as RedHat Linux 7.2, java is
java version "1.3.1_02"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.3.1_02-b02)
Java HotSpot(TM) Client VM (build 1.3.1_02-b02, mixed mode)
I haven't gotten back to experimenting and figuring out what's going on.
I suppose I should look into the possibility of an interactive java debugger, because while I don't know Java I don't think I'm quite so slow that I couldn't figure it out, if I had a way to watch what was going on.
#122201 - 27/10/2002 10:41
[Re: Daria]
Loc: Richmond, VA
when 43 goes up, put jempeg.debugLevel=24 in your .jempegrc and try again ... this should print debug output to your console (you might have to run it java -jar jemplode20.jar to see this output)
Mike
#122202 - 27/10/2002 10:44
[Re: mschrag]
#122204 - 27/10/2002 11:56
[Re: Daria]
I guess I'll try updating to Java 1.4, "just in case".
#122205 - 27/10/2002 12:19
[Re: Daria]
No dice. Tried selecting from a playlist instead of a search, and tried Java 1.4. Still lose.
I guess I'll try to figure out how to debug java now.
#122206 - 27/10/2002 12:32
[Re: Daria]
Loc: Richmond, VA
It looks like there is some output cut off here ... can you make sure you have the full stack trace and exception name? probably run java -jar jemplode20.jar > output.log and put the contents of output.log up for me to take a look at.
Mike
#122207 - 27/10/2002 12:34
[Re: Daria]
Loc: Richmond, VA
Does this happen only on one particular song or on any single song?
#122208 - 27/10/2002 12:40
[Re: mschrag]
I can try a different one, but I've been trying the same one.
#122209 - 27/10/2002 12:47
[Re: mschrag]
Different song, still lost.
I can put it on the network for real if you think it will help. Otherwise I'll find a debugger eventually.
121938-output.log (186 downloads)
#122210 - 27/10/2002 13:11
[Re: Daria]
Loc: Richmond, VA
Can you do the same thing but change jempeg.debugLevel to 31?
#122212 - 27/10/2002 17:01
[Re: Daria]
I figured maybe jswat would help. And, I got as far as loading the database, but couldn't actually trigger the problem before jswat died:
java.lang.StringIndexOutOfBoundsException
at java.lang.StringBuffer.deleteCharAt(StringBuffer.java:650)
at com.bluemarsh.jswat.PathManager.setSourcePath(PathManager.java:478)
(and so on)
I hate Java.
#122213 - 27/10/2002 17:45
[Re: Daria]
Loc: Richmond, VA
Blame jswat, not Java  OK .. One last time, we'll get really picky and set debugLevel to 32 -- this will do the full debug output of the protocol... Can you put the whole output log up for that too? Sorry to have you keep doing these .. they're not telling me much, unfortunately.
ms
#122214 - 27/10/2002 17:47
[Re: mschrag]
Well, yes, I gathered the logs have been pretty useless.
#122215 - 27/10/2002 17:56
[Re: mschrag]
Surely this can't be right. After the database rebuilds I'm going to try again.
121959-output (284 downloads)
#122216 - 27/10/2002 18:00
[Re: Daria]
#122217 - 27/10/2002 20:02
[Re: mschrag]
jdb is too crude. jdebugtool seems to have hung after starting the JVM. At least jswat run for a while before it blew up. How can I not blame Java when as a novice every debugger I try just wants to taunt me?
