Page 3 of 3 < 1 2 3
#120783 - 15/10/2002 12:49 Re: empeg-preinit v6 [Re: genixia]
Try hijack299-jh1-mount fix
Does this have Jaharke's changes too?
#120784 - 15/10/2002 13:07 Re: empeg-preinit v6 [Re: tfabris]
genixia
Take a guess: hijack299-jh1-mountfix
You don't really think I'd tag one of my changes with jh1 do you????? the -mountfix is mine.
#120785 - 15/10/2002 14:00 Re: empeg-preinit v6 [Re: genixia]
Thanks. You guys are great.
Any chance of talking Mark into including both in the standard release?
#120786 - 15/10/2002 14:03 Re: empeg-preinit v6 [Re: tfabris]
jaharkes
I already sent my change to mlord
#120787 - 15/10/2002 14:27 Re: empeg-preinit v6 [Re: jaharkes]
Now that the problem in the kernel is fixed, I've already managed to crash the player a few times because of the bug, and on one of my FSCK repairs I got the following error text indicated. Do you think this indicates a serious problem or not?
Pass 1: Checking inodes, blocks, and sizes
Deleted inode 2078 has zero dtime. Fix? yes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
Block bitmap differences: -9733 -9734 -9735 -9736 -9737 -9738 -9739 -9740 -9741
-9742 -9743 -9744 -9745 -9746 -9747 -9748 -9749 -9750 -9751 -9752 -9753 -9754 -
9755 -9756 -9757 -9758 -9759 -9760 -9761 -9762 -9763 -9764 -9765 -9766 -9767 -97
68 -9769 -9770 -9771 -9772 -9773 -9774 -9775 -9776 -9777 -9778 -9779 -9780 -9781
-9782 -9783 -9784 -9785 -9786 -9787 -9788 -9789 -9790 -9791 -9792 -9793 -9794 -
9795 -9796 -9797 -9798 -9799 -9800 -9801 -9802 -9803 -9804 -9805 -9806 -9807 -98
08 -9809 -9810 -9811 -9812 -9813 -9814 -9815 -9816 -9817 -9818 -9819 -9820 -9821
-9822 -9823 -9824 -9825 -9826 -9827 -9828 -9829 -9830 -9831 -9832 -9833 -9834 -
9835 -9836 -9837 -9838 -9839 -9840 -9841 -9842 -9843 -9844 -9845 -9846 -9847 -98
48 -9849 -9850 -9851 -9852 -9853 -9854 -9855 -9856 -9857 -9858 -9859 -9860 -9861
-9862 -9863 -9864 -9865 -9866 -9867 -9868 -9869 -9870 -9871 -9872 -9873 -9874 -
9875 -9876 -9877 -9878 -9879 -9880 -9881 -9882 -9883 -9884 -9885 -9886 -9887 -98
88 -9889 -9890 -9891 -9892 -9893 -9894 -9895 -9896 -9897 -9898 -9899 -9900 -9901
-9902 -9903 -9904 -9905 -9906 -9907 -9908 -9909 -9910 -9911 -9912 -9913 -9914 -
9915 -9916 -9917 -9918 -9919 -9920 -9921 -9922 -9923 -9924 -9925 -9926 -9927 -99
28 -9929 -9930 -9931 -9932 -9933 -9934 -9935 -9936 -9937 -9938 -9939 -9940 -9941
-9942 -9943 -9944 -9945 -9946 -9947 -9948 -9949 -9950 -9951 -9952 -9953 -9954 -
9955 -9956 -9957 -9958 -9959 -9960
Fix? yes
Free blocks count wrong for group #1 (2096, counted=2324).
Fix? yes
Free blocks count wrong (6117, counted=6345).
Fix? yes
Inode bitmap differences: -2078
Fix? yes
Free inodes count wrong for group #1 (1302, counted=1303).
Fix? yes
Free inodes count wrong (2572, counted=2573).
Fix? yes
/dev/hda5: ***** FILE SYSTEM WAS MODIFIED *****
/dev/hda5: 1523/4096 files (0.5% non-contiguous), 10039/16384 blocks
#120788 - 15/10/2002 14:52 Re: empeg-preinit v6 [Re: tfabris]
jaharkes
No that shouldn't be serious. Some large file was removed, but was still in use when the drive was remounted readonly. So it was only 'marked' for deletion (deleted inode has 0 dtime), but never really reclaimed. When that is 'fixed' the blocks that were part of this file are no longer referenced, but the allocation bitmap still shows them as used. those are the block bitmap differences. Finally the free blocks counts are corrected, as long as the number of free blocks increases it should be safe.
It actually looks like 2 files were deleted, as the inode count was off by 2. Both of them were about 228 blocks, so about 228KB or 872KB depending on the filesystem blocksize.
#120789 - 15/10/2002 14:55 Re: empeg-preinit v6 [Re: jaharkes]
Cool, I think I know what file it was. All is well.
#120790 - 07/12/2002 15:56 Re: empeg-preinit v6 [Re: wfaulk]
lothar
I'm trying to download preinit but it looks like the site is down Sat 12.7.02 @ 3:00pm PST.
http://www.beaglebros.com/empeg/empeg-preinit/
Would someone be kind enough to either attach it to this thread or post it somewhere else?
TIA.
-lothar
#120791 - 09/12/2002 08:32 Re: empeg-preinit v6 [Re: lothar]
smu
Loc: Germany (Ruhrgebiet)
Hi.
You are probably able to get it from the quoted URL again, but I attach it to this post anyway.
cu,
sven
128660-empeg-preinit.v7.zip (52 downloads)
#120792 - 09/12/2002 12:17 Re: empeg-preinit v6 [Re: lothar]
Sorry. My computer was down for nearly four days due to a large ice storm combined with CP&L's general incompetence. Off to research hydrogen fuel cells.
Page 3 of 3 < 1 2 3
